Pilot keeps going out, already changed the thermocouple
  • 767 Answers
Hello my name is Heath it will be my pleasure to assit you. What you will need to do is pull out the whole pilot assembly and clean the pilot orifice. Its inside the pilot assembly where the silver tube attaches with the brass nut.
Posted on Oct 08, 2010
U can light the pilot lite,turn 2 ON it will stay lit 4 a couple of minutes then go out? If u turn the knob 2 low,med. It goes out pretty much immediately?I changed the thermocouple,blew the lines ou
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Feb 17, 2015 | Rheem Richmond 75 Gal Natural Gas 6 Year...
What can go wrong with a garland thermocouple?
Make sure the thermocouple is screwed securely into the safety valve... it is a -tiny- voltage and a small loss can drop the pilot. Also make sure the pilot flame covers the last 1/3 of the thermocouple element, you don't wan to cover the whole thing. Check for errant air currents that might be blowing the pilot out.
Jul 19, 2014 | Garland H286 Gas Kitchen Range
I changed my thermocouple on my fireplace,it still wont stay lit
Thermocouple keeps the pilot lit.
Thermopile keeps the burner lit.
Please specify what won't stay lit...
If it's the burner, you may need to change the thermopile as well.
If the pilot still won't stay lit, you will want to make sure that the pilot flame is large enough to completely engulf the thermocouple and keep it hot. If it's too small, you may need to take some compressed air and blow out the pilot hood to remove any blockage.
Dec 18, 2012 | Napoleon 36" Zero Clearance Top/Rear Vent...
Pilot light keeps going out
If you have not already replaced the thermocouple then this may be the problem, If you
have already replaced the thermocouple with a "universal" this may also be the problem
as it may be a different length in relation to the flame of the pilot.
Feb 24, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Our pilot light does not stay on...sometimes when temperature changes out side
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out as the outside air cools.
Sep 21, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Apr 04, 2010 | Stoves Premier 600GRa Gas Single Oven
Reznor model# f125 pilot won't stay lit. i
Make sure the pilot is clean (Blue flame fully enveloping the top portion of the thermocouple) if its dirty the pilot will be yellow like a candle and barely touching the thermocouple ...quick fix is knock the pilot with a screwdriver...gently tapping it...knocking the dust out and getting a better pilot....the pilot could also be too small if its not making good contact with the thrermocouple....there could also be an Auxillary limit wired into the thermocouple which when open will prevent the magnet from staying closed....if all looks fine then the Gas Valve itself is likely gone (The magnet inside is not field repairable)
Oct 25, 2009 | Heating & Cooling
Climate master furnace ,can't keep the pilot burning ,i have already changed the thermocouple
Make sure the thermocouple is well into the flame. Remove the pilot assembly and clean out any debris in the pilot orifice. Tighten the connections to make sure there is no gas leak and lastly, replace the thermocouple again. You may have gotten a bad one.
Oct 09, 2009 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
My bosh water wizard 10P pilot light keeps going out.
Very possible the thermocoupler is no good. The thermo coupler is that bulb that is in the pilot flame. It controls the main valve It's not expensive and fairly easy to change out.. Make sure you get no dirt in the cspillary tube hole.brass screw end. The bulb must be just in the flame tip when adjusting. Good Luck, Ned-
Sep 17, 2009 | Bosch & Tankless LP Hot Water Heater
The pilot light to our fireplace insert keeps going out. after the fireplace is lit, we here a click and then the pilot light goes out and the fire goes out. we already changed the thermocoupler.
Check venting, exhaust, the adj vent in fireplace. If that does not work your valve failed, warranty it. If no warranty expect to pay between 90 to 150 dollars.
Dec 05, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
