Question about LG Studioworks 563N 15" CRT Monitor
Please describe eht number and output fet number
  • 11,361 Answers
"tc2119r" EHT Number Please
High voltage transformer or ? Google the model number with the brand to search for this part.
Nov 06, 2012 | Televison & Video
Please give me cineplus eht number sir
If you have confirmed that the EHT has shorted the EHT must be removed out of the board if you need to find the replacement from a general electronic store as the EHT can be indetified . If you choose to order from LG, then all you need is to quote your TV's model number. Contact LG support center.
http://www.lg.com/us/support/index.jsp
Oct 03, 2011 | LG RU-52SZ30 52" Rear Projection...
Power ok but not eht function
Hello
If you have tested the secondary section of the SMPS power supply of your Sony TV, amd found it OK I thinks, and posts this solution.
If the secondary supply rail 125VDC is found ok, just goto to the Horizontal Output Transformer, a small transformer diretly soldered on tho the main board, very near to the Line Output Transformer [LOT], and its secondary winding is connected to the base of the line output transistor, which in turn drives the LOT said above, generates EHT you described.
The base of the line output transitor must get appropriate frequency to switch on and off. This frequenct is gerally comes to 15625Hz. Just measure the voltage across the primary winding of the above said line driver transformer, which can be a possiblity open winding. Check the voltage at the collector point of the line drive transitor connected ti the one end of the primary winding is easy. Then check the voltage at the other end of that winding. There must be a little difference of 2VDC or so, if the line drive section is working, and fault is after that section, that is line output section. If you have a digital multimeter capable of measuring frequency, measure the frequency of the collector point of line drive transtor, and find out whether there is 15625Hz or near to this frequency comming out. Never touch the multimeter prob to the collector of Horizontal Outout Transistor, while it is working. Your meter will get damaged.
Line output section, contains tha LOT said above and line output transitor. If the Line Output Transistor has some sort of leak, normally collector to base leak, it will not drive the LOT to produce EHT and it wlii heat up also.
Just check it heat effect, after switching the set on for a short period of time, say 30 seconds ro so. If it heats up abnormally, suspect the line output transistor and LOT. You just replace the line output transistor first, with same type and number. If it doesn't retify your problem, LOT said abve is faulty, and it also should be replaced with same type and number.
If you have to replace the horizontal output transistor, and the LOT said abve, insist on orginal, and not replace it with a susbstityution, as these are critical components in all TVs..
If you need further assistance, get me through Fixya, and be free to conact me. Ok
Nov 29, 2010 | Sony KV-XA21M61 21" TV
X2GEN 19" Monitor
becauce of overload such a problems are come please disolder path of an eht and look whether smps gives output or not if smps gives output contineusly then replace eht
Oct 27, 2008 | X2Gen MG19MY 19" LCD Monitor
EHT PROBLAM
EHT Problemsymptems :1.If U find R457 - 33k,R452 -1k,R458 - 10k Resisters are Burnt In Zenith 14"and15" monitors To replaced all thease resisters and LOT FSN14B016S
2.HCL HCM 482M, 580M,582M, 780M models getting FAT - FAT sound coms from LOT when u switch on the monitor It's LOT Problem . replaced it
3.Samtron Samsung Models like 45Bn, 55V,56V when u switched on the monitor Power indicator (Led )glow one time First u can check Boosting FET IRF630 bitween (SMPS O/P to LOT supply) and also replace LOT.
4.some Old Gold star anlog and LG monitors If U found 12k Resister near by LOT and also bulched 1Mfd/63V capacitor
It's LOT Problem
Oct 04, 2008 | Computers & Internet
Help for TCL Brand of tv
I WANT THE SERVICE MODE CODE FOR MODEL NO: DP21E101 TCL TV 21"
Jun 15, 2008 | LG 30FS1D TV
Need a part # and where to order a horizontal output transistor. stamped on transistor p5nk 50zFP GK180 CHN 607
hori out puts numbers are like D1581, C1551,or NTE2973 NTE2324 and so on None of the numbers you have cross over to anything.
Mar 12, 2008 | Televison & Video
Loud pop and picture is no longer available.....
blown resistor (42ohm) replaced this and it imediately blew it clearly shows that there is a short circuit in your tv. if you are a tech person please proceed as follows. 1 isolate power supply from hor.output section. 2 now check power supply section.i.e. switching tran., cap..diode etc. 3 if it becomes ok check power supply output. 4 if output is ok then check hor. output section.i.e. h.out tr.,cap& diode in eht winding. 5 check print near eht. 6 at finally eht. 7 see every thing is normal now. now reconnect power to hor.section. put on tv. good luck.
Sep 24, 2007 | Philips 7P6041W TV
No raster no audio,Zenith SJ 2065S5
as horizontal transistor gets very hot so no eht so no raster &no sound due to nosupply to vif & tuner. as hor output is getting hot please isolate supply to hor. section & check power supply output is ok as due to high voltage h/outout may get hot & demaged. if supply is ok check for leaky or short parts in hor output. 1 hor. output transistor itself if it is replaced that may not be of proper matching. 2 diode& cap.in eht section. 3 clean print near eht. 4 moisture near yoke due to rain in rainy season only. so keep it hot for few hours. 5 at last if all are ok eht or fly back transformer. re connect power to hor output after rectification
Sep 18, 2007 | Televison & Video
LG Studioworks 563N 15" CRT Monitor Logo
47 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
