Question about Bosch 24 in. SGV53E03 Built-In Dishwasher
The tap light is on m bosch sgv53e03 and wont fill or empty but is making noise to suggest its trying to work
2 Suggested Answers
  • 409 Answers
SOURCE: bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Posted on Sep 25, 2008
Bosch classicxx
could be the engine check if the motor in not dirty the coper motor next to the brushes has got gold ish colour if not just clean with sand paper
the noise could be the bering ( if the noise is cracking ) ( if the noise is metal could be somthing in iner drum )
Jan 17, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Dishwasher making sucking noise and no water coming out
I had the same problem with my Bosch dishwasher, and what I had to do was open up both of the lids at the bottom, and fill the empty one with water, then it worked.
I realize this is probably way too late to help you, but maybe someday another guy will have this issue.
Feb 04, 2012 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Classixx 1400 Express: stopped midway through wash cycle, making a high-pitched beeping noise. Water and clothes are trapped in the machine. I have tried setting it to drain and spin - just makes a...
if there is still water in drum the door wont open try tilting the machine back so the water is not touching the door and wait for a click that normly works
Mar 28, 2011 | Bosch Washing Machines
Moved to new home hooked everything up washer will not fill
ther's something wrong with your water supply to the washer the humming noise is the solenoid on water valve working check water taps to make sure there is water there and hoses are not kinked
Jun 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch SHV46C
Replace the fill valve that sound is it trying to open
Mar 12, 2009 | Bosch 24 in. SHV46C13UC Free-Standing...
Bosch classicxx dishwasher not working check water light on
he there,
thanks
Sep 25, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch sgv53e13gb Integrated dishwasher - wont start a new cycle!?
As the machine is only two weeks old I would go straight back to the seller and report the fault to them - and take a copy in writing. Don't be fobbed off with any instructions to get in touch with the makers - your contract is with the seller and it is up to them to fix it! And if you mention compensation for the inconvenience caused by this defective product, it might help speed things up.
Hope this helps! D.
Jul 13, 2008 | Bosch 24 in. SGV53E03 Built-In Dishwasher
My dishwasher has been running for 4 hours!
The long cycle is caused by the heater not heating the water or not having enough water in it to heat. It is normally a slow fill valve in the unit. The best way to check is to start a cycle and let it fill to see how much water is in it. If you add a little water to it and it pumps better you will know you have a water supply problem.
Apr 23, 2008 | Bosch 24 in. SGV53E03 Built-In Dishwasher
Bosch classixx condenser drier
The problem is with the lower water tank float switch, it is stuck. Take off the right hand side panel (as you are facing the machine) at the bottom you will see a spring mechanism for the belt tension. Beside this there are 2 electrical connectors. Take them off and spray with wd40 or similar. Whilst off give the plastic box they fit 2 a light tap with a hammer to free the float switch. Reconnect and try. If this fails you can over-ride by leaving the left hand of the two plugs off. This will get your machine working but you will not have an indication as to when the water container needs emptying so you will need to remember.
Nov 30, 2007 | Bosch Axxis WTA4400 Dryers
Loud click / tap noise every couple of hours or so
Check your owners manual for a list of common noises it should make to see if it's on that list. Does this have an icemaker? That time frame could be an ice maker valve turning on for a few seconds to fill the tray (or dumping ice).
Oct 16, 2006 | Bosch Exxcel KSR34423 Refrigerator
Bosch 24 in. SGV53E03 Built-In Dishwasher Logo
61 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
