Question about Panasonic PT-51HX42 51" Rear Projection Television
Panasonic PT51HX41E 51" PROJECTION TV is doing the same thing.Comes on for a few seconds then turns off.I have to unplug it to try it again, but it still turns itself off.
  • rip1874 Oct 08, 2010
    A picture tries to appear befor it shuts down. I've never had to change any of the lamps. Is there anything I could test with a volt meter?
    That would great. Please send me the that info. and THANKS!
    President:
  • 2,777 Answers
Sounds like a failed or at least failing power supply / power board inside the TV. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You will need to contact a local TV repair person in your area. This is actually the most common problem with this type of TV, I see it every day, it just happens - sometimes with new TVs and sometimes it takes many years for it to happen.
If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
If you want to attempt the repair yourself please let me know and I will get you the part number and a place you can purchase it from for what you need.
So sorry that I don't have better news but it is definitely a power issue internally.
Thanks
Tim
Posted on Oct 08, 2010
  • Tim Grayson
    Tim Grayson Oct 08, 2010
    Man oh man I have searched far and wide for the power supply, noone seems to have it in stock. Sometimes this is an issue for older TVs. What is your zip code, I will try to find someone locally for you that can special order it, if that's even possible.
    Thanks
    Tim
  • Panasonic Master
  • 11,800 Answers
There's a fault in the high tension module - one of the tubes is having an abnormal power draw that causes the high tension module to overstress, that in turn activates the autoprotection of the power source, that shuts the tv down.
The tv must be opened and tested to identify the failed part/tube. This is a job for someone with a lot of experience, otherwise a bad move can be fatal - there are over 25,000 volts there. Time to call a repairman.
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My panasonic pt51hx41e convergence will not line up
Clean the projection lenses with qtips and alcohol. Then try to use the convergence function. My blu was messed up on one side of the screen until I cleaned mine.
Mar 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Tv wont turn on
how was the pix on your tv befor it shout off if it look like a 3d piix you have bad con.v ic to see f you do open it up and look for two big ic or stk. and look for the power suppy line and unplug it now tv should come if it do come on you have bad con.v stk 392-120or 110
Dec 07, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Convergence for HD channels only
Hello, please check the IC7102 (24LC64). This is eeprom that contains the convergence data. Please ask the Panasonic dealer if they can supply a replacement IC with the data for your HD. If you need more info please advice. Arpi
Jun 08, 2007 | Panasonic PT-51HX41 51" Rear Projection...
PT51HX41E PANASONIC
I know it has been about a year since you posted but I was wondering what you did about your Panasonic? I to have one that has turned white....I think it is a lemon ..my son also had the sam eproblem with his....we paid over 2,000 for this piece of JUNK...Thanks....diggey2@yahoo.com
Nov 19, 2006 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT51HX41E
you need remote control that came with tv ,there is a service code menu for techicians only - setting convergence on these sets are not easy.you Must Know what you are doing other wise you can shut set down with bigger problems.Call a repair shop if your not sure.I have service codes but ,i will not tell someone these codes unless they do know How to set convergence.
Oct 23, 2006 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX42 51" Rear Projection Television Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
