Question about ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard
Sir my computer is biso jumper changed. system on. but my biso jumper 1to2 pin connected the not on. but 2 to 3 jumper pin connected the system on. only going biso screen only. not go to another screen. what the problem.ple me sir
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 45 Answers
You try to reset your bios at first u remove the cmos battery from motherboard after that you remove the jumper and ram and install it again. so i think your problems is resolve if still u getting same than you please revert back.................
Posted on Oct 08, 2010
Bios password Dell XPS M170 how do you unlock it ???
How to use the jumper to reset the BIOS password on your Dell desktop computer
Summary: If you're prompted for the Basic Input/Output System (BIOS) password at startup (before the operating system loads) or the BIOS or CMOS setup is locked, and you don't know or have forgotten the password, you won't be able to use your computer or change BIOS settings. Use these instructions to reset the BIOS password manually using the jumper.
NOTE: This process will not clear a Windows Operating System password, nor will it clear passwords on a Dell portable computer. This is only to clear System BIOS passwords on Dell Desktop and Mini-Tower systems.
Desktop system BIOS password reset.
NOTE: The BIOS is the program that activates the hardware required to start your computer. The jumper is a small plastic covering found inside your computer.
Before you begin
Perform the safety steps in the order below.
WARNING: These steps are for your personal safety and the protection of the equipment.
  1. Turn off the computer and unplug the power cable.
  2. Wait 5 seconds.
  3. Disconnect all external devices.
  4. Disconnect any telephone or network cables from your computer.
  5. Press and hold thePowerbutton for 10 seconds while your computer is unplugged to release static electricity from the system.
  6. Before touching anything inside your computer, ground yourself with a wrist-grounding strap or by touching an unpainted metal surface, such as the metal at the back of your computer. While you work, periodically touch an unpainted metal surface to dissipate static electricity.
To use the jumper to reset the BIOS password
NOTE: On the DellManualsweb page, download the Setup Guide or Service Manual for your computer. Then refer to the System Board Components section for a labeled illustration of the jumpers on the system board.
  1. Ensure that your work surface is flat and clean to prevent scratching your computer's cover.
  2. With your computer still turned off and unplugged, remove your computer's cover.
  3. To locate the password jumper on the motherboard, look for the letters PWD, PSWD or PSWDCLR.
  4. Choose an option:
If there are 2 metals pins under the jumper
  1. Remove the jumper from the pins, replace the computer cover, reconnect the power cable and monitor and turn on the computer.
  2. After the Windows logon screen appears, turn off the computer.
  3. Again, disconnect the power cable and monitor. Press and hold the power button for 10 seconds to release static electricity from the system.
  4. Remove your computer cover.
  5. Replace the jumper in its original position covering the 2 pins. This will re-enable password feature.
  6. Replace the computer cover.
  7. Reconnect the power cable and other connections and turn on the computer.
If there are 3 pins under the jumper (See figure 1. below.)
Figure 1. Generic motherboard illustration showing a 3 pin password jumper, you motherboard may vary, see the owners manual for you system for specific instructions.
  1. Remembering which two pins are covered, remove the jumper from those pins.
  2. Reinstall the jumper in a different position. For example, if you removed the jumper from pins 2 and 3, reinstall the jumper over pins 1 and 2.
  3. Replace the computer cover and reconnect the power cable and monitor.
  4. Turn on the computer and wait 5 seconds. Then press and hold thePowerbutton until the computer turns off again.
  5. Disconnect the power cable and monitor again. Press and hold thePowerbutton for 10 seconds to release static electricity from the system.
  6. Replace the jumper over the original 2 pins.
  7. Replace the computer cover.
  8. Reconnect the power cable and other connections and turn on the computer.
May 06, 2017 | Dell Computers & Internet
How do I remove administrator password on the BIOS of Optiplex 390
The CMOS contains the current BIOS settings
  1. Turn off the computer and disconnect the power cable from the electrical outlet.
  2. Remove the computer cover.
  3. Locate the 2-pin password connector (PSWD) on the system board.
  4. Remove the 2-pin jumper plug.
  5. Locate the 2-pin CMOS jumper (RTCRST) on the system board.
  6. Move the 2-pin jumper plug from the password jumper to pins into the CMOS jumper.
  7. Plug in AC power to the system and wait ten seconds for the CMOS to clear.
  8. Move the 2-pin jumper plug back to the password jumper.
  9. Replace the computer cover.
  10. Connect your computer and devices to electrical outlets, and turn them on.
Location of the RTCRST Jumper will vary by platform and form factor. For more information about the jumper locations refer to the system service manuals located at www.dell.com/support/manuals
Aug 15, 2016 | Dell OptiPlex 390 DT Desktop Computer...
How can I reset my system password?
Disabling a Forgotten Password
If you forget the system password, you will be unable to operate the system until disabling the password. Disabling the password involves going inside the computer and changing a jumper setting (twice) on the system board.
To disable a forgotten password, perform the following steps:
  1. Turn off the system and remove the cover.
  2. Move the jumper plug on jumper A to pins 2 and 3 to disable the password(s).
  3. Turn on the computer. Powering up the system with jumper A set to the disabled position erases existing password(s). Before assigning a new system password, you must reset jumper A to the enabled position.
  4. Turn off the computer.
  5. Place a jumper plug on pins 1 and 2 of jumper A to enable the password features.
Dec 28, 2012 | Dell Latitude E4300 Notebook
How do i reset the pc to original settings
remove the power from CPU then remove the side covers in the motherboard near the c mos battery you will see a three pin jumper with 2 pin shorted remove them and insert the jumper to the 2 and 3 pin then switch on the computer in some case the computer doesn't work switch off and remove the power and replace the jumper to early position and connect the power and restart the computer this will reset the system to default
Oct 27, 2011 | Computers & Internet
Dell 4700 need to reformat but need to get admin code for the bios. already took bios bat out and unplugged all cords on inside and re-plugged them. got system code, but still need bios admin code is there...
I believe that you need to set up the CMOS jumpers inside the main circuit board. For details click on this link (Click Me)
1. Look for 3 pin CMOS clip that says CLR CMOS on the mainboard 2. Take out the jumpers from 1 and 2 3. Put it in jumpers 2 and 3 and wait for 5 seconds 4. Put it back to jumpers 1 and 2
Figure 1. Schematic Diagram of Main Board Dimension 4700
Thank you for choosing Fixya
Jul 06, 2011 | Dell Dimension 4700 PC Desktop
I have a Gateway computer running Win98 that prompts me for a password at startup. It didn't use to do this, so I don't know what password it is asking for. Never used one! It is doing this after a power...
Somehow, the motherboard thinks that a "start-up" password is required.
If you have a desktop computer, turn the computer off, open the case, and look on the motherboard. Look for three pins (labelled 1, 2, and 3), and look for a small "jumper" that is connecting pin 1 to pin 2. Move the jumper to connect pin 2 to pin 3. Wait 5 seconds.
Move the jumper back to connect pin 1 to pin 2.
Turn the computer on -- the "BIOS-password" will have been removed.
Jul 17, 2010 | Gateway (4000484) Motherboard
NMI ISSUED PRESS ESC TO TURN OFF NMI IN IBM SERVER
dear mugkifa ,
the above error indicates , a non maskable interrupt occurred in your server , there may be a change of malfunction of a hardware ,like add on cards
one more solution in ibm server is disablig the NMI interrupt by using jumper settings (inside motherboard)
see the below mentioned details , may differ with your server series please refer with series on http://www-947.ibm.com/support/entry/portal/docdisplay?brandind=5000008&lndocid=MIGR-5069937
System-board jumpers
The following illustration shows the switches and jumpers on the system board:
migr-5069937_2.gif Note: Any jumper blocks on the system board that are not shown in the illustration are reserved. The following table describes the function of each jumper block:
Jumper Settings CMOS jumper (JP3) Pins 1 and 2: Keep CMOS data (default)
Pins 2 and 3: Clear the CMOS data, which clears the power-on password and administrator password Boot block jumper (JP4) Pins 1 and 2: Normal (default)
Pins 2 and 3: Recover boot block NMI (non-maskable interrupt) switch (SW1) Normal (default): No NMI issued
The NMI button that is on the rear of server, connected to this switch, has been pressed: NMI issued
May 07, 2010 | IBM eserver xSeries 360 8686
Sir, I have Intel D485PEBT2 mother board.Whenever I do a cold start it does not boot.If I do CNTL+ALT+DEL it restart and boots.cmos battery is ok.date and time ok.I tried several times to change Boot...
I would suggest that you do a factory reset on your mobo. To do it, here are the steps you can follow.
1. make sure that computer is OFF and unplugged from the wall
2. locate the 3-pin jumper on the mobo that is near the cmos battery
3. once located, remove the cmos battery
4. then from the 3-pin jumper, if the jumper is connected to pins 1-2, switch it over to pins 2-3
5. return the cmos battery back
6. plug the computer back then turn it ON
7. you will probably get an option to reset or restore settings back to factory, it that's the case, continue with it
8. after doing so, turn the computer OFF again and unplug it
9 remove cmos battery then return the jumper to it's original position
10. put in the battery back then turn the computer on again
11. go to the bios and set it back to the setting that you have set it before
12. check and see if problem has been resolved
* I would suggest getting a new cmos battery if it's already old
Let me know if you need further assistance
Jon
Oct 16, 2009 | MSI MS-6547 Motherboard
Bios password
hi
you will have to reset the bios.open the system unit, locate a small battery, near the battery, there should be a small jumper. pull the jumper upwards, you will get a small square plastic cover. now turn on the pc, and your bios password is reset.
hope it helps
kind regards
Mar 11, 2009 | Intel D101GGC Motherboard
Vertual memory low
You either need to add more physical ram to your computer or delete and make more room on your hard drive.
Feb 22, 2008 | Microsoft Windows XP Professional With...
ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
