Question about Asko D1776 Stainless Steel Built-in Dishwasher
The heater element does not stop when the cycle machine is finish. I need to off plug the electrical wire. Some told me that my control board was broken. Is it possible because they told me that the piece was discontinue. The dish washing machine has been bought in 2003! What can I do
  • Asko Master
  • 2,605 Answers
Hello, Welcome to FixYa. Beased on the description you posted..."The heater element does not stop when the cycle machine is finish. I need to off plug the electrical wire" This is a red flag. In these scenario's 99% of the time the control and thermistor are both at fault. If the component has failed both will need to be replaced...This asper Asko as follows. **When any or several of control unit components or the conductive pattern (copper foil on the soldering side) close to these components are damaged most probably the external component is the cause of failure and should be ohm-measured and in case of short circuit be exchanged simultaneously with the control unit.** Having said this, If you remove the door and control panel and visually inspect the control you will most certainly see burnt circuits, relays or resistors on the control. i.e. The heater element does not - 249be30.jpg The thermistor wires are the 2 gray ones to the right of my finger in the photo. You can measure it`s resistance here.
The thermistor controls the water temperature to give the required temperature. The heater will be disconnected if the thermistor is short-circuited or loosened from the circuit board...unless of course the control itsrlf is faulty, such as a stuck/faulty relay.
The normal resistance of the thermistor is beetween 25 and 15 Kohm at (20°C), 68°F, or (30°C), 86°F alternately.
The actual thermistor is located on the bottom of the tub...check the wires going to it along the door for any severed/shorted signs or the thermistor iteslf where it fastens to the tub.
i.e.
this is the best image I could provide considering it`s location under the tub
It`s true the controls may not in fact be available as new, however I would suggest you do some on-line searches for original Asko number 8057931-4, If that fails, you can contact me a macmarkus@live.ca and I`ll see if I can find you one.
The thermistor is original Asko number 8059767 and is still available from "repairclinic.com" for about $23USD.
It`ll look like this...
Let me know what you find or if you require further assistance. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Oct 08, 2010
Model SHE7PT55UC. What does error code h:13 indicate?
Hello. From what I've been able to glean from the net(and I have extensive information on a large amount of appliances), the error code might pertain to the heater circuit. You need to check(with power disconnected) continuity of the heating element, any thermal fuses inline with the heater element, and also, when the heater is supposedly activated, is there 120 volts being applied to it(if not, an inline thermal fuse or, if good, the main control board might be faulty). If you are hesitant about checking any of these items, definitely call for service!
Nov 24, 2015 | Bosch Dishwashers
Hello... I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called Frigidaire. They said it was likely a shorted wire and put me in contac
http://www.manualslib.com/manual/417069/Frigidaire-Fase7073lw.html
you can read the error code E61 here
it says its a heater control relay or the heater element is duff
its prob corroded and worn out and needs replaced
"Check for short circuit across heater relay(s) (RL5, RL6, RL7)
or L1 applied to heater relay output(s) (J5-2, J7-1, J7-3)
with cycle stopped. Check for open circuit between L1 and heater relay connection(s) (J5-1, J5-3, J7-2).
If no wiring problems are found, replace Electronic Control Board and retest"
you can download the schematics etc also in the same manual
i think you need a tech too look at the heater now you know whats up
Dec 20, 2014 | Frigidaire Dryers
I have a lg gromm dryer and it dosn't get hot when drying why?:
I suspect that either the heating element is malfunctioning or the control board is. Sorry but either will mean an engineer's visit ;-0(
Sorry again,
Good luck,
John C
Mar 25, 2011 | LG Washing Machines
Our 4 year old Asko D3121 dishwasher has stopped heating the water and drying off the dishes..is the problem as simple as replacing the heater element ??? If so ,how difficult is it ?
I would check the voltages around the heater before replacing it. Sometimes the thermal overload relay opens out and shuts off the power. Could be a more simpler to replace than the whole heater.
Jun 29, 2010 | Asko 24 in. D3121XL Free-standing...
My dryer is no longer heating up and it does not time out, what parts would i need to fix the problems?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug
Whirlpool style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 27, 2010 | Whirlpool GEW9250 Electric Dryer
Bosch dishwasher SHX46A -cycle runs too long (4 hours)- items still wet. The economy cycle also runs too long - should be about 80 minutes and it ran for 200 minutes.
It sounds like there's a problem with the dishwasher's heating element. The dishwasher uses the heating element to heat the water to certain temperatures, and it will wait (run for extra time) for the water to reach this temperature, and may eventually give up. When it's time to dry, the dishwasher uses the heating element to steam dry the dishes. If you're not technically savvy, you will probably need to have a pro work on the machine, but first check to make sure there's not hard water scale buildup on the heating element. If you're brave enough to work on the machine, you should check to see if the element's plugged in, check its resistance to make sure it conducts electricity, check the element's switching components, and finally the dw's computer board. There's a chance that the machine is just stuck in a loop or something. You should try turning off the circuit for a few minutes. There's a chance it may reset and start working.
Dec 07, 2009 | Bosch 24 in. SHX46A05 Stainless Steel...
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
Hotpoint WT960 Fault F-07 heater relay
A few reasons for this, faulty heater, broken wire, faulty pressure switch or faulty main control board (the heater relay is on the main control board).
There is no reset for this.
Unplug the appliance and take the rear cover off.
Check the wiring to the heater and thermostat. Give the wires a good tug as they can break internally and look ok.
If you have a multimeter, test the heater, it should read around 25 ohms.
Take the top off the appliance, locate the pressure switch (has a thin tube on it), give it a few good taps with your screwdriver handle.
Finally, take the main control board out (bottom left when viewed from the rear) and one plug at a time, take them off, clean and tighten them, plug them back on.
If everything checks out ok, then it's likely the main control board is at fault.
Good Luck!!
Thanks
Nov 09, 2008 | Hotpoint Aquarius WD63 Front Load...
WASHER STOPS AFTER A FEW MINUETS INTO THE WASH CYCLE
you didn't say if the machine had filled up with water and stopped after that, if that is so then the place to check first is the heater element for open circuit, this will be located at the bottom end of the drum area, remove plug before testing, work safe, hope i have helped a little, if the machine has not finished filling check the water supply first then the water solenoids. hope i have helped, if so rate me please
Sep 12, 2007 | GE WBSE2090A Top Load Washer
Asko D1776 Stainless Steel Built-in Dishwasher Logo
246 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
