Question about Laser Logitech O - V550 Nano Cordless Mouse - Grey
I dropped my mouse and lost control of the wheel used for scrolling ... is there a fix for this?
Scroll wheel stopped working. It feels weird now when i try to scroll it. How do i fix it?
Disconnect the mouse from the computer and turn it upside down. The screws to disassemble the mouse are under the pads on the bottom of the mouse. When you disassemble the mouse, you will find that the scroll wheel axle is gummed up, and the interruptor wheel is probably dirty. Use an old tooth brush and alcohol to clean the scroll wheel components, and let the components dry. You can use glue to re-attach the pads after you have reassembled the mouse.
Sep 05, 2015 | Universal AULA Ogre Soul Professional...
How to fix how much the wheel scrolls
If you are a windows user then follow the below steps:
Click on Start Menu
then select Control Panel
in the control panel select the Mouse option
and when you double click on Mouse a new window will pop up
on that window click on WHEELS
and there you can set the desired scrolling with mouse wheel.
Thank You
Aug 28, 2012 | E-Machines Computers & Internet
All things on my imac desktop is bigger by 2x
You may have
- Adjusted the screen resolution inadvertently (go to the System Preferences > Displays panel to fix this, adjust the screen resolution to a higher setting, i.e. toward the bottom of the list)
- Inadvertently used "screen zoom" by holding control and doing a scroll with the mouse trackball (or a 2-finger scroll with the mighty mouse). To fix this, try holding control and scrolling the mouse's scroll wheel down. (Or swiping downward with 2 fingers on the mighty mouse if you are using one of those)
- Accidentally adjusted the size of the icons in the finder. You can fix this by going to the finder (click the desktop) and hit command J (or just go to View > Show View Options). This will allow you to adjust the size of the icons on the desktop, or any other window.
Oct 14, 2010 | Apple iMac 24" Desktop
I have a gateway laptop. At times I have a little wheel that can be used anywhere on the screen to scroll up and down and then it seems to quit working and I have to use the slide bar on the right side of...
Go to the control panel and set up your mouse. If this doesn't fix the problem, take the mouse apart and blow the dust out where the wheels with slots are. There is a small eye that detects movement in the wheels. If that doesn't fix it, the mouse needs replaced.
Aug 08, 2009 | Compaq Presario CQ60-220US PC Laptop
Arc Mouse wheel faulty... but only when scrolling up
I repaired mine following this link, very useful:
http://dompruitt.com/2008/11/24/fixing-the-scroll-wheel-on-the-microsoft-arc-mouse/
You will new a small philips and thors screwdriver plus masking or painter's blue tape.
Good luck!! :)
Jul 03, 2009 | Microsoft ARC Mouse
Imprecise scrolling
go to control center, mouse properties, use the wheel-tab, and set lines to scroll to 1.
Jun 03, 2009 | Logitech Cordless Mouse
Mouse wheel scrolling has changed
try control panel settings for your mouse
Apr 03, 2009 | Computers & Internet
Scroller goes up when scrolling down
This works for all mice.
click the scroll button and movie it up and down for a while and it will work just fine.
i had the same problem with my acer mouse but when i looked at a forum for the mac os x mouse someone said this tip and it worked
Oct 27, 2008 | Dell U0636 Mouse
My mouse is wheel is not functioning right
You need to determine if it a software or hardware issue. Check the mouse settings in control panel under the wheel tab (mine is set to 3 lines at a time). Do you have access to another wheel mouse to try? A new mouse is not expensive. If the scrolling works on another mouse the the wheel is defective.
Jul 20, 2008 | Dell U0636 Mouse
Laser Logitech O - V550 Nano Cordless  Mouse - Grey  Logo
56 people viewed this question
Top Laser Computers & Internet Experts
Robin Hill
Robin Hill
Steve Sweetleaf
Steve Sweetleaf
Are you a Laser Computer and Internet Expert? Answer questions, earn points and help others
