Question about Samsung Cameras
Cant turn it on or off the screen say R1 - Samsung Cameras
  • 231 Answers
Dear sir
this is the problem usually caused by viruswhich happens when you are receiving files from p.c or untrusted cameras and sometimes it might be software failure also, which causes some of the menu not tofunction,the only solution is to flash ur phone software from the nearest samsung care,it also updates your cam software also
thank you.....take care................
Posted on Oct 08, 2010
Tip
Medal of honor- Airborne (CHEATS)
Codes
Enter these codes while in a level without pausing. Enabling any cheats removes your ability to save your progress!
Effect-Code Entry Screen
  • Hold L1 & R1, then enter Square, Circle, Triangle, X, X
Health Restore
  • After entering the "Code Entry Screen" Code, release R1 & L1, Hold R1 & L1 down again and enter Triangle, Square, Square, Triangle, X, Circle
Infinite Ammo
  • After entering the "Code Entry Screen" Code, release R1 & L1, Hold R1 & L1 down again and enter Circle, Circle, Triangle, Square, X, Triangle
on Apr 23, 2011 | Video Game Consoles & Games
What is the unlock all for dirt to Daytona
At the title screen after the press start screen you will see three lines of text on the right. Enter the following combination: R1, R2, R1 Left, Right, R1, Down, Down. The text will disappear then reappear, confirming the code. This will allow you to select from any of the unlockables on the following menu screen.
Jun 18, 2014 | Sony PlayStation Video Game Consoles &...
2000 r1 boots on carb wont fit
Hi, Gene you may have the wrong ones for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2000 2001 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Yamaha R1 Performance upgrade 1
Yamaha YZF R1 02 03
Mar 23, 2014 | 2000 Yamaha YZF-R1
How to remove key from gas cap after removed
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/46-how-tos/144585-how-remove-gas-cap-no-key.html
http://www.r6messagenet.com/forums/r6-maintenance-technical/55318-how-do-i-get-key-out-gas-cap-once-off-tank.html
https://r1videos.files.wordpress.com/2011/04/2002-2003-yamaha-r1-service-manual.pdf
Oct 02, 2012 | 2003 Yamaha YZF-R1
No spark on my 2001 yamaha r1
Hi, Anonymous and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and CDI box.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose, check for spark leakage in the dark.
6. Faulty ignition coil, pick up coil, trigger coil or CDI box testing needs to be checked with an ohmmeter at 70 degrees Fahrenheit
7. Faulty safety switches clutch, kickstand, neutral, off/on etc.
8. Faulty ignition switch.
http://www.r1-forum.com/forums/102-00-01-r1-mechanical-help/254361-2001-r1-no-spark.html
How to diagnose no spark situation on motorcycle
May 06, 2012 | 2001 Yamaha YZF-R1
Need to reset rev limiter light, cant find my owners manual
Hi, Tom for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
setting rev limiter light Yamaha R1 Forum YZF R1 Forums
2005 Yamaha R1 Shift Light Adjustment
2004 2005 Yamaha YZF R1 Service Manual R1 Moto Data Project
Feb 04, 2011 | 2005 Yamaha YZF-R1
2001 yamaha r1 vacum diagram
Can u email me a drawing. I have a 2000 r1
Dec 17, 2009 | 2001 Yamaha YZF-R1
Ignition, electrical noise
does it have a fuel pump ?...it could be just priming itself..when the pump is already full you cant really hear the noise that much. Does the noise go away after riding for awhile and then restart it?
Sep 29, 2009 | 2005 Yamaha YZF-R1
Ps2 spiderman 3 cheats
Mick and Matt, to get to the cheat menu on spiderman 3 wait for the main menu. Hold r1 r2 l1 l2 at the same time.
Cheers.
Feb 21, 2008 | Sony PlayStation 2 (PS2) Console
Cameras Logo
49 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
