The fuse and fuse holder fell out of my behringer euro power pmp2000 amp where can i get a new fuse holder
    Sergeant:
  • 198 Answers
Try googling the brand name to find the manufacturer, they'll have the fuse and holder. you can also try going to an electronics supply house, they'll be able to help you also.
Posted on Oct 08, 2010
Behringer Fuse Holder for B212A
I realize this is an old question, but if anyone else has the same query, from page 6 of the manual listed below, the fuse holder is located on the back panel between the power on switch and power socket. For use on 120v supply, 5 amp/250v. For use on 240v, 2.5 amp/250v.
-Steve
http://www.behringer.com/assets/B212A_P0261_M_EN.pdf
Oct 24, 2013 | Behringer Eurolive B212A Speaker
I need to know where can I purchase a fuse for Behringer PMP2000 10 Channel Mixer
If the fuse blew, you ARE going to need a lot more than a fuse as the cause is usually internal damage to the amp module and or power supply. Replacing the fuse without repairing the cause USUALLY causes more damage.
Oct 09, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
My band plugs into the input channels on the SX2442FX mixer, which we then hook up to the PMP2000 to use as a PA. Since the SX2442FX is not a "Powered" Mixer, I figured that we should be going...
Either way will work, however your friend's method probably would be slightly better since it goes through less stages within the PMP2000. The "left and right power amp inputs" are the INPUTS to the power amp in the PMP2000 and hence are the best places to connect the mixer if using the PMP2000 as only a power amp. Note doing this will LIKELY disconnect any other input to the PMP2000 from the power amps in it... that is all the preamps in the PMP2000. DO USE TRS cables!!! and power both units from the same receptacle to avoid ground bounce.
Aug 25, 2011 | Behringer Sx2442fx Eurodesk 24channel...
Behringer Europower PMP2000 Fuse keeps blowing when the amp is switched on.
For goodness sakes do NOT replace the fuse... doing so causes more damage inside. Likely one of the power amps has shorted and may have damaged the power supply as well. Also please read my tip on Fixya regarding a HAZARD with channel A if you use 1/4 inch plugs with the speaker cables. Essentially the sleeve of the channel A plug is the hot, and not the tip. Ground the sleeve of the plug and you can blow the channel A amp. YOU WILL NEED TO TAKE THE UNIT IN FOR REPAIR... THIS IS NOT A DIY REPAIR!!!!
Aug 23, 2011 | Behringer Rx 1202fx 12 Channel Line and...
My europower pmp 2000 powered mixer wont turn on and the fuse appears good. I turned it on and it immediately turned off ,nothing smells burnt. any ideas on what it could be
This is likely a power supply failure, possibly brought on by a failure of one of the amp channels.
This is probably close to your supply:
http://elektrotanya.com/behringer_sps600_power-supply_sch.pdf/download.html
Scroll down to "get manual" and click on that to download schematic. Ignore other download links.
Aug 05, 2011 | Behringer Pmp2000 Europower 800w 10ch...
Hi I have a behringer europower pmp2000 I've just got the back panel back from the shop after having a new fuse and holder fitted. The trouble is I've lost my wiring diagram to re-attach the back panel,...
If those green wires have eye connectors on their ends, that indicates chassis grounds and should be put under one of the mounting screws on the board. you should be able to get a diagram from Behringer's website.
https://grounenimex.files.wordpress.com/2015/11/behringer-pmp2000-schematic-diagram.pdf
Jun 27, 2017 | Audio Players & Recorders
Fuse and fuse holder needed for Behringer 3000 pmp mixer
Try this Behringer support:
BEHRINGER USA, Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
Fax: +1 425 673 7647
I just repaired a PMP3000.
A bit of warning on these. Do not let a speaker leads get pulled while powered. They can arc out the power amp causing extensive damage.
If the fuse ever blows do NOT replace the fuse as much more damage will result. Service the unit before using.
May 12, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer pmp2000 europower no sound
Probably the power amp has arced and popped a lot of components.
When teh amps go usually the final pwer transistors, their drivers and sometimes even the power supply gets zapped.
Check the output of the preamp at the inserts for the final amp with headphones to see if anything is coming through.
Jan 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
121 people viewed this question
 Grubhead
Grubhead
