Question about RCA F36650 36" TV
RCA F36650 36" TV
Makes high pitch squealing noise when i turn it on
  • Bigdikbstrd Jun 28, 2008
    when I plug it in it makes a load whinning noise its weird because the thing worked fine an hour before
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Is the squealing noise from the back of ur set , if so it is ur flyback transformer
Posted on Jun 28, 2008
My tv makes 3 even high pitched squeals when i turn it on. about 1 second each, then powers off. No picture no sound. All imputs. What do you have for suggestions on what it could be.
One of most two common reason why your set will not come on, is because it has lost the high voltage, the first thing to check is your horizontal output transistor, to see if it is shorted, it will be located bay the flyback, mounted on a metal heat sink. That is what is causing a squealing noise.
Oct 16, 2010 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
Trouble turning on tv. High pitched noise/click.
The mainboard might have some loose components, or cold solder , or may be the filter capacitors are becoming faulty. Yes it is worth repairing, bring it to the repair shop. Cheers.
Nov 25, 2008 | RCA Televison & Video
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
Squealing noise
a shop will need to do the repairs on the tv..its not something a novice shouldd try to repair
Aug 29, 2008 | RCA P52926 52" Rear Projection Television
52 in RCA widescreen HDTV Monitor
high pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
Stopped working and squealing sound
Your set is shorted circuit condition. The power supply is making the noise. Unfortunately almost any of the hi current circuits will do this. If picture went out 1st look for video or hi voltage problems.
Jan 11, 2008 | RCA 32F531T 32" TV
High Pitched Noise on TV
THIS NOISE IS NORMAL. IS THE DEGAUSING COIL
Sep 16, 2007 | Televison & Video
RCA F36650 36" TV Logo
302 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
