Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Red light hello screen goes blank. red light flashes 5 times then turns on what can it be, and how can i fix it? please advice luis
    Sergeant:
    Champion:
  • 326 Answers
according to the Service Manual - lamp driver is defect. Replacement of lamp driver will fix the problem.
Part number is 146887511. Please contact your nearest Sony Dealer.
If you want I can send you the Service Manual. Please send your email address.
Best regards,
Arpi
Posted on May 31, 2008
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Red flashing light
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 17, 2013 | Sony Televison & Video
My TV was working and then all of the sudden the screen went blank and now there is a flashing red light that appears. I tried to turn everything off and back on (the universal solution to everything) but...
Hello
There is something confusing the system control of your TV and it should me resetted. To reset it, just switch OFF your TV with its front panel power control switch, and after that, unplug the TV from the wall socket. Wait for about 5 minutes or so, and the plug it and switch It ON. If this does not work for the first time, give some more time to reset, say about an hour or so, and try. OK.
Jan 29, 2011 | Philips 37PFL5332D 37 in. LCD Television
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
PICTURE ON LCD TV GOING IN AND OUT
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
when your tv blanks out, turn off the tv and then it back on. below the power button usually flashes green light. does yours flash red? if so you need to count how many flashes. the number of flashes will help in resolving your problem. then google red flashing light sony and you will find what the red flashing lights mean.
Oct 04, 2008 | Sony KDF-E55A20 55 in. LCD Television
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
I'VE OWNED A SONY WEGA 27" FLAY SCREEN T.V.FOR A YEAR AND A HALF AND NOW FOR THE SECOND TIME THE THING WONT TURN ON. ALL ITS DOING WHEN I PUSH THE POWER BUTTON IS MAKING THE NOISE OF TURNING ON BUT...
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
Jan 16, 2008 | Televison & Video
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
