Question about Cameras
My green and red button s not working and wen i ever click tat button my handset is hanging
  • 231 Answers
Dear sir
this is the problem usually caused by viruswhich happens when you are receiving files from p.c or untrusted mobiles...... and sometimes it might be software failure also, which causes some of the menu not tofunction,the only solution is to flash ur phone software from the nearest service centre,it also updates your cam software
thank you.....take care................
Posted on Oct 08, 2010
Getting bored from Nokia C5-03 touch screen Hang problems & display related problems
Hi @Jayeshsinh DO this steps:
>Check your phone, that is it on.
>Hold and press Green handset + Red handset + Camera key.
>Release holded keys, when you see Nokia logo.
>Now tap your lock code. (The default lock code is 12345).
After this operations your phone will reset and maybe restart.
OR
>Press Power button, until your phone turns on.
After that press Menu button and goto Settings -> Phone -> >Phone management -> Factory Settings -> Delete data and restore.
>Confirm your decision -> press Yes.
>Done
Oct 29, 2017 | Nokia C503 Cell Phone
How do I turn off the blinking lights on my DTU-8D-2(BK) Telephone
Unplug the line cord. While holding down the * and # keys, plug the line cord back in. Release the * and # keys.
Follow the directions on-screen, which will test all display modes, buttons, and sounds for both red and green colored LEDs.
If the feature button continues to flash, press it and then lift the handset and hang up.
Sep 09, 2011 | NEC DTU 8D-2 Corded Phone
Wen i use in my pc mp3 is playing...wen use no data can help 4 me solve tat problm pls..
It is likely starting up when you computer is turned on. Follow these steps to get to your startup folder and disable anything you may not recognize:
Change Current Startup Programs
  • 1
    Click the Windows "Start" button and type "msconfig" in the search text box. This opens the System Configuration console.
  • 2
    Click the "Startup" tab. This gives you a view of all the programs installed as startup options on your computer.
  • 3
    Check boxes of the applications you want to start when you boot the computer. For programs you no longer want to start, clear the check box.
  • 4
    Click "Apply" and close the configuration window. A popup window will ask if you want to reboot the computer. Click "Restart" to reboot the computer and save the changes.
  • Mar 07, 2011 | Computers & Internet
    My pc is cut off automatically some times (not shut down) jus cut offed like wen current is not their it will cut na like tat!! after that i need to start again
    most probably cooling problem.
    check the cpu fan ..is it working?
    or might be cpu fan not sitting properly upon the the processor.
    when the processor gets over heated it just cuts down or hangs there itself.
    Feb 09, 2010 | PC Chips P23G Motherboard
    I want to regieter my china mobile handset IMEI
    yeh kumari go to dual sim settings n chk tat both sims are open if not set tat option or else sim reader pins might gone dead or cut or broken chek tat also....
    Nov 03, 2009 | Cell Phones
    The Power Light is Red
    yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
    Per user manual:
    Solid red - power off (standby mode)
    blinking red - power off (now cooling)
    blinking green - power on (preparing to light lamp)
    solid green - power on
    Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
    Phones won't pick up calls...say connecting
    HOLD THE HANG UP BUTTON AND THE POUND BUTTON DOWN FOR 5 secons. select base unavailable....yes. then hang it up on the base and it will register to the base. if that doesn't work then unplug the base then plug it back in then put the reciever on the base.
    Nov 20, 2007 | Uniden TRU9380-2 Twin Phone
    MEMORU CARD CORRUPTED
    try by restoring handset once a time or else memory card is corrupted..change it....
    Oct 18, 2007 | Nokia N70 Cellular Phone
    Cameras Logo
    13 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
