Question about Gateway MX6920 Notebook
Determine if hard drive is bad and if so, a replacement purchase
My laptop is just over 1 year and it boots up to where it states, select F2 or F10 and when you select one of these, nothing happens. The o/s will not load.
I suspect it may need a new hard drive. It came with a 160GB. Do you think the hard drive is the issue? If so, where can I purchase a replacement. I live in Boca Raton, Fl. Thanks.
I could not find my model MX6956 PC Notebook on your list.
    Problem Solver:
  • 19 Answers
F2 should take you to the BIOS whether the hard drive is bad or not, so if you cannot even get into the BIOS, you have other problems that are preventing the system Posting.
I would suggest that you email Gateway's support as they may be able to give you some options to try.
https://support.gateway.com/support/contact/contact_tech1.shtml
They also have some online self help tutorials available here
http://support.gateway.com/s/tutorials/index/Tutorials.asp?cat=2&CatTitle=PC%20Hardware&subcat=10&SubTitle=Laptops&topic=217&series=2281
Posted on May 29, 2008
    Problem Solver:
  • 27 Answers
This doesnt sound as if the Hard Drive is faulty, This actually sounds like a System File Corruption, Most Likely you will need to format your Computer and reload the OS, This can be abit tricky if you havent done this before, But its better than Throwing out a Good Hard Drive and Reloading the OS on a New one.
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Took acer 6733Z-4633 to tech. it wouldn't boot up. he said hard drive bad. he was able to save pictures and some files to USB. now I need to replace hard drive. sent for Acer recovery discs. if I cant...
when your laptop starts if it has F12 option push that and install your first disc and choose boot from cd player then follow instructions
if you dont have the F12 option when you puch the power button toggle the F2 key and go to boot menu and choose the cd player as first boot option and then hit F10 and save install boot disc and follow instructions
Aug 18, 2013 | Acer Computers & Internet
Samsung hd154ui hard drive - cannot format above 1 TB says 500gb available but does allow one to create a partition
The drive has developed some bad sectors on it
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
or you could download partition magic
when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 Partition Magic 8.0
note: after you loaded your operating system you will have to change the boot order back to your hard drive
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
http://www.filehoo.com/download/Partition-Magic-8,0.aspx
Hope this helps you
Apr 06, 2011 | Samsung 1.5TB F2 HD154UI/Y HDD EcoGreen F2...
I want to boot my toshiba sa50-543 laptop from pen drive
While starting system U will find message on task bar that press F2 to boot.Then press F2 while starting the system.U will find blue screen in DOS mode stating boot order.Select boot order as USB insted of CD ram driver.Then save by pressing F10.Then insert USB drive to USB port2.0.Automatically it will boot O/S from USB drive
mohanraojagan@yahoo.com
Nov 07, 2010 | Toshiba Office Equipment & Supplies
I dropped my notebook about 5 feet about and when i booted the message was operating system failed.
First thing to do is determine the health of the hard drive. Enter the laptops setup on boot and see if the BIOS has a hard drive test utility. When you boot the laptop, look at the screen and find the function key (F10, F2, F12) that you will need to press to enter the BIOS. After that, look through the menus related to the hard drive and see if a test is in there.
Oct 27, 2010 | Gateway T-1625 Notebook
Hp pavilion a530n will not boot for cd it says not hard drive found reboot and select proper boot device or insert boot media in selected boot device
Need to set it to boot onthe CD drive.To boot on CD drive;
1-at start up press F2
2-At BIOS select BOOT option and move the CD drive to the fist option using the keyboard arrows.F10 to save and exit.
Oct 26, 2010 | HP Pavilion A530n (DW234A#ABA) PC Desktop
Compaq presario 2199us notebook does not boot
Hi Krishna. Could be that the processor's cooling fan is no longer functioning and then the processor instantly overheats and everything STOPS !!! Could be the RAM memory chips not in good state anymore .....Could be that (while it tries to determine what hard drive is in there) the hard drive is BAD and cannot be identified... that would also just STOP everything. It really is quite a few things that could cause that
Jul 06, 2009 | HP Compaq Presario 2200 Notebook
Can't boot up my HP XE4100 laptop
press hard disk and boot the windows
Apr 01, 2009 | Computers & Internet
Booting Problems When Western Dig. USB Hard drive is Connected
Your laptop will be set to "boot from USB first" in the BIOS. Go into the BIOS (F2, F10 or DEL key as stated on startup) and look for the boot order options.
Change it to boot from the internal hard disk first and all will be sorted.
Feb 06, 2009 | Acer Aspire 5100 Notebook
Got a laptop (ei systems) that i cannot properly start up, and access vital information which i just cant lose (court stuff etc). When computer turns on it say Boot device Hard Disk C / ...
try to boot your laptop from hard disk
reset your laptop & press f2 or del to go in cmos setup by press f2 or del key then afer go in boot manu select there is hard disk in a frist boot divice then save the settings by press f10
try this
may your problem will solves
Mar 23, 2008 | Computers & Internet
Gateway MX6920 Notebook Logo
534 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
