Have no disk for my advent bluetooth dongle - Computers & Internet
  • 50 Answers
Go to driverguide.com
Posted on May 29, 2008
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
BLUETOOTH - Advent Roma 2000 - How do I turn on my bluetooth? I have the drivers/software but is there an easy way 2 turn this feature on?
BLUETOOTH - Advent Roma 2000 - How do I turn on my Problem with the Advent Netbook PC Notebook BLUETOOTH - Advent Roma 2000 - How do I turn on my bluetooth? I have the drivers/software but is there an easy way 2 turn this feature on? - By kellyashby79 14 minutes ago
Oct 12, 2011 | Advent Netbook
Sir i want to install a bluetooth facility in my laptop it is accer/emachines e727
The easiest way is to purchase a bluetooth dongle for your usb port. I use one myself- generally the install just involves running the drivers disk then inserting the dongle. I would personally recommend using one of the micro dongles that does not stick that far out from your system- I have broken 2 longer form factor adapters by having them get bent!
Oct 03, 2010 | Computers & Internet
Does my advent 7111 have a bluetooth device and if so, how do i turn it on? Or...can i install bluetooth on this laptop?
This lapotp doesnt have bluetooth I'm afraid, the newer Advents do. Best bet is to buy a USB bluetooth dongle which only costs a few pounds and you can pklug it into any USB port and be running within seconds
Jun 27, 2010 | Computers & Internet
The Bluetooth on my Advent Milano Netbook won't work, it doesn't pick up any bluetooth devices and other bluetooths can't find it
advent milano has bluetooth software but you have to buy third party hardware to plug in for it to work.
Nov 07, 2009 | Advent Netbook
Bluetooth won't work on Advent 5431
This model is not bluetooth enabled but yoy can buy and install a blurtooth adapter (dongle)
Once the adapter is inserted to an available USB port the appropriate drivers are installed
You can now access the bluetooth device from the control panel and get connected to any bluetooth enabled device
Jan 13, 2009 | Computers & Internet
Aspire 3000 laptop
Normally you setup a passkey or use 0000 or 9999 as a passkey.
The question is, does that pop up when you try to connect a USB device? Do you get that when you try to install the dongle? (That shouldn't happen). If you are trying to connect a PDA or cell phone, you setup the passkey for the connecting device on the computer then type it in to the PDA or mobile phone. If you are trying to connect a bluetooth headset, then you use whatever code is from the manufactorer. Normally this is 0000 or 9999.
Hope this helps!
Oct 18, 2008 | Adapters.com Bluetooth USB Adapater, USB...
I am trying to install a Nikkai Bluetooth Dongle on my laptop which is Advent with Windows Vista. Everytime I try to install it keeps telling me error 267 what do I do?
Error 267 relates to registry errors.Scan your computer with free Registry scan to fix the errors and remove your junk files.
Jul 14, 2008 | Computers & Internet
Advent ade-ad2 keyboard an mouse problem
do you have an Infra Red device that is installed on your main PC. Because most laptops have infra Red devices and as well with bluetooth connectivity to function your wireless keyboard and mouse.. Go to my computer icon, right click on it then left click properties then go to device manager then check for additional devices.
Jan 21, 2008 | Computers & Internet
Problem with my bluetooth dongle
Do you have tried to uninstall the drivers from the bluetooth dongle?
Uninstall the bluetooth, then try in other usb port.
It could be some problem whit the driver
Nov 09, 2007 | 11Wave amb-1101 Bluetooth Wireless Adapter
Computers & Internet Logo
David Payne
David Payne
