Question about Acer Aspire 3680 Laptop
My acer aspire 3680 could not power on by bat and adaptor
  • 2,567 Answers
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Oct 08, 2010
2 Suggested Answers
crashmech
  • 67 Answers
SOURCE: All Drivers for Acer Aspire 3680
here are all the drivers for this model
click here
any more problems email me.
Posted on Sep 27, 2008
My laptop is Acer Aspire 4520. It is only charging when it is off. I can use the laptop until the charged battery goes low bat and it will shut down. But when I use it with a Power adaptor, it always goes...
If your adaptor is not supplying enough current, it won't be able to run the laptop and charge at the same time.
Try a new adaptor. Cheap as anything on ebay!
Jan 07, 2011 | Acer Aspire 4520-5582 Notebook
BROKEN POST FOR POWER ADAPTOR GOING TO BOARD.IS THE CIRCUIT BOARD REPLACEABLE OR CAN I REPLACE THE POWER BLOCK PART? ACER 3680 - 2007 MODEL
If the pin on the power socket itself has broken, then you are in luck because Acer uses a satellite board for its power to the motherboard, so no soldering is needed. I'm including a link below for a replacement board to get you back up and running.....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280408569438&ru=http%3A%2F%2Fshop.ebay.com%3A80%2F%3F_from%3DR40%26_trksid%3Dp4712.m38.l1313%26_nkw%3D280408569438%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
Oct 14, 2009 | Acer Aspire 3680 Laptop
ACE ASPIRE 3680, LAST WEEK I WENT TO TURN ON THE COMPUTER BUT IT DOESNT TURN ON, I CHECK WIRE, PURCHASE A NEW WIRE, BUT STIL THE SAME PROBLEM, WHEN I PUSH THE BOTTON TO TURN ON, YOU SEE THE GREEN LIGHT BUT...
hello! most comon reason for this is the BAT, the voltage is very low to run the machine I suggets connect the power and dont put on the machine let the bat be charged for ie 2-3 hours .
Second troublshooting open the back where the RAM are remove them from the slots and put them back again then turn on the machine .
ur machine should operate like normal
good luck dude
bye
Sep 08, 2009 | Acer Aspire 3680 Laptop
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
Acer Aspire 3680 laptop. Computer is not getting power
If the power adapter light is not on, even when not connected to the computer, you have a bad power adapter.
You can find additional troubleshooting tips here:
http://www.shopbysystem.com/blog/?p=21
Aug 07, 2009 | UltraLast ULAC3660L For Acer Aspire...
Looking for drivers for acer aspire 3680 2022
have you check the manufacture website for the dirvers
Dec 30, 2008 | Acer ASPIRE 3680-2022 Notebook
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Pin stuck in power adaptor
It is broken, you are going to have the DC jack replaced.
Dec 27, 2007 | Acer Aspire 3680 Laptop
Possbile battery
It could be a battery fault, have you tried it without the battery?
Sep 07, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
126 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
