Question about Nikon DSLR D90 Digital Camera
In the past when film was still king and I was using it I had always used a UV or a Polarized lens cover. Now in the DSLR world I've been told that I should not use a non rated DSLR lens cover. Is there something out there that I should know???? Rick
    Novelist:
  • 88 Answers
I think what you are referring to is the difference between coated and non-coated UV filters. In the old days of film, simple UV filters were fine and reduced haze while protecting the lens glass. The newer and much more expensive multi-coated UV filters do the same thing, but are also said to protect against ghosting and flare in digital cameras and lenses, which tend to be more sensitive to that issue. I've used both on my DSLR, and the answer as to whether the more expensive coated UV filter is worth the money: it depends.
Posted on Nov 25, 2010
    Brigadier General:
  • 3,006 Answers
Without specific reference to the D90, the following applies to almost all dSLR's: Skylight filters (UV) are fine, but avoid using auto white balance. Polarisers can prevent the autofocus system from working, but the more expensive circular polarisers are usually OK although don't produce quite the same effect as linear polarisers.
Posted on Oct 08, 2010
I have just purchased polaroid lense filters polaroid say they are compatible with Nikon d90 but I cant get them on do I need something else to attach them
Filters must be the right size for each lens. For example the 18-105mm kit lens that comes with most D-90 kits uses a 67mm filter. They thread into the main lens. It is always safer to put a clear or UV filter on your camera lens to protect the expensive lens glass. You can thread another type of lens onto it as easily as you can your base lens. Be sure and do not force a threaded lens filter onto your lens or you will damage the expensive lens. It should thread on easily and do not over tighten it.
Dec 12, 2014 | Nikon DSLR D90 Digital Camera
I have a wonderful old sigma 79- 200 mm macro lens which i i used on a 35 mm film camera. I dont think i will ever be able to afford a digital setup with a lens like this so was wondering if i should get a...
What lens mount do you have on the lens? In other words, with what make film camera did you use the lens? A DSLR from the same company should be able to use the lens.
Oct 16, 2013 | Sigma 18-200mm f/3.5-6.3 DC Lens for...
Will the Quantaray 49mm to 55mm step up ring work on a Sony a100 DSLR camera
The step-up ring will on any lens with a 49mm filter thread, regardless of the manufacturer. The easiest way to find out whether it works with any given lens is to see whether the ring fits onto the front of the lens (you could also read the filter size written on the lens itself).
If it doesn't fit, purchase the appropriate step-up ring. That will be much cheaper than buying a whole new set of filters.
If the new lens(es) have a 55mm filter thread then you don't need the step-up ring at all. The filters will mount directly onto the lens.
Mar 17, 2013 | Cameras
I heard that its not enough to wear dark glasses to protect your eyes from the sun. You need special lenses. Is that true?
yes you need to get polarized lenses not just dark glasses if you want to protect your eyes from UV rays. This is also true for children as the harmful impact of UV rays builds up over a lifetime and is not just something that affects adults.
Feb 13, 2013 | Health & Beauty
Can you use the twist-barrell zoom lens on a Sony DSLR camera (or any DSLR) when the camera is set to auto-focus? I've been told that this damages the gears in the lens if you do. Thanks for your help.
You can zoom completely independent of the focus.
Some lenses immediately override the autofocus when it senses you turning the manual focus ring. Other lenses don't, and you can damage the lens by forcing it. It depends on the lens, so you'll have to consult the documentation for the specific lens.
Jul 06, 2011 | Sony Alpha DSLR-A200K Digital Camera
WHICH LENS WILL GIVE THE SAME RESULT OF 50 MM LENS IN FILM MODEL
To figure the equivalent coverage comparable to a film camera, multiply the number of mm by 1.5. Example: a 50mm lens will be like a 75mm lens on a digital camera.
Sep 08, 2009 | Nikon DSLR D90 Digital Camera
Quantaray 70-300mm SLR lens does not work with Canon DSLR STi
If it doesn't work then sorry that is how it is. I heard is not really a good reason, I hear a lot of things most is not true.
May 19, 2017 | Quantaray 100-300mm F4.5-6.7 Zoom Lens for...
Cameras compatible with Quantaray AF 70-300mm lens
Depending on how new your Minolta SLR film camera was, the lens may or may not work on a Minolta Digital SLR. In many cases, a lens with the correct mount (in this case, a Minolta mount) can be used on the same brand of camera in the digital format.
One thing you should know is that DSLR sensors are, generally speaking, smaller than the size of a 35mm film negative. Long story short, that means that your lens will have a magnification factor on the DSLR. Usually, it is in the range of 150%, so a 70-300 lens from a film camera would cover 105 to 450 on a Digital SLR.
To be sure about the mount, you'll need to seek advice specific to Minoltas -- probably best to take your lens to a local camera shop and see for sure if it fits and what features will work (aperature, auto-focus, etc) and which won't work on the DSLR.
May 31, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Polarized lens
A polarized lens will work on a digital as well as it would on a film camera.
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Filter
Skylight filters don't generally block UV, they change the colour tint optically, which you can do without danger of image degredation in post-processing, so I woudn't really recommend using a skylight filter for digital cameras. I haven't tried a UV filter on my fz10, only my circular polarizer. From what I've heard however, a uv filter may act as lens protection (or use the lens hood), and might in some circumstances reduce haze (rarely), and there are unconfirmed rumours of possibly reducing purple fringing. If anyone could ever confirm this, I might consider one. Otherwise, UV filters also seem peripheral for digital photography. Probably the most important optical filter you can use is a polarizer. This can cut a lot of excess scattered/polarized light and reduce excess contrast, increase sky colour saturation, etc. It's effects are extremely difficult or impossible to get in editing.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Nikon DSLR D90   Digital Camera Logo
122 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
