Question about Lexmark C540N PROD SPECS TBD Printer
Replace waste toner box - Lexmark C540N PROD SPECS TBD Printer
  • 624 Answers
SOURCE: Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 17, 2007
tech435
  • 284 Answers
SOURCE: "replace waste toner box" error
sorry there is no quick solution you need a tech to go into service mode and reset the counter
Posted on Nov 03, 2008
leroyal
  • 2120 Answers
SOURCE: Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Posted on Feb 05, 2009
  • 95 Answers
SOURCE: Oki c9600 printer - waste toner box
Did you first try and dump the waste toner out of the waste toner bottle? If so it never completly gets empty. It is compacted at the end where the opening is. When the mach fires up the gears that drive the waste bottle break.
Posted on Mar 11, 2009
  • 34 Answers
SOURCE: how do i replace the
When you open the door to access the toner and waste toner area, you will see a letter "K" on the left side of the waste toner box, and a thumb screw on the right side of the waste toner box. Immediately above the letter "K" there is a raised area in the brown plastic housing. It is between the blue toner cartridge, and the waste oner box. There is a second raised area 2.5 inches at a 225 degree angle below the thumb screw on the right side of the waste toner box.
If you will place your thumbs on the raised areas and your forefingers on the white plastic rear cover of the waste toner box immediately below the raised areas and squeeze your fingers towards your thumbs, the waste toner box will come forward at the top of the box. You can then lift the waste toner box up and out of the printer.
Please squeeze carefully if you think your waste toner box is close to full as you may inadvertently find waste toner all over the place.
The two blue caps on the back of the waste toner box are to keep the waste toner in the waste toner box instead of your carpet.
Installation of the new waste toner box is the reverse of the above procedure. The new waste toner box almost snaps in place.
Here in California waste toner is considered a hazardous material and must be disposed of properly.
Posted on May 14, 2009
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
Reset Waste Toner
If your machine is displaying "replace waste toner container" then you can empty the waste toner box & reset the machine.
If you open the front door you will see a large black box & above this a small rectangular green button. Pressing this button will release the black box. The box will then lift upwards from the machine. At the bottom of the box you will see a round, clear plastic bung, remove the bung & empty the waste toner into a suitable bag or container. Once emptied, the bung can be re-fitted, the waste box can be inserted back into the machine. Locate the waste box into the 2 slots then push the waste box firmly back in place until it latches. Turn the machine off & on using the switch located to the left of the waste box in the bottom left corner of the inside of the front door. This should reset the machine. Be careful when disposing of the waste toner, it is flammable so do not dispose of in a fire. Hope this helps.
Dave.
Feb 19, 2016 | Sharp MX-3501N All-In-One Printer
Message on screen says "Waste Toner Box Full"
Typically you will need to replace the waste toner box. There is usually a difficult to access part of the bottle that is used by an optic sensor to tell when the box is full. Plus toner is very fine and you do not want it getting into the air. Toner will pass through the filter of most vacuums and go back into the air.
Dec 12, 2015 | Kyocera FS-1035MFP
Reset wast toner box on 9970cdw
Remove the full waste toner box per manual. Wear breathing protection as there will be toner dust in the air. Place flat in a work area and remove the 6 screws retaining the black box cover and carefully remove cover with box still flat on the work area. Be careful, the box is full of waste toner powder. Dispose of the waste toner by tipping into waste container, being careful not to inhale the powder. Use a blower or vacuum to remove final traces of waste toner from the box and clean all surfaces with a clean cloth. Place the box flat on bench to inspect the clear sight-glass at the front. Inside will be a black flag which should be down on the bottom of the sight glass. If not, there is still waste toner in the front of the box which needs to be shaken or blown out. Replace the cover and 6 screws and replace the waste toner box in the printer. If error message still says replace waste toner box, then you need to check the sight glass again. The flag must be horizontal at the bottom of the glass or it is not completely empty.
Jul 03, 2014 | Brother WT300CL Waste Toner Box
It says replace a waste toner
The waste toner box is full.You have to replace it now.Replace the waste toner box with the new one or empty the waste toner box and fix it again.Your problem will be solved!
Apr 09, 2014 | Samsung CLX 3305 - multifunction fax /...
Reset Waste Toner in a Brother
  1. Remove the full waste toner box per manual.
  2. Wear breathing protection as there will be toner dust in the air.
  3. Place flat in a work area and remove the 6 screws retaining the black box cover and carefully remove cover with box still flat on the work area. Be careful, the box is full of waste toner powder.
  4. Dispose of the waste toner by tipping into waste container, being careful not to inhale the powder. Use a blower or vacuum to remove final traces of waste toner from the box and clean all surfaces with a clean cloth.
  5. Place the box flat on the bench and inspect the clear sight-glass at the front. Inside will be a black flag which should be down on the bottom of the sight glass. If not, there is still waste toner in the front of the box which needs to be shaken or blown out.
  6. Replace the cover and 6 screws and replace the waste toner box in the printer.
  7. If error message still says replace waste toner box, then you need to check the sight glass again. The flag must be horizontal at the bottom of the glass or it is not completely empty.
Jan 24, 2014 | Brother WT300CL Waste Toner Box
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
Sharp MX 2300N - Toner collection unit needs replacing, not sure what this means. We replaced toner cartridgers very recently and assume this is a container that collects loose toner particles. How do...
REPLACING THE WASTE TONER BOX
The waste toner box collects residual toner that is produced during printing. When the used toner box is full, the display
will show "Replace used toner container". Follow the procedure below to replace the used toner box.
Open the front cover.2
Release the used waste toner box.
The waste toner box will fall forward as shown.
Gently support the box with your hands as you let it fall forward
as far as it will go.
fmtx.png Remove the waste toner box.
Hold the box by both hands and lift it up slowly.
If the waste toner box falls too far forward, it will not be possible
to remove it. (Remove the box when it is at an angle of about
30 degrees.)
Install the new waste toner box.
Insert the box from above at a slant. (The direction opposite to
when you removed it.)
Push the waste toner box into the
machine.
Push the box in until it clicks into place.
Close the front cover
Hope this helps.
Feb 07, 2011 | Sharp MX-2300N Color Copier
I have a c652 biz hub keeps coming up waste toner box konika minolt printer
To replace the waste toner box, open the front door above the paper drawers. The waste toner box is on the left hand side (usually). Your supplier should have supplied an extra waste toner box. Slide out the 'full' toner box. Replace with an empty one. This should register that you have installed an empty waste toner box. If not, turn off the copier and after a minute or two, turn on the coper again. [If you want to be environmental friendly, the toner box has a small slide cover approximately 1-2cm long (usually on the upper face at the rear as you remove it). Place this end in a plastic bag, slide open this 'cover' and rotate the toner box 180° so this is facing down. Care needs to be taken to prevent the 'waste toner' from flying everywhere. Gently agitate the box until all the waste toner (a grey color) has spilled out. (Approximately 600-800gms) Carefully seal the bag and dispose. An industrial vacuum cleaner can be used to remove the residual toner, clean down the waste toner box with a soft rag and it is ready to re-use.]
Sep 02, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do i replace the waste toner box on the konica minolta
Jul 31, 2008 | Konica Minolta Office Equipment & Supplies
Lexmark C540N PROD SPECS TBD Printer Logo
748 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
