posted by oldsilver73 on May 29, 2008
Can information or programs that are stored on one drive be tranfered to another drive?
My C: drive was failing, and was replaced with a new one, but some of the programs on the old C: drive need to be recovered and placed on the new drive.
Can this be done if so how?
Steve Fox
Solution #1
posted on May 29, 2008
if its a laptop u need to buy an external hard disk case to connect yr old drive so when pluged to the usb port the system see's it like flash drive so what yu do flash drive yu do to it..
if its a desktop system then u need a second hard drive cable so u can connect it to the IDE-2 port on yr motherboerd then boot yr system yu should see the second drive as d: in my computer so u do the normal copy and paste from d: to c: if u dont have a second hard disk cable(bus,data cable) then yu will need to use one cable to connect the 2 drives by making the good one a master and the bad one slave through the jumper settings.
hopes this helps
do give me feed back when done.
hopes this helps
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
HP Compaq Motherboard
HP (D9896-69007) Motherboard
HP (P2074-69003) Motherboard
AOpen (MX4SGI4DN2PRE) Motherboard
ASUS (M2NGREEN) Motherboard
ASUS (P4BP-MX) Motherboard
ASUS Intel 440BX Chipset P2B-VM Motherboard
Can you Help with these Motherboards problems?
ASUS P5N-E SLI Motherboard
put new vid card in pc it will...
I have a asus p5n-e sli... Answer This...
Foxconn 761GXK8MBRS AMD Athlon 64/Athlon 64...
downloding drivers
downloding drivers
I want to download the driver... Answer This...
Toshiba Satellite (K000004080) Motherboard
Toshiba Satellite A135 is DEAD!
My daughter's laptop won't turn... Answer This...
Repair Service
Find Motherboard Repairman Near You:
