Question about SanDisk Sansa c150 MP3 Player
Need help plugging in to computer
I made a mistake and lost the cable for my Sansa C150. I was wondering if there is a place to purchase one or some way or using a differnt type of plug to keep using this MP3 player.
Thanks
  • 758 Answers
You can click on the link below to find the cable
http://cgi.ebay.com/GENUINE-SANDISK-USB-CABLE-for-SANSA-C140-C150-C240-C250_W0QQitemZ130193244770QQcmdZViewItem?_trksid=p3286.m20.l1116
I hope that help
Please rate accordingly
Thank you
Computerrep
Posted on Oct 03, 2008
I just bought the usb connector for the sansa sandisk c150 mp3 player and my computer will not recognize it when I plug it in.
Make sure it is the right thing.
I tried to use an extension cable for
mine and It won't work with it.
I don't understand it!
No ext fine, use ext no fine.
It could be the wrong cable/connector.
PLEASE RATE YOUR ANSWER
Aug 13, 2011 | SanDisk Sansa c150 MP3 Player
C150 as not working what's solution?
Check the orange "Hold" switch on the left side of the Sansa C150, if you cannot turn on the MP3 player or if none of the buttons is working. When the "Hold" switch is up, the buttons are disabled. Slide the "Hold" switch down to activate the buttons again.
Press and hold the "Power" button until the LCD screen lights up when turning on the MP3 player. Pressing the button quickly does not turn on the device. The "Power" button is located on the front of the device, under all the other control buttons.
Replace the AAA battery, if you cannot power on your MP3 player. To replace the battery, remove the battery cover from the back of the device by pressing in on its tab and pulling it off. Remove the old battery, insert the new battery and replace the cover. One AAA battery provides approximately 15 hours of power for your Sansa C150.
Change the backlight settings to conserve battery life. This is useful if you find the battery loses power quickly during normal use of your Sansa C150. To change the backlight settings, choose "Settings" to bring up the "Settings" menu. Select "Display," "Backlight" and then a shorter backlight time. The backlight will shut off after a period of inactivity that matches your backlight setting.
5
Review your music purchases to understand what rights you've purchased to the content, if you are unable to play a track back on your Sansa C150. When you purchase music, it comes with certain rules for how you can store and play it. You may not have paid for the right to transfer the song to a portable media player.
6
Reset the Sansa C150 if it acts erratically or if you have other problems. To reset the device, open the "Settings" menu and choose "Reset All." Choose "Save" to finish restoring the MP3 player to its factory default settings. If you decide not to reset the device during this process, select "Cancel" instead of "Save."
~KenjiFox
Jan 07, 2011 | SanDisk Sansa c150 MP3 Player
Computer does not detect Sansa c150
This model is no longer made but sansa can areplace it for you. Go to their website and call tech support for your area.
Oct 28, 2008 | SanDisk Sansa c150 MP3 Player
I have lost my cable
They can be purchased.  Look at your local electronics shop.  They might have it although it is more likely that you will find it at a specialist online shop or on ebay.
Jul 20, 2008 | SanDisk Sansa c150 MP3 Player
Not Doing Anything Sansa c150
go to my computer when it is plugged up and delete the music from the harddrive of the player.
May 16, 2008 | SanDisk Sansa c150 MP3 Player
I NEED HELP
Follow the link below to obtain the driver for your device..Select your device model and operating system.....
http://www.sandisk.com/DriverDownload/index.asp
I hope this helps..
Thank you
Computerrep
Mar 19, 2008 | SanDisk Sansa c150 MP3 Player
I need help!!!
It doesnt sounds like your device is fixeable...most likely you will have to buy another player...the reason you need to buy a new player is because you are not going to be able to see the screen to do a manual reset....therefore no troubleshooting is available for you device...
Dec 17, 2007 | SanDisk Sansa c150 MP3 Player
Open Questions:
SanDisk Sansa c150 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
