Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Dyer on combo won't start
I have a duo washer and dyer Frigidaire. Model #-FLEB8200DS0 serial # XE44903623.
the washer turns on and works..but.. the dyer, when you turn the swith to ON.. it won't click on. I tried the circut breaker, unplug and replug,clean out the lint, held down latch and tried to start it, but nothing works.
can you give me more suggestions? could the switch be burned out? how does one go about fixing it if it is?
I really don't have the funds to get a repair man out here to fix, so if there is a way i can try and do it myself with your help. that would be great!!
please let me know. Thank you
  • kypoet Nov 05, 2008
    I have the same problem & no money for a repair man.
  • 23 Answers
This could either be a bad start switch or door switch
Posted on Nov 04, 2008
Frigidaire Washer Dryer Combo (Stacked) We had to have the power shut off to our house. Now that it is turned back on, our washer dryer combo won't start.
Thank you for your inquiry, Caroline!
From the information you have provided your Frigidaire laundry center is no longer working. I understand that you had to shut off power to your house and now your laundry center is not coming on. It sounds like you could have a possible short within your timer. I would recommend performing a reset on your laundry center and you can do that by unplugging the power cord for roughly ten minutes. If you continue to have issues with your dishwasher can you provide me with your model number? In order to locate your model number you can find the serial tag and that should be located on the inside wall of your dishwasher. I look forward to assisting you further. -OOS
Mar 23, 2015 | Koolatron 1.7cuft Thermoelectric Fridge
My kenmore 29822800 won't fill with water, it works on spin and drain
The last time I moved, my washer/dryer combo (Frigidaire) had the same issue for approximately 7 months before finding out all I needed to do was level the washer, and of course, make sure the faucet connected to the washer is turned to on position. Hope this is helpful.
Praysemema.
Mar 13, 2013 | Kenmore Washing Machines
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
Hi there, I am trying to find the year of the washer/dryer stackable combo unit that I have. It is a Frigidaire Heavy Duty 27" model. Model number is MLC275CW5 and the Serial number is XE92196352. ...
5/99 is the date,if you want to find out dates on any other appliances you can go to appliance 411 and enter the model and serial numbers,brand name and what appliance you're looking up and it will give you the date.good luck
Aug 08, 2011 | Frigidaire Washing Machines
I have a Frigidare washer/dryer combo (model # FLEB8200DS0). My wife washed a heavy load and the washer stopped draining completely. Agitator works fine. Please HELP...
I'm not sure if the heavy load had anything to do with it or not. this unit has a remote pump, which means the pump doesn't run off of the main belt . It actually has a motor of it's own. Basically you would have to remove the front access panel, of course unplug from power, make sure the pump will turn. with the power off you can rotate the cooling fins on the pump motor. if it turns freely then you would have to determine if the pump motor is getting power. If it is getting power then you need to replace the motor.
Oct 24, 2009 | Frigidare FEF336EC Stainless Steel...
I'm trying to find out the cu. ft volume cap on a Frigidaire Washer Dryer unit that I'm going to purchase Item # FLEB8200DS0... Does anyone know?
Go to managemyhome.comand you can get a manual for the unit by entering the number you gave above, and the Frigidaire.
Jan 24, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
153 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
