Question about ECM Giotto Espresso Machine
Giotto Premium problem...
My ECM Giotto Premium is about 4 years old... turn it on, power light comes on, but it does not heat up and has a clicking sound that will not stop until I either turn it off or unplug. Not sure the tech at Espresso Parts in Olympia has it figured out yet... says it may be the 'Auto-fill controller'. Also says that ECM was sold, does very little business in the US of late and it's hard to find parts. He's supposed to take a closer look at it later today.... any suggestions as to what this could be and how to remedy it?
Olywagal
  • Olywagal May 30, 2008
    Well, I just spoke with the repair tech where I originally purchased my Giotto Premium 4 years ago. He knew exactly what the problem was when I described it... power light on, clicking noise (not remedied by a hard boot), water not coming out of the grouphead, not heating up etc. Apparently, this is a common problem, but is not the heating element; it's the relay box costing about $200 from GCM in Italy. (and why did I pay $10 for this professional advise?) Olywagal
    Genius:
  • 1,142 Answers
Try to do a hard reset by unplugging the device from the power outlet or take the batteries out and wait for sometime to reconnect.
Posted on May 29, 2008
I turn the ECM Giotto on, the light comes on but the pump does not activate and no heat. 2 hours later it all works fine.
Try this open the steam valve when you turn the machine on, leave the valve open until it starts to hiss with steam, then turn off valve. If that works then the vent valve is sticking and needs to be replaced.
Oct 12, 2011 | ECM Giotto Espresso Machine
My Giotto Premium drops water from time to time - it runs out the holes in bottom of machine and makes quite a mass of water either side of machine on bench - we can't see a pattern - but do leave the...
Did you find a solution yet?
If your machine isn't plumbed in, so you have to fill the reservoir, I find it is easy to overfill, and the water runs out over the lip. I placed a fishing float with the long bit sticking up through the hole, so I can see when the water level is too low.
Dec 27, 2010 | ECM Giotto Espresso Machine
I have a Giotto ECM esspresso machine. it is approximately 3 yrs old. recently when i turn the machine on, it starts heating up, but it doesn't create any pressure. any suggestions how to fix this problem.
Hi
1 solution is your vacuum breaker valve is sticking. Try opening the steam valve and see if you can start to heat again. If it does just, replace your vacuum breaker valve.
Sep 20, 2010 | ECM Giotto Espresso Machine
My 5 year old Giotto has stopped working
The vent valve on the machine is stuck in the open position. Turn on the machine and open the steam wand until you hear a hiss or see small water bubbles from nozzle, let it steam out a little more then close wand, that should allow the machine to heat up correctly, then order a new vent valve for the machine.
May 03, 2010 | ECM Giotto Espresso Machine
ECM Giotto releases steam instead of water from the coffee group
Check the shower screen and diffuser in the head, they might be blocked, if not, check the metering jet at the top of the head(large nut) CAREFUL, make sure machine is off and cool before removing, use a paperclip or pipe cleaner to clear blockage. If not blocked then you will have to check the brew solenoid.
Mar 02, 2010 | ECM Giotto Espresso Machine
Help w/ ECM Giotto. pump doesn't turn on when pulling lever
Replace the magnets in the water tank, the reed switch is not reading one of them, most likely the safety or bottom magnet.
Feb 03, 2010 | ECM Giotto Espresso Machine
Just replaced the head gasket of my giotto
HI
Make sure that the water level probes are touching the machine to ground themselves. Push down on the probes, and see if the machine comes on. With out looking at it I don't know what else to tell you.
Nov 21, 2009 | ECM Giotto Espresso Machine
No Pressure..No heat
Se my solution re no heat on page. pressostate or microswitch fail is easy to fix. many times the water tank is bebt out of shape with time. A twisted tank lift one side and tank is no longer resting on four points. This cause no contact with electrodes inside tank saying = no water = no power allowed. The GROUND must be established! A small piece of alu foil rolled to a ball will help to ground the electrode again. Lift the tank gently and find the two v - shaped contacts for the electrodes. Have also replaced the electronic box once :-( on friends ECM /// olev
Nov 19, 2008 | ECM Giotto Espresso Machine
Giotto premium - is it a lemon?
My friend, had the same feeling,,,What have a done !! This piece of junk for all my dollars! No ,,it needs cleaning. Read all my comments re this. You can open this machine witha few fixed keys and mantain it. It will outlast you, when correctly mantained. All solid cupper and metal, no plastic. take it apart and CLEAN IT!
Remember - it is built by a human beeing. The ECM is a buty as it has very little automation built in. Very siple function = löong time in love with your machine. It is totally ANALOG = tweek it = better cogffee. /// Olev
Aug 23, 2008 | ECM Giotto Espresso Machine
ECM Giotto Premium (S/N 20030100413, purchased May 2003)
Well, I just spoke with the repair tech where I originally purchased my Giotto Premium 4 years ago. He knew exactly what the problem was when I described it... power light on, clicking noise (not remedied by a hard boot), water not coming out of the grouphead, not heating up etc. Apparently, this is a common problem, but is not the heating element; it's the relay box costing about $200 from GCM in Italy. Olywagal
May 26, 2008 | ECM Giotto Espresso Machine
ECM Giotto Espresso Machine Logo
196 people viewed this question
Top ECM Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
