Question about General Electric E840s Digital Camera
My camera ge e840s when i press at zoom button an message say lense error and camera power off
  • 231 Answers
Dear sir,
this happens when the clearance for the lense mechanism to open and close is being insufficient due to -small bits of sand or lint that may become get trapped in the mechanism which is commom while taking photos in open dust spaces.
It is advised to take the camera to a camera repair shop and have it disassembled and cleaned,if delayed the problem gets complicated..
thank you...take care
Posted on Oct 08, 2010
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
I HAVE A SONY DIGITAL CAMERA DSC T-20 AND HAVING AN ERROR MESSAGE E:61:10 PLEASE SEND ME HOW I CAN SOLVE THIS PROB LEM
Hello and Welcome
The symptoms of this error is
  • After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  • Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  • Zoom in and zoom out would not work.
  • Playback mode and the Setup mode was not affected.
To solve this
Put the camera about a half inch from a hard surface.
Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
Turn it on and let the lense go out fully
See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed
See the following video, It may also help you
I hope it will be Helpful for you.
Thanks and keep Using FixYa
Mar 16, 2011 | Sony Cyber-shot DSC-T20 Digital Camera
My Fujifilm FinePix F20 digital camera gives me a zoom error message and the lens does not open when I power up
problem on lense .remove ur lens on ur camera and cheak the motorgears which are supporting to move lense
Jul 11, 2009 | Fuji FinePix F20 Digital Camera
The lense will not zoom
Your camera has a zoom failure that can not reset by pushing menu buttons or else. Ask your local Sony repaircenter.
Regards,
Rob NL
Apr 24, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
E18 Message - Beeping.
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 13, 2007 | Canon PowerShot A520 Digital Camera
Zoom error message
Aug 07, 2007 | Olympus SP-350 Digital Camera
General Electric E840s Digital Camera Logo
Top General Electric Cameras Experts
Tom Chichester
Tony Parsons
Tony Parsons
Are you a General Electric Camera Expert? Answer questions, earn points and help others
