Question about Philips Magnavox MWR10D6 DVD Recorder
Lost Remote Control
Hello, I lost my remote for my Magnavox DVD recorder. I can access most features from the front panel but can't change channels which is important when trying to use the front and rear RCA plugs. Was wondering if there was a universal remote that I could use or a way to access the front or rear inputs without the remote. Thanks,
  • Anonymous Jun 02, 2008
    Lost remote
  • Anonymous Jul 30, 2008
    I lost my remote. Is there any way to finalize without the remote?
Wal mart sells a phillips universal plip remote that works with the unit but the code for the dvd player is not listed so you have to do a manual code serch pain in the !@# but other then that it works
Posted on Aug 30, 2008
  • auggiesdvdbu Aug 30, 2008
    i mean flip remote not plip
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
Codes for a magnavox vcr/divd player
Magnavox VCR codes are: 0330, 0430, 0534, 0324, 0224, 0124, 0230, 0125, 0247, 0093, 0598, 0830 .
Magnavox DVD player codes are: 0441, 0442, 0447, 0599, 0799, 0699, 0247, 0193, 0093, 0598
(see the link below if you need a DVD recorder code)
You may need to program the VCR and DVD player separately. A manual code search option is available. Turn on the device manually. Press and hold Setup until the LED lights up. Then press and release the device button. Press Channel Up repeatedly until the device turns off (use channel down if you miss the code.) Press Mute to lock in the code. Test all of the features of the remote that you need; repeat the seach if you find the code doesn't work for all features.
Please note: remotes usually only have codes to control devices released 6+ months before the remote was programmed. If your device is newer than your remote, you may need a new remote.
The documentation for the SRU2013/27 is available here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=REMOTE_CONTROLS_SU1&cat=REMOTE_CONTROLS_CA1&session=20110307214530_216.49.241.252&grp=SOUND_AND_VISION_GR&ctn=SRU2103/27&mid=Link_RCCodeFinder&hlt=Link_RCCodeFinder .
I hope this helps.
Mar 08, 2011 | Philips SRU2103S-27 Remote Control
We lost the remote and we are trying to hook up our Wii to the front panel box. How do we change the input to the front panel without the remote
On the side of the TV there are a set of buttons. An Input button is next to the Menu button and will let you access the different sources connected to the TV. For the front panel input, look for the source labeled Front. (There are also volume control and channel +/- buttons.) The button order is Input, Menu, Vol -, Vol +, Ch -, Ch +.
If you want, you can get a substitute remote that is guaranteed to match the original remote's features here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=32V524T&uuid=12935850039140 .
I hope this wants.
Dec 29, 2010 | RCA 32V524T TV
I have a Magnavox DVD/VCR combo that I have lost the remote to. I have bought universal remote after universal remote trying to get one that will work the DVD player or at least will setup the date and...
Universal remote does not work with Magnavox combo of dvd vcr, because no dubbing button. But magnavox has many remotes that will NB884, NB559, NB677.NB627 which also works on Sharp dvd vcr combo.
Nov 05, 2010 | Philips Magnavox Learning Universal Remote
I have lost the remote fo magnavox is there a universal remote
yep you can order a brand new remote at:
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12601096376390&smodel=MWR20V6&brand_pn=MAGNAVOX_MWR20V6
this link is an exact replacement, model and everything. its $40.00 dollars though.
Also almost all universal remotes will work on your player as well.
if this was helpful please mark it fixya.
Dec 06, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Lost remote to sylvania combo tv how can i change the channel manually?
If tv is programmed you should be able to change channels at the tv front control panel. Also, you can buy a univeral remote and program it to your television.
Apr 23, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Panasonic DMR E80H Video recorder remote
While pressing [ENTER] on the remote control press the [1] button on the remote - that should change the remote's control code back to one.
Jul 28, 2008 | Panasonic DMR-E80H DVD Recorder
Tv codes
Hello, Well I have a Phillips universal remote but but maybe they are the same. For the Orion TV try 105, 115, or 713. For The Pioneer DVD Try 042. If one or more does not work, Look for a "code Search" button. Turn on the device, then push and hold down the code search button until the red indicator stays on, then release the search button. Press and quickly release the desired mode button (TV, DVD, etc). The red indicator blinks off once. . If it is a tv or vcr use the channel up button until the channel changes. Press the power button on DVD and see if it is right Hope this helps.
Mar 16, 2008 | Philips Magnavox REM-350 Remote Control
Philips Magnavox MWR10D6 DVD Recorder Logo
481 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
