Question about LG 22.4 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Smooth Black
It is making a fairly loud noise that stops when you open the doors
  • mraab Jul 21, 2012
    Thanks!! This was exactly the problem on my fridge, and is probably a fairly common problem. In detail... - Some ice was evident on the outside of back ball. To get to the ice that was affecting the fan... emptied freezer, removed screw in center of back panel. Pressing panel half way up, and heard ice crunching behind it. Think this step may have helped loosen the ice. Pulled on ice maker wire to get left side and bottom tab free. Broke vent fin, and pulled on right side with finger. Pulled panel out on right side, and clunk. Large chunk of ice fell out. Reached behind and took out a few more pieces.
    Thank you. This must be a fairly common problem. Would probably be easiest to let the ice melt to fix this problem. I was able to get mine off without defrosting. 1) Press the center of back panel to crunch ice behind it. Pulled Ice maker hose/wire to free top left corner. Broke out small vent fin on top right vent, and pulled out right side with finger. Clunk, ice fell out.
  • LG Master
  • 43,501 Answers
The fan is hitting built up ice ....
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
My LG refrigerator model # LFX25960ST/bottom freezer, is making a humming noise that stops when we open the door. What is it?
my refrigerator before making a loud noise when we open the door. i called mr.apliance he replace the evaporator fan.......
Sep 25, 2010 | LG Refrigerators
The freezer is making a loud buzz sound that stops when I open the door.
Could be the evaporator fan motor about to fail or the evap fan blade touching something. If the fan is controlled by a door switch, opening the door would deactivate the motor and the noise would stop. Depress the door switch and see if you can locate the exact source of the noise.
Mar 03, 2010 | GE Refrigerators
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge makes a fairly loud humming noise when I close the door
it sounds like your refridgerator might be unlevel try adjusting the legs all the way down to start then level to floor if that doesnt fix it its probably the rubber gromet under the compressor usually there is four of them if one comes out(usually after moving it makes your compressor vibrate you can use almost any gromet of of any junk refrigerator or if you want you can by original replacement parts at one of your local appliance dealer
Dec 18, 2008 | Dishwashers
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
LG 22.4 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Smooth Black Logo
103 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
