Question about GE Refrigerators
Motor runs constantly - GE Refrigerators
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
My plumber says the pump should not run constantly, but should switch on and off. It come on for about 15secs and then off. I want it to run constant, will it create problems?
Assuming you do not build up really excessive pressures and the motor is not straining, running the motor constantly is better than having it cycle periodically. Every time a motor turns on a tremendous amount of juice goes into the motor windings until the motor speeds up and the back emf reduces the current. A constantly running motor will run cooler and last longer.
Oct 20, 2015 | Plumbing
Abs motor runs constantly
take to brake specialist,there is no abs motor
Jul 09, 2015 | Cars & Trucks
My karcher k7.85 has lost pressure and the motor runs constantly when switched on ,motor only used to run when trigger pulled in on lance ,there is no leaks. Can any one help please.
Sounds like the pump seals are bad. The manual says to only use these a few minutes at a time, most people try to clean the patio etc with them, run them too long, and burn out the pump seals - don't ask me how I know this.
Feb 17, 2014 | Karcher Garden
Pump will not stop running
It is difficult to answer the question with so few symptoms. The question would be whether the pump stops when you open the door? If not, then should checked for correct door switch, otherwise I think you need to replace the main board. If you see diagram bellow you can see that the motor is driven by the triac which is probable remain in the open position and constantly power supply motor. Some model has relay which switch between wash motor and drain motor and there is possible that relay stuck and motor also running constantly.
22778750-fvdtzpxoyys0i2rs1v4qjxt5-4-0.jpg Dado
Jan 09, 2014 | AEG 21 in. Favorit 45250Vi Built-In...
Diverter getting constant power on fisher & paykel ecosmart washing machine
I think this is a motor controller fault causing the pump to run constantly. replace the motor controller.
Aug 17, 2013 | Fisher and Paykel GWL11 Top Load Washer
Heater won't go off
If you're referring to the heater "FAN" running continuously, then its likely to be your blower motor resistor.
The heater blower motor (under the dash) has constant power supplied from the battery, but is controlled by the blower "resistor" - usually mounted on the blower motor assembly. If one or more of the blower resistor coil wires are faulty, the motor will either not work on one of the fan settings, or will constantly run by itself.
Jun 08, 2011 | 1984 Mercury Grand Marquis
Window motor on drivers side constantly runs down
Best guess would be a shorted window switch, it may have moisture in the switch or the wires are shorted or the switch needs to be replaced.
Hope this is of some help.
Ed
Mar 29, 2010 | 2005 Chevrolet Equinox
Humming sound? motor or fan constantly running
Hi, It is the evaporator fan motor you are hearing. The motor is the only thing that shuts off when the door is open. The fan motor is located behond the rear panel inside the freezer sections.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | LG LSC26905TT Side by Side Refrigerator
Engine checklamp is flashing constantly and the motor stop running.
first chek your sparking plugs your engine maybe working on with one or more cylinders is off . then check your distributar
May 31, 2009 | 1994 Toyota Corolla
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
