Question about Troy-Bilt Pony Garden Tiller
No spark at all on a old briggs and stratton. I
No spark at all on a old briggs and stratton. I suspect the magneto.
  • 26 Answers
Hi Michael--
There are a number of things that could prevent your plug from sparking. Here are some things to check before you replace the mag.:
1) Make sure all control switches are turned to the 'on' or 'run' position.
2) Check the ignition wire's connection to the spark plug. The round clamp that meets the spark plug can sometimes loosen over time. You can tighten it by first disconnecting the spark plug, then gently crimping the end of the ignition wire that grabs the top of the spark plug with a pair of pliers and refitting it to the spark plug.
3) Is there a kill switch or a grounding lug that is stuck to ground, preventing the plug from firing? Sometimes those metal tabs that ground out the plug get bent into the 'off' position.
4) Are all the electrical connections clean and snug?
5) Are the flywheel magnets dirty? Roughing them up with sandpaper and wiping them down with some solvent is sometimes all you need to generate a better spark.
6) Check that the points are properly timed and gapped. Even if they are good, improper gapping can leave you without spark. They should be about a matchbook's thickness apart at top dead center.
--Hope this helps, Joe
Posted on Oct 08, 2010
Why won't engine start after doing all these repairs
Make sure it is the correct spark plug with the correct gap. Then check to ensure that fuel is being delivered and is not bad
Jul 30, 2014 | Briggs & Stratton Briggs Stratton...
Why Spark on Briggs and straiten motor?
Does it have a shutoff wire on the carburetor?
Use a meter to check the coil at the magneto - if that coil reads "open" (no continuity), then it's bad & needs replacement.
Jul 26, 2014 | Garden
No spark on 6.5HP B&S OHV
Make sure that the magneto circuit is not grounded. Be sure that the air gap between flywheel magnet and magneto is at specifications. If all that checks out okay, then you need to replace the magneto. Also, check the spark plug for any cracks in the ceramic insulation.
Mar 15, 2014 | Briggs & Stratton Garden
Change a lawnmower sparkplug wire
Don:
You will need to buy a replacement magneto as the secondary (spark plug wires) are hard wired into the magneto.
Aug 29, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
No spark on briggs statton 16hp
If you have no spark, check magneto, flywheel key, points, condenser.It also could be to much gap between magneto and flywheel.Have you checked to see if you are grounding out some where?
Nov 30, 2011 | Briggs & Stratton Garden
What would cause no spark? the mower is a masport 8/02 two stroke. Will not start and I have changed spark plug and cleaned every thing but still nothing.
Your spark plug wire may be damaged, or your magneto may be too weak to generate a spark. You also have a kill switch wired to your magneto, and a condensor. I would start by cleaning the contacts of the magneto and then check the gap between the magneto and the flywheel. The gap between the flywheel and magneto should be .010". I would start by checking the kill switch wire for damage. If any damage is suspected, replace the kill switch. Next, I would have the magneto tested or replaced. Also, check all your ground wires for damage, or loose contacts.
When you are checking for a spark, you should have the spark plug installed in the spark plug wire as normal, but not installed in the engine. The spark plug base should be grounded to the engine while trying to start and checking for a spark. If there is a weak spark, this is probably due to a worn magneto.
May 24, 2011 | Briggs & Stratton Garden
Have a 5600 Gen. with 10 HP B/S engine OHV. Did great during Rita, replaced carb- changed gas-replaced plug- doesn't want to fire it seems. Where Can I find the magneto ? Are there points on the flywheel...
The magneto is by the flywheel. Depending on the age, there maybe points under the flywheel. If so you remove the flywheel and there the points are. Sometimes bugs build cacoons between points, make them inoperable. Newer engines have electronic ignition though. Follow the small wire from the magneto coil ( where the spark plug wire goes) it will either go under the flywheel through a plastic bushing, or to an electronic module. The magneto coils do fail you can test with an ohm meter. Before that test for spark. You can remove the spark plug, and let it rest on the engine to get ground, and turn the engine over. You always need 1-spark, 2 fuel . If you have spark, see if it will hit on starting fluid, if it does, then you have a carb or fuel filter issue. Those shut off valves on the bottom of those tanks, can be a problem
Jun 29, 2010 | Briggs Stratton H7159 & Stratton® 5500,...
Wiring on an old 5hp Briggs and Stratton engine
The "heavy wire" connects to the spark plug. It should have a plug connector attached. There are 2 small wires. One of them grounds to the engine block (probably through one of the screws that holds the magneto in place). The other wire goes to the condensor/capacitor.
Nov 30, 2009 | Air Tools & Compressors
Troy-Bilt Pony Garden Tiller Logo
531 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
