Question about Samsung NV10 Digital Camera
When i put it in auto and take a picture is says processing and turns off, when i put it on again there is no picture. i have changed the battery and have two new sd cards that should be compatible
  • 231 Answers
dear sir
this is the problem usually caused by viruswhich happens when you are receiving files from p.c or untrusteddevices...... and sometimes it might be software failure also, which causes some of the menu not tofunction,the only solution is to flash ur cam software from the nearest samsung care,it also updates your cam software
take care...thank youu
Posted on Oct 08, 2010
.1991 Ford Aerostar 4.0 Lt engine, auto tran', electrical short ?
turn every thing on in park if voltage drops change alt
Mar 03, 2010 | 1991 Ford Aerostar Extended
The battery in my car keeps died, so I jump it then it dies again
if you have a multi meter disconnect positve battery terminal and put red wire to battery and black to battery cable put multi meter on resistance should be 0.005 or less if more then check for things that may be plugged in to cig lighter etc turn door lights off etc dont turn key on any more than 0.005 will drain battery
Aug 25, 2009 | Mercedes-Benz ML-Class Cars & Trucks
Camera stopped taking pictures
Same thing happened to me a while ago. I was in a panic. I turned it on and off several times...no change. Finally, I turned the camera to the off position, took the battery out of the camera for about 30 seconds and put it back in again and it worked fine. No problem since.
Jul 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 1000D
Yep set the auto turn off higher and instead of removing the battery, just open and close the battery compartment.
This appears to be a problem I have raised with Canon, hopefully they will release a firmware update soon to fix this
May 30, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
Red light continually flashes, and won't take picture
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Mar 05, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
The flash on my camera is not working!!!!
If the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
Hope this one helps.
Jan 12, 2008 | Samsung Digimax S630 Digital Camera
Auto Focus Not Working
Mine did the exact same thing and i hav only had it for 3 months; there is nothing i could do exept for taking it to the professionals
Dec 14, 2006 | Samsung Digimax S500 Digital Camera
Why doesn't the shutter button on my EasyShare digital camera work?
The cause and solution may include one of the following: The camera is not turned on. Turn on the camera. The camera is processing a picture; the camera Power ring light (on the Mode dial) blinks green. Wait until the light stops blinking before taking another picture. The card or internal memory is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The shutter button was not pressed. Depress the shutter button completely down. There was a failure in the focus and/or exposure. Press the shutter button halfway to set the Auto Focus (AF) and Auto Exposure (AE). When the AF/AE indicator turns green, press the shutter button completely down. The battery is exhausted. Replace or recharge the battery
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Samsung NV10 Digital Camera Logo
53 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
