Question about Microsoft Xbox 360 Console
Xbox 360 hi my xbox360 will not play any games all i get when i put a disk in is open tray and the wheel in the disk drive is only spinning for a few seconds then stops. please can you help me. from tracey allen
  • 3 Answers
Their are four ribbon cables inside one for the laser, one to open, one to spin the disk and one for power sometimes one of these might come lose. Or maybe even the laser has gone out but try in that order cables first, once the disk drive is opened then check for the laser turning on without starring directly into it you should see a red light of course. A new laser goes from 15 to 40 bucks depending on the type of drive you have check ebay first.
Posted on May 30, 2008
Open tray error
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
Nov 11, 2009 | Microsoft Xbox 360 Console
Xbox360 disc drive
Hi, it sounds like you have the" open tray" error that is very common with the 360s. How you fix this is you take your DVD drive apart and look at the laser assembly, there are 2 screws on the side of it, look at the one on the left. Turn this screw to the left a VERY little bit at a time and keep checking it every time you turn it until it stops the open tray error.
Aug 17, 2009 | Microsoft Xbox 360 Console
XBOX360 won't read disks
the magnet that pulls the tray up has most likely come loose go on youtube and there are videos showing hoe to fix it
Aug 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 Pro : To Play This Disk Error
Unfortunately , a new xbox360 game cant be played in a normal xbox (not xbox 360)
The problem is that the new xbox is way different on the inside than the original xbox is. Because it is way more powerful, you can put an old xbox game into a 360, and it will work fine (most of the time), but if you try the reverse there is no way to make it work.
May 13, 2009 | Microsoft Xbox 360 Pro System Console
Help
Try putting the game in straight. By straight i mean putting the disc in where the xbox 360 logo at the top of the disc goes in the tray towards the xbox360. if that does not work contact microsoft
Mar 16, 2009 | Microsoft Xbox 360 Console
My Xbox 360 stopped spinning the CD and playing the games.
i myself have the same problem and currently working on it. go to youtube and type in "how to fix a broken xbox360 dvd disk drive" this guy is amazing and helped me out with the red rings of death. all u have to do is buy a new disk drive for about $50 and take some parts apart.
Mar 14, 2009 | Microsoft Xbox 360 Console
My xbox says open tray when there is a disc in it
common xbox flaw mine does the same ,just keep opening and closeing the tray till it reads the disk,this can be very annoying .your dvd tray is probally on the way out
Feb 26, 2009 | Microsoft Xbox 360 Console
My xbox360 wont play any disk
I had a problem like this a few days ago, my 360 had problems reading my disks. I ended up opening it up and cleaning the laser in the dvd drive. After that it played fine, if that doesn't work you might need a new dvd drive.
Jan 04, 2009 | Microsoft Xbox 360 Console
Xbox 360 doesn't read games properly
3 Simple Steps to Fixing this problem :1.Take out and disks in the tray and turn it off. 2.Lay the XBOX 360 Horizontally and give the xbox 5-10 medium bangs with your palm or fist (top Left of the XBOX). 3.Turn it on, Put in a Game ! SUCCESS ! Hope it Helps There is a vid, Hope this helped. =D
Jul 10, 2008 | Microsoft Xbox 360 Console
Xbox 360 Will Not Play Games....
Try opening the disk tray with the 360 off. 05a1ed9.jpg Push a paper clip into 1 of these holes in your 360. It will pop the tray out. Grab the tray pull it out all the way. Put a game in, leave it open! Then turn your 360 on see if it boots the game.
"Your Disk tray might be going bad. It might be fixable but I will have to try it out on a bad drive which iI dont have at this time."
Oct 22, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
95 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
