Question about Fanimation LX25IM Ceiling Fan
My ceiling fan only works on high speed........not medium or low. Too powerful for the bedroom.
  • 17,130 Answers
Fault in your regulator or the control in the remote.
The fan speed is controlled by a thyristor or SCR device which could have shorted in the panel, thereby giving off the full voltage to the fan.
You will need to remove the panle to see the device or replace the control unit.
Please be careful when attempting to work on power circuits.
Posted on Oct 08, 2010
Replaced fan switch but fan only works on low and high but not work on medium
You have a problem with the connection to the medium speed motor winding, or a problem in the motor. Turn off power to the fan, open it up and verify that the wire nuts are properly installed.
Nov 14, 2011 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan stuck on high
I found out that the capacitor and switch is shortened. I un-shortened, and it got to low, mediium, and off.
Apr 27, 2010 | Hampton Bay 24750 Huntington III Ceiling...
I have a hunter ceiling fan its about 20 years old. my problem is the remote will not work the fan. when i have the fan set on high speed the remote will only work the high and when i set the the fan on...
I'm sure you put fresh batteries in the remote...right? Most of the time you can correct remote problems by carefully taking the remote apart and cleaning all the contact points with a pencil eraser.
Jul 26, 2009 | Hunter 21564 The Brunswick Bronze Ceiling...
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
HB ceiling fan is getting slower and slower bi the day
Solid-state controls change the level of power in the fan motor to control the speed of the fan. For instance, when you switch from medium to high on a solid-state fan, the speed control mechanism increases the power of the motor. Solid-state controls are generally equipped in fans with controls that have predetermined settings, such as low, medium and high.
The solid state device in or around the fan motor could be defective and in need of replacement.
https://www.hunker.com/12003281/how-does-a-ceiling-fan-speed-control-work
Dec 07, 2017 | Hampton Bay 52 In. White Redington...
Changing the 3 speed switch on my westinghouse ceiling fan
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 18, 2009 | Speed Ceiling Fan 3-speed Switch By...
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
Altura 68" ceiling fan noisy
TAKE THE DARN THING BACK, IT SHOULD NOT MAKE ANY NOISE.
Jan 13, 2009 | Hampton Bay 24002 Ceiling Fan
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Fanimation LX25IM Ceiling Fan Logo
1,051 people viewed this question
Top Fanimation Dryers Experts
Paul Bade
Michael Galve
Michael Galve
Are you a Fanimation Dryer Expert? Answer questions, earn points and help others
