Question about Bosch Washing Machines
I have a tear in the lining of my washing machine by the opening.
  • Bosch Master
  • 17,129 Answers
This is the bellow housing of the drum and if this is torn then there is a possibility that water will leak.
So you will need to procure the part from Bosch.
Please click on Contact.
Posted on Oct 08, 2010
Kenmore elite washing machine
What is the model number?
Jun 29, 2013 | Washing Machines
Wm 2233hs. I think it is leaking somewhere. Not at the water lines and not in the drain line.
if this is a front loader check carefully in the rubber seal around the basket(where the door closes) They are notorious for small tears whichcan leak. Than use duck tape from the back to repair
Jul 15, 2011 | LG Washing Machines
Why dose the water leak out from the Miele Touchtronic W1113 Large Capacity Washing Machine w/ Stainless Steel Honeycomb Washing Drum?
Hi dear.Please check the door gasket for any wear & tear.(Also open the door,ajar inside the door gasket, check inside of it for any fine tear or cut.)Please check for pump filter.Is it attached correctly.I hope that helps.Thanks.
Jun 19, 2010 | Miele Touchtronic W1113 Washing Machine
Leaking water under front edge of machine?
Open the door and gently pull on the grey rubber gasket and check all around it for holes / tears. There are three tiny holes in the 'wall' at the bottom that are supposed to be there, but you should not see any other tears. I just found a large tear on mine that causes leaks when I run very large loads. I am going to try to fix it with Gorilla Tape, otherwise I will probably have to buy the whole new gasket. It seems like it would be a real pain to replace!
Apr 30, 2010 | LG WM-2277HW Front Load Washer
Whole in seal and a smell
Is the hole, or a tear? If its a hole, that's the normal hole to get the excess water out of the door gasket. If there is a tear, you'll need to replace the door gasket. The smell you get, is due to not leaving the door open, you'll need to leave this, and the dispencer open all the time, when your not washing. The unit needs to vent, in order not to have build-up of mildew/mold.
Mar 28, 2010 | Hotpoint Washing Machines
When I turn on the machine to wash then proceed to set the washing program and happen to touch any part of the machine it shocks me.
There is a leakage of current in the machine. Do the following Check the wiring. See there are no cuts or the wire is exposed due to wear and tear of rubber/plastic/cloth insulation. Ensure the exposed ends are not touching the body of the machine. Insulate all the open wiring ends. Check that the earthing wire is OK.
Feb 09, 2010 | Whirlpool LSQ9610L Top Load Washer
I am not getting any water into the drum unit when I turn on the wash cycle. I have checked the supply lines and they are working fine.
You may have a stopped up inlet screen. Turn the water off and undo the inlet hoses from the machine and see if there is build up in there. If so, clean it out, being careful not to tear screen. If that is clear, I would say that the inlet solenoid is not opening when calling for water. Hope this helps. Good luck.
Apr 24, 2009 | Washing Machines
Kenmore Elite HE3T door seal tear
tear may be from pulling something across it with sharp edges..to replace seall not major job front part of seal held in place with spring ..remove and pull boot away from front edge inlet tub slides out of boot opening rear held in place with LARGE screw clamp a little patience is usually all that's needed ..did 2 today
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Washing a down comforter.
yes but use a gentle cycle also ck for open seams or tears in comforter first if torn may cause stuffing to come out and plug pump
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
