Question about Maxi-Cosi Priori
How do I take the seat cover off to wash it?? I have most of it off but cant detach it from the seat belts???
  • Maxi-Cosi Master
  • 1,629 Answers
Full instructions on fabric removal are in your user manual.
Posted on Dec 13, 2011
My passenger side seat belt on my 2000 ford taurus se is locked and i cant retract it. how do i fix this problem with buying a new seat belt retractor
of course it possible to access this retractor , you just need to locate the small round circles in the lower part of trim and gently pry the covers off , screws will be evedent , you will need a 6 mm star (five sided) drive socket wrench to remove the retractor though
Feb 10, 2015 | 2000 Ford Taurus
Hi, I would like to know if the front seat belt retractors for Honda CRV 2003 are the same? If yes, is it difficult to replace the seat belt assembly? I'm planning to buy a used front passenger side...
I don't know if this is something you want to get into? You decide. Front Seat Belt Replacement SRS components are located in this area. Review the SRS component locations and the precautions and procedures before performing repairs or service.
NOTE: Check the front seat belts for damage, and replace them if necessary.
Front Seat Belt
  1. Make sure you have the anti-theft code for the radio, and then write down the frequencies for the preset buttons.
  2. Disconnect the negative cable from the battery, and wait at least 3 minutes before beginning work.
  3. Slide the front seat forward fully.
  1. Pull the lower anchor cover (A) back, and remove the lower anchor bolt (B).
  2. Remove the B-pillar lower trim panel.
  1. Remove the upper anchor cover (A), and remove the upper anchor bolt (B).
  1. Disconnect the seat belt tensioner connector (A), and detach the harness clip (B) from the retractor (C). Remove the upper retractor mounting bolt (D), and the lower retractor bolt (E), then remove the front seat belt (F) and retractor.
  2. If necessary, remove the front seat belt protector (G).
  3. Remove the B-pillar upper trim.
  1. Remove the shoulder anchor adjuster (A).
  1. Install the seat belt in the reverse order of removal, and note these items:
    • Assemble the washers, collar, and bushing on the upper and lower anchor bolts as shown.
    • Check that the retractor locking mechanism functions.
    • Apply liquid thread lock to the anchor bolts before reinstallation.
    • If the seat belt tensioner has been activated, replace the front seat belt protector with a new one.
    • Before installing the anchor bolts, make sure there are no twists or kinks in the seat belt.
    • Make sure the seat belt tensioner connector is plugged in properly.
    • Reconnect the negative cable to the battery.
    • Enter the anti-theft code for the radio, and then enter the customer's radio station presets.
    • Reset the clock.
    • Do the PCM idle learn procedure and the power window control unit reset procedure.
Upper anchor bolt installation
Lower anchor bolt installation
Seat Belt Buckle
  3. Remove the front seat.
  4. If equipped, remove the center table.
  5. Remove the under seat storage box.
  6. Remove the center cover, driver's, passenger's.
  1. Driver's: If equipped with seat heater, remove the harness band (A), and disconnect the seat subharness connector (B). If equipped without seat heater, detach the seat belt switch connector clip (C). Detach the seat belt buckle tensioner clip (D), and harness clip (E).
Dec 11, 2017 | 2003 Honda CR-V
How do iremove front seat from a 1997 honda accord
1. Make sure you have the anti-theft codes for the radio and the navigation system, then write
2. Tilt the steering wheel all the way up and telescope it all the way in.
3. '04-07 models passenger's seat: Carefully insert the tip of a small screwdriver (A) through
the hole in the back of the front seat belt lower anchor cover (B) and into the hole in the
front seat belt lower anchor (C). Unlock the lower anchor by pushing in on the screwdriver.
Remove the screwdriver, and then detach the front seat belt anchor plate (D) and anchor
cover from the lower anchor.4. Slide the seat all the way forward, then remove the seat track end covers from the back of both seat tracks.5. Slide the seat about half way to the rear so you can access the seat mounting bolts. If equipped with the driver's 8-way power seat, fully raise the seat.
6. If equipped with a side airbag, disconnect the negative cable from the battery, and wait at
least 3 minutes before removing the seat. 7. Remove the bolts securing the front seat. 8. Lift up the front seat, then detach the harness clip and disconnect the connector.
If equipped, the seat heater connector on the 2-way power seat and passenger's
manual seat. '04-07 models, disconnect the seat position sensor subharness connector on the
driver's manual height adjustable seat and the driver's 8-way power seat.
9. With the help of an assistant, carefully remove the front seat through the front door opening. 10. Install the seat in the reverse order of removal, and note these items:
Apply medium strength type liquid thread lock to the front seat mounting bolts
Make sure each connector is plugged in properly.
Tighten the seat mounting bolts to the specified torque in the sequence shown.
Slide the seat all the way back and tighten then slide it forward and
tighten Before attaching the lower anchor bolts, make sure there are no twists or kinks in
the seat belts. 04-07 models passenger's seat: The triangle marks on the anchor plate and
the lower anchor must face the same side. Insert the anchor plate into the lower
anchor, and make sure that it is locked securely. If equipped with a side airbag, reconnect the negative cable to the battery. Enter the anti-theft codes for the radio and navigation system, then enter the radio station presets. Reset the clock. Your all done. Drink a cold beverage and enjoy the rest of your weekend! hope this helps. Dave
Jun 16, 2011 | 1997 Honda Accord
Cant remove the cover off the straps at the bottom of the cabrio fix car seat i have removed it off the seat but can not remove the straps at the bottom to remove the cover
Had the same problem where you are left with the cover trapped by the quick adjust part for the shoulder straps located near the foot of the seat. The solution, the strap does detach at the front of the seat. The loop that is stiched round what feels like a solid plastic part of the base, turns out that there is a gap in the plastic so push the strap to either side and pull it out through the gap. With this removed you should now be able to remove the cover completly and bung it in the washing machine on a hand wash.
Feb 16, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
I dont know how to install stereo speakers in my citroen saxo VTR near the rear seats. how can i do this?
First you have to remove the old ones...
You cannot just clip out the rear speakers, as the cover over them is attached to the rear panel (2 door Saxos)
In order to take out the rear speakers, from what I remember...
1) Take out rear seats
-Get yourself in the car through one of the front doors
-Once inside face toward the rear seat
-Reach for gap between where the upper and lower parts of the seat join
-Pull the bottom half up and towards you
-Once it is vertical lift straight up to detach from pivot
-Get it out of the car to give you space
2) Undo 2 bolts
- Having just removed the lower part of the seat there are now 2 bolts visible 1 located each side of the car, next to the rear speaker panel.
- Undo the bolts, they are long so require lots of twisting until free
- Remember where the washer sat and place in safe location out of car
3) Lift up rear window seals
- Open rear windows
-Lift up the rubber seal which lies on the bottom part of the window
-(It is attached all the way round the window trim, only lifting it up is neccessary)
4) Remover upper seatbelt bolts
- Locate rear seat belts (side belts only)
- Locate top of seat belt fixing point
- Remove circular plastic covering on top joint of each belt (1 each side)
- This reveals seat belt joint bolt (1 each side)
- Undo bolts and place safely outside of car
- (Same for front seat belts required)
- Locate front seat belts
- Locate front seat belt joints at top of belt.
- Remove circular plastic covering (1 each side)
- This reveals bolt (1 each side)
- Undo bolt and place in safe location
5) Lower rear seat
- Open the boot
- Clamber in
- Locate where rear seat meets plastic trim (each side of car)
- Locate small plastic lever (each side of car)
- Push small plastic lever towards the front of the car (both sides same time)
- Meanwhile push rear seat gently towards front of car (helps if have a friend)
- This will lower seat
- (You do not want seat lowered completely, once seat is free in movement leave resting in normal position)
6) Remove rear speaker panels (requires trusted + competant friend)
-Friend Get in car sit where rear seat was on driver side (for space)
-You sit front seat passenger side
-You locate where rear speaker panel ends beside front door
-You pull rear speaker panel away from end at door towards opposite side
-You will notice part of rear speaker panel detach from car
-Friend and You pull off remainder of speaker panel from its poppers
-Notice lump of plastic preventing complete detachment from car
-Careful to prevent damage Friend and You need to move rear speaker panel towards front of car and up
-Remember plastic will flex, but is also capable of snapping
-Manipulating this action will get rear speaker panel detached from car...although still on the seatbelts themselves.
Notice how speaker is joined to hidden part of rear panel, rather than metal body work.
To remove rear speaker undo the 4 torx screws holding speaker in place, alongside wire joint (wire with plastic adaptor at end)
Do what you needed to do, and then return car to normal state by effectively reversing the above instructions.
(I accept no liability for any action you undertake from following these instructions.....yadda yadda)
If any problems contact a Sax-p I.C.E section expert, or if incounter any difficulties that the above cannot solve, any car audio installer can help, alongside most garages, including Citroen Dealerships.
The instructions above probably took longer to type than to actually perform, estimated time for completion is 40mins-1 hour.
Oct 24, 2009 | Car Audio & Video
Have washed the covers and now can't get the shoulder seat belts to fit. Their too short.
cant put the straps back in the correct way after washing car seat please help!~!!
Oct 06, 2009 | Nania Airway LX
Removing seat cover maxi cosi priorifix
To be able to remove the seat cover from your seat you have to 'unhook' the seat belts at the back of the seat:
First extend the seat belt to the maximum length.
Then put the seat at the maximum recline.
At the back of the seat-'shell' you will then see a metal hook that hold the shoulder straps: unhook and pull forward.
Reassembly is just the reverse.
A few more tips when removing the cover from a PrioriFix: take care not to damage the white extruded foam when pulling the belts forward and when taking off the cover. When the foam is not protected by the padding it may easily snap.
The seat padding is cold wash only and no spin-dry, otherwise the seams may loosen.
Please don't hesitate to use the contact form at http://www.babycare.nl if you need any further assistance.
With kind regards,
Babycare.nl Sales Desk,
Erwin de Raad
Jun 21, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
How do i remove maxi cosi car seat cover for washing please
hi bodsierpa..hope this helps..good luck!!!
• First remove the belt pads.
• Open the rim at the sun canopy as far as possible
• Remove the cover from the hooks
• Remove the cover then from under the hooks and quick adjuster button
• Pull the buckle tongue sections and adjustment strap through the openings.
May 15, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Jane powertwin has stains on seats do covers come off for washing
I normaly Scrub the seats down with some stain remover and hot water on a sunny day, or ona day when it is dry. Then leave them to dry, and they come up pretty good.They only detach from the pram as a full seat so not able to put in a washer.
Jan 11, 2009 | Jane Powertwin Jogger
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Maxi-Cosi Priori Logo
73 people viewed this question
Top Maxi-Cosi Baby Gear Experts
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
