Question about HP 22" Widescreen Flat Panel TFT LCD HD Monitor
My HP TFT (22") Monitor is not detecting any signal. I have changed the connecting cable and I think that some internal problem has caused the non-functioning. May kindly guide plz.
  • 11,361 Answers
You should try this monitor with other PC or try another monitor with this PC to find out if it is monitor problem or video card problem.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 08, 2010
No signal ???????
I have the same problem in setting up two displays, a Dell as primary and a VA2223wm Viewsonic as secondary, both connected to an Nvidia geforce 9500 GT. I think it might be the cable, but it's baffling. I have one DVI cable that seems to work on either monitor, and either plug on the graphics card. The second DVI cable doesn't seem to work, but when it's connected to the Viewsonic, the Nvidia control panel detects the monitor as secondary, so I can change settings, etc., but the monitor still says no signal. Each monitor works separately when connected with one cable, but not with the other.
Thoughts?
Jul 23, 2013 | ViewSonic VA2223WM 22 inch Monitor
I recently got a used Sylvania 22" TFT-LCD
you posted sylvania to HP , whY?
The did not post a question, is this show and tell.
or the CELL phone battery died.? LOL
Aug 10, 2017 | HP 22" Widescreen Flat Panel TFT LCD HD...
I get a "no input signal" error message on the
Check the cable, to make sure that it's plugged into the monitor and the computer.
After that restart the computer - some computers only detect monitors right when it turns on.
Dec 22, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
I just replaced the ram on my pc but when I went to turn it back on it says no signal detected and goes. Black while the power light goes orange. I have checked and rechecked the physical connection over...
Your computer isn't starting up, no video is getting to the monitor, and that's why you see the "no signal" message and the power light goes orange. Make sure you've reconnected any internal cables you might have removed when you replaced the RAM. Also be sure you've seated the RAM properly into its socket. I've seen modules seated crooked so that contacts are shorted. The modules should fit properly into the sockets so the latches click into place.
Try reinstalling the original RAM and see if the computer starts properly. You might have a defective part which is keeping the board from starting up.
Since the trouble began after you replaced the RAM, that's where to start looking for the cause. Good luck, and thanks for using Fixya!
Oct 05, 2010 | BenQ T701 TFT 17" LCD Monitor
Line across lcd screen
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer. let me know if this resolved ur issue.. regards, guru
May 03, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
Unable to detect 1440 x 900 resolution after change of cables
Try updating video drivers to be sure, but once you go over 3 meters, the video signal can degrade, causing a loss in the PnP signal to your monitor. Try setting the resolution manually.
Dec 28, 2009 | Samsung Syncmaster 940BW LCD Monitor
No DVi input, then computer goes to sleep
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
Dec 07, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
Blurred "No Signal" in the TFT when only power cable is connected.
in display settings try to reset the screen resolution
Oct 16, 2008 | Acer AL2216W LCD Monitor
HP 22" Widescreen Flat Panel TFT LCD HD Monitor Logo
81 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
