Question about Sony CDX-CA750X CD Player
I need the code to get the radio working as i disconnected the battery
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 2,226 Answers
What exactly is the radio doing. as far as i know sony radios do not require a code.
Posted on Oct 08, 2010
Need the radio code to reset after battery was disconnected.
Afraid there is no radio code as such....the Saab headunit is paired to the car with Saab Tech 2 software.
A dead battery swap shouldnt lose the radio if it was working before you changed the battery.
Have you checked the fuse for the radio?
You should also post on Saabcentral
Jan 14, 2016 | Saab 95 Cars & Trucks
Tip
DISCONNECTING YOUR BATTERY without losing the RADIO CODE
I constantly read frequent requests for RADIO CODES referring to the disconnection of battery power ( whether its for changing the battery, etc.) and the radio is now INOP. Here is a simple way to save radio codes, radio stations, clock time and computer settings. Purchase from an auto parts dealer, a 9 volt battery powered lighter socket connector. Plug into lighter, do your battery work, After work is completed, disconnect, and radio will work as before. Unit will cost less than 20.00 and well worth it.
on May 11, 2009 | 1993 Cadillac DeVille
Please someone give me a unlock code for ford 6000ne car radio.YS4F-18C815-AD. serial M178227
It is only available at a Ford Dealership...Give them your VIN Number & they will give you the code...There is a charge for this service...Now, if you lost battery because you changed or disconnected battery you can avoid this happening in the future...Take a 9 volt battery...Remove the snap top from an old smoke detector...Solder the + lead to positive of cigar lighter plug and - lead to negative of cigar lighter plug...snap on 9 volt battery and plug into lighter BEFORE disconnecting car battery...The 9 volt battery will hold radio up while car battery is disconnected...saailer
Jun 05, 2015 | Ford Cars & Trucks
Bmw 735 li e65 change battery and i get many problem no value to set clock radio not working cd also i disconnect the battery still the same problem
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your BMW service centre and get them to enter this code for you.
Jan 15, 2013 | Cars & Trucks
Code for a Ford Mondeo 6000cd radio
Hi Geof
Your radio code number should read: 5796.
I trust this will do the job.
I have no other code for your model.
Please let me know if this works.
Bye Ray
Sep 02, 2009 | 2001 Ford Focus
I have a renault scenic 2000, replaced battery need to input the radio code, noticed on this blog that you can push numbers 2, 5 and on button, I did this and my radio came on without me having to inp
Some radios hold the codes for a few Min's.However ,Disconnect the battery again and leave disconnected for an hour.Then reconnect and Enter codes and confirm.Should work ok.
May 29, 2009 | 2000 Renault 181
Radio locked after disconnecting battery
In your manuel there is instruction to unlocking the radio and you may have the code's written in the back. If it does ask for a code try 0000 and if that does not work try logging on to www.radio-code.com.
They can give you the instruction and codes you need to reset your radio. If you have a good relationship with the dealer they may be able to help you out too since they are always disconnecting and changing batteries.
Good luck and hope this helps.
May 28, 2009 | 2002 GMC Sierra 1500HD
Radio does not work after battery disconnect
you need to go to a deller and ask them to look it up and tell you like a chev you need to go to chev deller
May 03, 2009 | Car Audio & Video
Radio code won't work
Yes I've had the same problem you need to switch off the Radio and disconnect the battery again - Leave battery disconnected for about 5 mins and reconnect. then switch on the radio and you should have code displayed. Then type your code number in and away you go.
Jul 13, 2008 | 2003 Honda CR-V
Sony CDX-CA750X CD Player Logo
47 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
