Question about HP Color LaserJet 4650DTN Printer
HP Colour Laserjet 4650DTN occasional magenta leaks. Every so often we get smears of magenta ink on our printouts, this has happened with a number of cartridges (all official HP) no problems with the other colours. On opening the printer the transfer kit is usually covered and requires cleaning which solves the problem short termdominic. but this appears to be happening more frequently, can anyone offer any advice?
SOURCE: Fault "door Open" Hp2600n
Obviously people arent as ambitious as me. Door switch is at the top left front and is a sliding plastic section that is pushed into the interior of the LHS circuit board that I did not replace fully - the micro switch was not in the fully inward position so the slider did not engage the switch. Very simple really!
RicW
Posted on Dec 28, 2007
Nitrotrike
  • 589 Answers
SOURCE: HP Printer problem
Sounds as though one of the drum cleaning blades is failing.
When you see the double image shadow, is it any particular color? If so, that's the drum unit that is failing.
Posted on Feb 06, 2008
  • 4 Answers
SOURCE: HP Color LaserJet 2600n
See...
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447626+1203496200432+28353475&threadId=1073731
Posted on Feb 20, 2008
BFixed
  • 104 Answers
SOURCE: Hp laserjet Printer
There may be a release lever for the print head assembly which would allow you to remove the print head and clean the excess ink from it. If it appears to get better the more pages you print it may be just a matter of time and lots of pages before it cleans itself.
Try running the print head cleaning utility multiple times to help reduce the amount of ink on the print head. This could take quite a few times before it gets better.
Posted on Mar 11, 2008
Benimur
  • 6966 Answers
SOURCE: Colour Laserjet 2600n has problem
Try removing each of the cartridges and vigorously shake. It is possible that the powder inside has formed into blocks, partially solidified, gummed together. This is specially true if the ambient temperature is usually cold and the printer is seldom used.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 31, 2008
Hp printer prints smudge on side of paper
I Suggest You To Watch
Ink Smears Smudges or Splatters on the Printout To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On : HP Printer Support
Dec 18, 2012 | HP Pick Up Roller Rm1-0885 for Laserjet...
The printouts produced a column of smear ink, some time with scratch at the top & bottom of the smeared column. the last part of the paper of the column leaving some hot ink dust
That sounds like the fixing film in the fuser has begun so shred itself. the film usually runs off centre and get crunched up at the end. A new film and possibly pressure roller will sort it out. Its fun to fit though!!
Aug 19, 2011 | HP LaserJet 1020 Printer
HP 2550 L ...When I try printing in color...........I get red/magenta spots on the printout........why is this happening ?
Are the spots in a uniform pattern? Try the Magenta toner cartridge first, the try replacing the imaging unit.
Jun 26, 2011 | HP LaserJet 2550L Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
1 colour is not working
check software first, check your magenta cartridge, Download service manual from the internet to fi the problem from eserviceinfo.com ,
it is great
Mar 14, 2010 | HP Color LaserJet 2600n Printer
I wish to clean the colour printing. I've cleaned
hello mvn 500 your printer is a inkjet say yes please remove the your colour catridge or laser printer please change the magenta ink only because laser was a 4 colour option cyan, magenta, yellow and black
Jul 02, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
HP 4600 has magenta and cyan marks on back of printouts.
YOU NEED TO REMOVE THE CARTRAGES AND THEN UNPLUG THE PRINTER. CLEAN THE INSIDE WITH RUBBING ALCOHOL AND SOME Q-TIPS.YOU HAVE EXCESS INK ON THE INSIDE OF PRINTER. THIS IS WHY IT IS GETTING ON THE BACK SIDE OF YOUR PAPER. HAPPY NEW YEAR TO YOU.
Jan 06, 2009 | HP LaserJet 4600dn Color Printer
MFC240C - all printouts in green colour
green is a combination of Yellow and Cyan, it is possible that you are missing magenta, depends on the file you are trying to print, if you can print one of each color this time print only magenta it would be helpful to isolate w/c is w/c from there you can find out what is the problem
hope this helps
Aug 08, 2008 | Brother Multi-Function Center MFC-240C...
Ink blobs on edges of printouts
Dear sir,
I figured out this problem it may cause; The problem behaves strangely why only on the right section the printout is not fused. The common section I first check is the high voltage circuit causing no static properties the powder shall be fused with the drum's developer. Now, it is clear also that the cause is within the drum. Pls check drum's life by printing the machine diagnostic details to check all moving and consumables counters. Clean the drum by rotating the developer roller. Well see if there's a irregularity of powder distribution. Have a nice day.
Feb 06, 2008 | Office Equipment & Supplies
HP Color LaserJet 4650DTN Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
