Question about Meade LX200GPS Telescope
LX200 GPS problem
My scope has been unused for 3 years now. When I fired it up everything appears to be just fine but then it begins setup anytime it wants and turns all the way to the stops. It then tries to bypass the stops so I immediately shut it down. I have attempted to fix by resetting but it still doesn't help. It scares me that it will strip gears so I need some assistance. Meade has no suggestions. How can I find directions? Would reloading ASU II help? It now has 3.0i....
Any assistance is appreciated,
Rick
  • grandmajean May 31, 2008
    We experienced the same problem tonight as described with our LX200GPS. It leveled itself first, but when it began to align to stars, it got lost. At setup the scope went crazy, turned rapidly and then went into the vertical stop. It was not used last year and does not get used much as we get few cloudless nights in Seattle. We purchased an AC chord with DC transformer last year. The batteries are still in it.
    jeanspohn@comcast.net
    Genius:
  • 1,027 Answers
I would suspect the Autostar II controller - the symptom seems like a 'stuck' key that tells the telescope to slew in one direction. The controller can be opened with no problems - just be sure not to lose and parts by doing it inside. The keys are molded rubber that press to the curcuit board to make contact. Clean carefully with a dry lint-free cloth and re-assemble. Note: the red filter on the top end falls out when the case is opened, so make sure it is in place when closing. When testing, make sure the axis clamps are loose so the gears can free-wheel without causing damage. Also - do not leave batteries in the telescope in not being used - the last thing you need is a leak.
Posted on Jun 06, 2008
How do I dismantle a Simmons #1210 scope
That is an old Japanese spotter scope. I don't know if I would spend any time trying to fix it Back about a year ago they were selling for $35 dollars or so.
http://www.shopgoodwill.com/auctions/Simmons-Model-1210--25X50-3X-Spotting-Scope-18713486.html
Nov 05, 2014 | Meade Telescopes 12in LX200-ACF OTA...
10" LX200 runaway motor, right ascension.Mead
The very first thing to try is new cables. Including the DEC cable. If this does not repair it then it has an internal circuit board issue.
Buy new cables first--
www.scopestuff.com sells them. Call them and order everything new.
Also a low power supply can also cause this-- and would be the second thing I would check. You are using a separate 12volt power pack -- correct?
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Jul 24, 2011 | Meade Optics
10" LX200 runaway motor right ascension.Mead
Already answered your question.
I have 8" LX200 about
You have GOOD power? You can try and replace the hand controller cable--
I would also Calibrate motors, and retrain the drives. But re-training must be done in alt az mode.
Mar 14, 2011 | Meade LX200GPS Telescope
The motor on my Meade LX200 caught fire. How do I take it apart to send it for repair? Thanks
Meade will want the entire scope back for repair-- contact them here--
http://www.meade.com/support/index.html
Jan 22, 2011 | Meade LX200GPS Telescope
Meade LX200GPS The scope does not complete the 'Auto Alignment'
Once the scope has taken a GPS fix and knows TIME, and SITE, and you do a two star alignment your alignment stars overide any automatic alignment issues.
You could turn off the GPS put in Time, Date, and Site, do a two star alignment and everything would be fine. Centering the alignment stars is the "trick". Apparently the scope also finds NORTH OK, or the alignment stars would be way off. Since you pre-level the tripod already the software can FAIL on "tilt" and you still get good gotos.
I would not worry about it, especially since your gotos seem perfectly fine.
May 28, 2010 | Meade LX200GPS Telescope
Backwards?
Check the Autostar controller for a stuck direction key.
Jul 02, 2008 | Meade LX200GPS Telescope
Meade LX200 10" SC Telescope
You have a standard lx200 problem. If you transported your scope a lot with the drives "locked" it damages the RA and DEC drives. If you keep using it, the motors burn out and start drawing too much current. This sometimes blows the motor driver chips on the motherboard which are getting very rare.
The burned out tantalum caps can be replaced with better aluminum electrolytics very cheaply. If the ones in your Autostar burned out, they often burn up the ribbon cable. Also, they often take out U11, a 74LS14 chip on the motherboard. Also a cheap repair. You should take the Autostar apart. If they are burned up, it will be obvious. If your ribbon cable survived, you should replace the caps with aluminum electrolytics. I believe they are 6.8 uf.
So, if you can work an ohmmeter, measure the resistance of the two drive motors with the plugs unplugged. If it is about 14 ohms they are ok. If they are about 3 or 4 ohms, they are toast. Check the worm drives for end play. If there is just a little, you can adjust them. The battery jack on the control panel often breaks the solder joints on the board, causing one of the problems you describe. You can check that and replace/resolder as necessary. The on/off switch often fails and gets intermittent. These are also cheap and can be replaced. I don't repair these for a living but I repair a few of them for friends in the club. These are pretty common problems.
Feb 27, 2008 | Optics
Meade LX200 10" - RA Gears slip when mounted on wedge (Milburn)
The problem is the addition of the 80mm telescope to the assembly. The telescope is now out of balance, and places extra weight off-center as the position chages. Too great an off-balance will cause the main gears to 'jump' the worm teeth. The solution is to restore balance by adding counter weights as needed. Loosten the axis locks (carefully) and see which direction it wants to move. To balance my LX, I used a small bag with lead buckshot to determine how much weight was needed and where to achieve balance. Then I added fixed weights to the mount. Once this is done, the scope should track correctly.scopestuff.com has balance kits at reasonable prices.
Feb 03, 2008 | Meade LX200GPS Telescope
Meade LX200GPS Telescope Logo
167 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
