Question about Uniden WXI377 Submersible Cordless Phone (WXI377TD)
Can't open Uniden WXI 307 cordless phone. Not conventional screws.
SOURCE: UNIDEN ELITE 9035 + 1 (WHITE) CORDLESS PHONE INSTRUCTION MANUAL DOWNLOAD
Try here:
http://www.uniden.co.nz/RESOURCES_MAIN/pdfs/ELITE_9035_OM%20Final.pdf
This is the manual from the Uniden NZ site.
Posted on Aug 29, 2008
OldLinuxGeek
SOURCE: uniden cordless phones
Okay, this solved it for me, so maybe it'll help others.
Basically, you just need to re-register the phones by placing each one on the base unit and leaving it there for at least five seconds after the charge/in use LED light stops flashing.
According to the manual, it's necessary to re-register each phone after a power failure or if the batteries get very low or die. If you're experiencing the "connecting..." problem, this will probably fix it!
Posted on Oct 23, 2008
  • 218 Answers
SOURCE: Need an owner's manual for Uniden EZ1996 Cordless Phone
Here it is.
http://www.uniden.com/pdf/EZI996om.pdf
Posted on Dec 28, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
Wins411
  • 166 Answers
SOURCE: Need manual for Uniden EXA18580 cordless phone
The manual can be obtained from the Uniden website in PDF format at:
http://www.uniden.com/pdf/EXAI8580om.pdf
Posted on Apr 28, 2010
Testimonial: "great this was needed to know how to activate recorder from another phone .Thank you all questions are answered Rachel R."
How do you open a stuck battery compartment on Uniden cordless phone
keep trying is only thing I know of . perhaps a small screwdriver to pry on it gently
Oct 20, 2014 | Uniden Cordless Phone
How to turn off silent mode on uniden cordless phone
Select the model of your Uniden cordless phone from the list beginning at http://www.uniden.com/owners-manuals/cordless-phones/scat/cordlessphones_mnl to download a copy of the manual.
Jul 22, 2014 | Uniden Cordless Phone
I cant open the lock of the phone
What model Uniden cordless system?
Jul 07, 2011 | Uniden Cordless Phone
HI We would really like to purchase a phone Uniden 900 Mhz. We have one but its no longer working. Happy to pay whatever it costs to get same type/brand. Omar Merhi 0418 513 127
You can try EBay, they usually have at least one of everything available.
Here are some listings that came up when I searched for UNIDEN 900 CORDLESS PHONE:
http://shop.ebay.com/i.html?_nkw=uniden+900+cordless+phone&_sacat=0&_odkw=uniden+900+cordless+phone+answer&_osacat=0&_trksid=p3286.c0.m270.l1313
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
You can always try different words in your EBay search and you will come up with different results. If you have the model number for your phone then try searching for that and you should get some better results.
Good luck.
Apr 16, 2011 | Uniden Cordless Phone exai398i
How do I take Uniden phone off line in use/hold? I cannot use phone at all or receive calls.
It depends on the reason for the in use message on the line. It could be the phone or the wiring. To diagnose the problem, I like to use an old corded phone.
Plug a different phone into the jack (where the cordless base is); use a new telephone cord. Do you have a normal dial tone? If yes, try the cord with the cordless phone's base; if this doesn't solve the problem, then the problem is the phone. If the phone is bad and under warranty, contact Uniden. These phones are really not meant to be serviced by the user.
Otherwise, try the second phone at another extension. If you get a dial tone, then the problem may be the jack where the cordless phone's base is plugged in. Try the cordless phone and see if you still get the message.
If you didn't get a dial tone, find where the phone service comes in. If you have a new install, you will find that your service line uses RJ-11 jacks. Plug your second phone into the jack and check for dial tone. If the phone still doesn't work, call your phone company. There is a problem with the wiring to your location and they will fix it as part of providing the service. Otherwise, the problem is with the wiring inside your home.
For indoor wiring issues, check any exposed wires for damage. Open the wall plate and check for a loose wire. Some will terminate with screws - just loosen the screw, strip more of the strand wire's insulation if needed, wrap it around the screw and tighten carefully. Others will use a keystone jack. Open the cover (just lifts off) and check the strands. You may need to remove the wire, cut it back and strip a new section of the outer insulation. Then using a special tool push each strand fully into the appropriate slot (do not strip the strand insulation). This tool is sold in many hardware stores in the wiring section alongside the keystone jacks. A plastic version is included with many keystones.
If the wiring problem is deeper inside the walls, you may want a professional. Your telephone provider will do this for a fee.
I hope this helps.
(a few weeks ago, we had an open line due to mice eating the wires near the road. It wasn't the first time for the problem. We've also lost a dial tone due to a failed filter for the DSL after a lightning strike and when a road crew dug up the wire by accident.)
Dec 14, 2010 | Uniden Cordless Phone
Apr 28, 2010 | Uniden Cordless Phone EXAI985
I can hear but the person I am talking to cannot hear.
try cleaning the mic' without openning the phone -
from the outside by an old touth brush...
that will do the trick
if you can open the screws without any damage
than pull out the mic's cover
it is probebly full of moist
Jul 22, 2009 | Uniden DCX640 Cordless Expansion Handset
Manual for Uniden Exa 1978 cordless phone
http://www.uniden.com/index/manuals_results.cfm?cat=1
hit ctrl+f opens find window .. search exa .. little ways down you will see I978 english or french
Dec 06, 2008 | Uniden Cordless Phone
Uniden 2.4Ghz
You can get the manual on the Uniden web site. Here is a link to the page for cordless phone manuals. Just look for your model # and click it. It will then open a pdf format of the Owners Manual.
Oct 03, 2007 | Uniden E26060 DSS Cordless Phone
Uniden WXI377 Submersible Cordless Phone (WXI377TD) Logo
47 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
