Question about HP LaserJet P2015dn Printer
HP P2015DN Prints in Landscape form
HP Laser P2015DN
When I print checks from the software that we use (Sage Platinum), they print out in landscape form instead of portrait. I\'ve tried changing the settings but it doesn\'t make any difference. They all print in landscape form.
I\'m guessing that it has something to do with the print drivers but I don\'t have a clue how to get the correct ones.
Any ideas?
  • GLMP May 29, 2008
    How do I do that?
    New Friend:
  • 142 Answers
Hi
sometimes just some of the printer drivers are with "bugs" like this one.
If you are using Win 7 or newer ver. please don't let the operation system to install drivers for this printer. Download drivers from www.hp.com and install it manual. Try different drivers. I'm sure that this will help to prevent "landscaping"HP P2015DN Prints in Landscape form - pocvnqve445ajvwaaaaasuvork5cyii=
Good luck.
Pifonski
Posted on Sep 22, 2014
    Genius:
  • 1,142 Answers
Reset the setting in the printer to the factory default first
Posted on May 29, 2008
  • 2 more comments
  • Maanita Chadha
    Maanita Chadha May 29, 2008
  • Maanita Chadha
  • Maanita Chadha
    Dont forget to rate fixya
    and thanks for using fixya
    regards
  • Maanita Chadha
    Go the the printer settings in the start menu open the printer folder once you locate you printer double click the printer icon after that click on the printers tab and select properties from the dropdown menu and after this click on printing preferences button on the bottom and from the layout select potrait, click on ok.
    This will resolve the problem
Prints only part of landscape pages
SET THE PRINTER TO IT'S DEFAULT SETTINGS IF YOU CAN
If not I would unintal it , have a disk cleanup and a defrag then reinstall all software
Jun 10, 2015 | HP Photosmart D7260 Printer
Suddent my sharp arm 257 prints landscape, in wordperfect only. Other programs print properly in portrait. My HP prints ok in all programs.
Check how your printer is set up in wordperfect, it is a software setting problem not a printer problem. You may have to re-instalall wordperfect but I hope not.
Nov 04, 2014 | Sharp AR-M257 Laser Printer Toner...
Hi when I print the regular file from any
please i need tounderstand so can gave you proper answer , you
mean the printer print landscape in all time ?
Sep 01, 2013 | HP LaserJet P2015dn Printer
My HP P2015DN only prints one page at a time. If I have a 5 page document, the first page prints and then I must print the go button for each page to print.
Is the paper feeding from the manual tray or tray 2. If you are printing from tray 2 and have this problem then it is likely that your driver or software is looking for different paper types than you have loaded in the printer. For example, if you have plain paper in tray 2 and your software wants to print on letterhead, then the printer will stop after each page and by pressing the button you are telling the printer that it is ok to print on different paper. If you have the paper in the manual feed tray (tray 1) then I would check to make sure you are telling the pirnter to print to tray 1 and not manual feed when you send a print job.
May 02, 2011 | HP LaserJet P2015dn Printer
The printer keeps printing in landscape form even
This sounds like a software problem...
Try using the PCL5e driver instead.
Jan 27, 2010 | HP LaserJet P3005n Printer
My suddenly prints every other page in landscape. What is the problem? Tom
It prints in portrait then landscape, portrait then landscape and so on. I use a laptop and desktop with this printer and both are doing it. 2 sided print has not been selected.
Aug 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Go to the FILE DROP DOWN MENU
  • Select SERVER PROPERTIES
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Jul 28, 2009 | Tally Line Matrix T6050 Printer
Samsung 4216f doesnt print landscape, Vista 64
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Lexmark Optra C720 Laser Printer
HP LaserJet P2015dn Printer Logo
547 people viewed this question
Seeker5211
Seeker5211
