Question about Hitachi Heating & Cooling
Model RAS-8HK2 showing an error code 02A0 ? What's the means?
4 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: GOLDAIR3 AIRCON MODEL RAS-90(3) SHOWS
F-6 High discharge coil temp. due toover charged /condenser coil blockage/less rpm of fan motor in outdoor/non-condensable gas.
Purge out over charged gas/clean condenser coil/Replace fan capacitor./Releaseall gas and flush out the system,replace filter drier and vacumise & do gascharging.
Posted on Jan 19, 2011
hvac1960
  • 2133 Answers
SOURCE: GOLDAIR 3 MODEL RAS-90(3) SHOWS
F-6 means for high current of compressor.Check to earth 50 MOhm minimum, if any reading. compressor is grounded. check run current, if it's high current, compressor defective.
Check compressor windings all equal 1 to 4 Ohms.If not replace compressor.
Please re confirm with all wiring (may be loose connection, short of wiring) before replacing compressor.
Helpful?
Posted on Jan 20, 2011
dcramer531
  • 1654 Answers
SOURCE: My hitachi air conditioning ras
According to the codes you gave me, it is telling me that it is sensing that it does not have enough of a gas charge to run. It is getting this code from the sensors attached to the cooling coils. The alarm code is as stated below.
Indoor/outdoor safety device activated. If your unit stops within 5 seconds, indoor coil sensor defective or short of gas/leak. If your indoor works and but out door unit works for just 5minutes and stops means outdoor coil sensor defective or short of gas or leak. find by amps. If less amps than mentioned, is gas leak/short of gas.
So either you have a faulty sensor or the unit sprung a leak while it was being unhooked and hooked back up. In either case you will need a licensed repair person to do the work as it will involve releasing and filling the coolant charge from the unit. It is unlawfull for anyone unlicensed to do this work. That law is from the federal government.
Posted on Mar 29, 2011
Whts the Erro code E000020-02a0 mean
If you wish to get some details; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Apr 15, 2016 | Office Equipment & Supplies
I need a replacement remote for my toshiba air-con RAS-10NKP-A2 where can I buy one?
Setup codes to check with Toshiba brand TVs are, 0028,0022,0021,0026. If you wish to get more try this link. http://electrohelponline.blogspot.com
Dec 23, 2013 | Televison & Video
Error message 02A0 stays up on the and the treadmill will not start
hi,
Here i have added the list of error codes list for t5x .
Check the same and confirm which error its shows. error 02A0 is not listed any where.
ERROR
Aug 20, 2013 | Matrix Commercial Treadmill: Mx-t5x
GOLDAIR3 AIRCON MODEL RAS-90(3) SHOWS ERROR CODE F6 WHEN SWITCHED ON?
Jan 19, 2011 | Heating & Cooling
GOLDAIR 3 MODEL RAS-90(3) SHOWS ERROR F6 WHEN SWITCHED ON?
Helpful?
How can I fix error code 720.I first got this while trying to connect to a wireless network. I get it repeatedly when laptop is near any networks. Also pops when I click on some links.
To resolve this behavior, follow these steps:
  1. Find out which protocols the RAS server is running, and make sure that the RAS service is installed and configured properly (or ask the Network Administrator to do this).
  2. After you find out which protocols the RAS server is running, make sure that your Windows XP-based computer is running one of the same protocols that the RAS server is running:
    1. Click Start, click Control Panel, and then double-click Network Connections.
    2. Under Virtual Private Network, right-click the VPN connection, and then click Properties.
    3. In the VPN Connection Properties dialog box, click the Networking tab, and make sure that you have a protocol that the RAS server is running.
  3. If you do not have a protocol that the RAS server is running, add the needed protocol:
    1. Click Install, click Protocol, and then click Add.
    2. Click the protocol that you need to install, and then click OK.
    3. Click Close in the VPN Connection Properties dialog box
Nov 28, 2009 | Computers & Internet
Canon irc 2100 showing the coad # E020-02A0
The Magenta drum unit needs to be replaced. Good day
Nov 06, 2009 | Canon Office Equipment & Supplies
Heating & Cooling Logo
70 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
