Question about Mitsubishi VS-50703 50" Rear Projection Television
Can I download a manual for my Mitsubishi VS-50703 on this site?
  • 516 Answers
My Mitsubishi VS 50703 is fed from a DVR into input Ant A. I get sound, but no picture, until I press the 'menu' button on the TV remote; then the picture appears in the PIP window for a few...
Try resoldering the vertica IC. Very common problem. When vertical drops out the CRTs go into blanking ( shutdown no picture) but the menu and on screen displays will still work. Resoldering the IC will usually solve the issue.
Jul 15, 2011 | Mitsubishi VS-50703 50" Rear Projection...
Mitsibishi VS-50703 will not power on. just here a click and shuts down
check from the ouput of the SMPS possible that the +B main is shorting., Use a multimeter to check on the main PCB only if you are familiar with poweer electronics. other wise just checkover for burnt components and replace if there is a shorted diode, transistor, capacitor or an open fusible. IF you systematically probe you might get to the problem provided you are aware of the stages and circuit.. hope my advise has helped ?
Jul 01, 2010 | Mitsubishi VS-50703 50" Rear Projection...
Vs 50703 mitsubishi power led comes on solid no picture no sound
Press menu on the remote to check picture. if ok, check signal source(eg. dvd, cable etc). Press input or device and menu button in the front panel at the same time to get error code.
Dec 29, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-50703 Picture Foggy
Open up the back and look for coolant leaks in the CRT's. If you are curious as to what it is, it's the same type of stuff they use to make antifreeze. If you see something wet, it should feel slippery if you get it on your fingers and rub them together.
May 10, 2008 | Mitsubishi VS-50703 50" Rear Projection...
Mitsubishi VS-50703 blurry after move
A halo effect usually means the coolant in the CRTs need replacing in the effected color usually blue goes first followed by green. red seems to be less prone for some reason.
Jan 14, 2008 | Mitsubishi VS-50703 50" Rear Projection...
Green "halo" around the bright white images
I have a Samsung HCM5535W rear projection TV that had pretty much the exact same problem-- a green halo around bright white images. I researched it on the net, and determined the most likely problem was with the convergence STK-ICs, or the convergence board. I bought a replacement board with the STK ICs and installed it, but no luck, the problem persisted. I decided to mess with the manual focus adjustment on the green crt (i was seeing a green halo), and that fixed it. As it turns out, no replacement parts were necessary to fix the problem in the first place. Hope this helps somebody out there.
Nov 14, 2007 | Mitsubishi VS-50703 50" Rear Projection...
Mitsubishi VS-50703
To Fix TV: Press Menu then 1-7-3-0.
Make sure Initial is highlighted in yellow and press Enter.
To get additional input channels:
Press Menu/SetUp/AV Connection/Locked to Input 1: Should be on NO.
1(800)332-2119 Mitsubishi Customer Support
Apr 16, 2007 | Mitsubishi VS-50703 50" Rear Projection...
Televison & Video Logo
597 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
