Question about Playgo Ltd Toys
Do you have a manual for the Playgo Girls Only Sewing Machine. I have a problem with threading the bobbin case. Can I buy a manual, also a cover for the bobbin casing?
SOURCE: Singer Concerto sewing machine model 9217 - bobbin thread problem
This problem is common in sewing machines with plastic bobbin cases. The new case you've ordered will most likely solve your problems. I might suggest checking the point of the rotating hook, to be sure it is burr free.
Posted on Feb 01, 2008
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
  • 323 Answers
SOURCE: Bobbin Case will not snap into housing
Insert the bobbin case without a bobbin to see if it will go all the way into the locked position. If it does,the bobbin case and basket are okay.
Check inside the bobbin basket(where the bobbin goes) and see if there is thread or lint wrapped around the spindle the bobbin case sits on. If there is, remove it. If there isn't ,then the bobbin is probably sprung and needs to be replaced.
sewman7
Posted on Oct 14, 2008
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
rynanlimpiad
  • 36 Answers
SOURCE: I cannot thread My First PlayGo Sewing Machine
find the write thread
Posted on Apr 08, 2010
Singer sewing machine will not grab bobbin thread
It could be a timing issue. Could be a tension issue. But it may also just be lint under the plate and feed dogs not allowing the thread to fully rotate around the bobbin case. If you haven't already, I would take the plate off, take the bobbin case pieces out, and clean thoroughly with a lint brush. Take the side cover off the top of the machine and check the thread path for lint or broken thread. If you have already cleaned it thouroughly and it still won't pick-up, have a repairman take a look at it.
Jan 15, 2014 | Singer Sewing Machines
Bobbin case jams
There are several things that can cause that, and you need to investigate and eliminate the possibilities one by one. First, you need to clean both the upper part of the machine, as well as the bobbin area. Take a look at page 80 of your user\'s manual for instructions on removing the cover over the thread path--it\'s a simple matter of removing two screws, and it\'s designed to come off for cleaning. Raise the presser foot, and use ONLY unwaxed dental floss or hand embroidery floss, and floss between the tension disks--there may be lint and/or loose threads preventing the thread from seating. If you\'re unsure regarding the disks\' location, just raise and lower the foot several times--it\'s the only thing that will move. By the way--you DO thread with the presser foot UP, don\'t you? It\'s the only time the disks are spread to accept the thread and exert tension on it, and may just be your problem.
Next, take out your user\'s manual review how you put your bobbin case in, making sure that the pointy part of the case is against the spring on the bottom right. Also make sure that the spring (called a "cushion spring") has not popped out. I\'m going to upload a photo of the case with the spring out and properly in with an explanation.
You should be cleaning your machine--top and bottom--as well as adding a drop of ONLY sewing machine oil in the center hole of the bobbin basket for approximately every 5 hours of embroidery sewing. Clean out the bobbin basket (holds the bobbin case) with the tiny brush that came with your machine, or with q-tips moistened with one drop of sewing machine oil, making sure that you get under the lip of the basket.
Review with the user\'s manual how you thread the bobbin in the case to make sure tension is being exerted on the thread.
Dec 13, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
I have mislaid the instructions for my Elnita 140. In particular, I need to find the instructions for threading, including the little bobbin that goes underneath!
This is a machine made under licence for Elna back in the 80's I believe. So should be a bobbin inside a bobbin case mounted vertically. Try this link for threading up, it should be very similar.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_225_threading_diagram.htm
Many machines have this bobbin case design and they all work much the same way, you need to place the bobbin into the bobbin case with it turning the right direction, click the thread into the tension spring on the outside of the bobbin case then latch it into the rotary hook of the machine, usually there is a little latch on the bobbin case that holds it in.
Top thread is usually fairly obvious, from the spool through an eyelet, through the take up lever, through a tension device, then down to the needle.
Always thread up with the pressure foot raised as this opens up the tension device and allows the thread to seat in correctly.
You can probably buy a manual for your machine from either sewusa.com or www.sewingpartsonline.com or "sewing machine relics" websites. Or just search ebay, there are several vendors who sell pdf copies of different manuals there.
I hope this helps you get sewing with your Elnita, four thumbs up if so.
Aug 21, 2011 | Sewing Machines
Just got the sewing machine last night - read the manual, etc - the tension of the bobbin is way off. tried every solution mentioned, but its still not working
are you adjusting the little screw on the tension spring on the bobbin case by minute amounts each time? Only turn it a quarter turn each time you change it.
If you do the dangle test, (suspend the bobbin by the thread tail) the bobbin case and bobbin should stay still in the air, but a gentle tug on the case should release thread. Adjust the little screw with the mini screwdriver in your kit until you get it to this point. turn it left to loosen and right to tighten.
Also check that the bobbin is in the bobbin case the right way, page 12 of your manual should show this. Yout want the bobbin to turn anticlockwise when you pull the thread tail. Then load it into the shuttle using the latch on the bobbin case to secure it.
It is possible that the tension spring itself is faulty in which case you can buy a new bobbin case for the machine from the local machine shop, or http://www.sewingpartsonline.com/brother-lx-3125-parts.aspx
Jun 02, 2011 | Brother LX3125 Sewing Machine
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
Bobbin not threaded correctly, no manual to show me how
From the manual:
  • Open the hinged cover
  • Pull the bobbin case tab and remove the bobbin case
  • Hold the bobbin case with one hand (I use left). Insert the bobbin so that the thread runs in a clockwise direction (should come up from underneath).
  • Pull the thread through the **** and under the finger.
  • Hold the bobbin case by the hinged latch.
  • Insert it into the shuttle.
Hope this helps. There are pictures in the manual that make it easier to follow.
Mar 27, 2010 | Singer 8280 Mechanical Sewing Machine
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
How to properly thread the bobbin
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin. NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  3. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  4. Slide bobbin cover back into position.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Sep 21, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Toys Logo
570 people viewed this question
Top Playgo Ltd Toys Experts
ray gallant
Are you a Playgo Ltd Toy Expert? Answer questions, earn points and help others
