Question about Samsung PCL6215R 62" Rear Projection Television
Your very helpful!! Thanks a bunch..
Thanks a bunch.. You really helped me out here.. I will let you know how it goes.. Will have to brush up on my soldering technique, there are a lot of prongs here(23) numbers 1-3 don't seem to be going to anything as there is no solder present.. I was told to use a de-solder device to remove the old solder since it will be dificult to pry off each prong one by one to remove the whole component. Once I get all the prongs loose, then I believe the metal coolant towers will pry off the posts.. Seems like the posts are soldered to the board, but the metal towers should slide off the threaed posts. You have been very helpful, let me know if I am on the right track??
  • Samsung Master
  • 8,617 Answers
Solder wick works good to soak up the old solder Radio shack has it for a couple bucks.
Posted on May 29, 2008
My KitchenAid Artisan mixer started hesitating on Speed 10 like it's going really fast and then it slows down for 1-2 sec and then goes back to really fast. I was making whipping cream when it happen
Unplug it and check the carbon brushes under the black screw caps on the sides. BE CAREFUL they only fit properly one way so take note of where the chamfered corner goes. Next check for loose or broken wires under back cover. After that it's going to get tricky.
Apr 19, 2015 | KitchenAid Food Mixers
Solenoid wiring diagram
If you have a relay to the starter solenoid then red one from the battery then red from the relay to the starter solenoid. The starter solenoid earth wire goes into the starter housing for the brushes if not then the red wire from the battery goes direct to the starter solenoid big terminal. The other big terminal will already got inside the housing. That takes care of the really heavy wires . The small wire goes to the little terminal between the big terminals.
Jul 27, 2014 | 2000 Ford Expedition
Kirby Sentria brush roll not spinning! HELP!
this video will help you with your problem
Oct 11, 2012 | Vacuums
EVERYTIME I PUSH THE BUTTON REALLY LOW TO ALLOW THOROUGH CLEANING IN THE CARPET, THE LIGHT DOESN'T TURN ON AND IT DOESN,T **** THE DIRT AT ALL.. IT ONLY WORKS IF YOU PRESS IT UP ONCE BUT IT DOESN'T GET ALL...
You need to replace the belt whenever the green brush indicator light goes out or is not steady. Be sure to observe the wear settings when re-installing the brush. The ends of the brush are marked with 1, 2, or 3 notches and numbers. In normal use the brush should have setting # 1 towards the rug. These settings adjust the brush for wear, and moving the bristles out prematurely will result in excess brush and belt wear.
Feb 24, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Cuts off when drain cycle starts.
Your problem could be with the "timer".
Feb 24, 2010 | Maytag Washing Machines
Heater wont start makes buzzing sound
Thanks for your question,
Changing the brushes might help, but more often since you said its really stiff, something in the motor over heated and it would probably benefit you more to change out the motor, the windings could be burned up, at least you will have the peace of mind that you know your motor wont lock up again. if it were me, I would replace over repair, hope this helps, please rate this and let us know what happens, thanks again,
mr.grzz
Jan 26, 2009 | Master Heaters Master B115DT 115,000BTU...
Brushes are clean, but Roomba stops and says clean brushes
I decided to take it apart and see if I could fix it because even if something inside went "SPROING" and I couldn't get it back together, it wouldn't be any worse than it was already.
FIrst, remove the dust bin part and the brushes. Then, there are four screws on the bottom gray panel which have to be removed first in order to get to the gears which hold the brushes. I did not remove the little sweeper brush on the front, but I just slide it through the hole in the gray panel.
Then in order to get out the orange section which actually holds the brushes, there are four screws which must be removed. The orange section is attached to a blue section. This entire unit comes out by sliding it toward the area where the dust bin goes, being careful not to tear the light gray rubber gasket which covers the side.
Once that section is removed, there are two screws on each side. These screws hold the orange thing to the blue thing. Once the screws are removed, lift up only the side which has the white squares into which the brushes are inserted. These are actually the back side of little gears. There is a face plate on the outside of the orange part on this end. The other end contains a bunch of wires and I was careful not to disconnect any of them.
The face plate has six screws which must all be removed. Use caution when removing the face plate. Hold it up so that all of the stuff doesn't fall out. It has a bunch of gears, little brass looking fittings and grease. Take care to only remove the gears which have the squares which hold the brushes AND do it one at a time unless you like working jigsaw puzzles. I used tweezers and a pin to clean the "gunk" consisting of hair, fuzz, etc., out of the little gears.
Reverse the process to put it back together. Hazel, my little Roomba, played me a happy little song and immediately went back to work. She seems as good as new.
Nov 19, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Sansa e280 goes to glitch screen after trying to refresh database
if the bar in the middle of the window has stripes its normal and it will keep doing it no-mater wat you do
Oct 26, 2008 | SanDisk Sansa E280 MP3 Player
Brushes won't spin on the shampooer.
Is this a Hoover? If so the turbine which drives the brush block is bad. If a Bissell, could be a belt or on some the brush motor went bad. Really need to know what you have to help you more.
Apr 28, 2008 | Vacuums
Dyson DC14 Bar brush and belt replacement.
Try the op manual http://www.dyson.com/customercare/manuals/us/dc14_opmanual_usa.pdf
Aug 30, 2007 | Dyson DC14i Bagless Upright Cyclonic...
Samsung PCL6215R 62" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
