Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
The power cable on my montor no longer works but the plug looks like a shaver plug is this right and can you recommend somewhere to get a new cable changed the fuse and everything
  • 11,361 Answers
It may be power supply problem, most monitors the same power cable as the PC (three prongs USA plug on one end and IEC C13 on the other end).
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 08, 2010
I own a Wahl 5 Star Shaver and plugged in a non Wahl Charger cord into the device, heard a spark, and then unplugged it. I found the original Wahl charger cable, but the device won't charge; even after...
I'm afraid you blew up your shaver. Only if they build in any over voltage protection or a fuse it could be the damage is limited, but I think a engineer should look into the shaver, or perhaps you better buy a new one?
Jan 18, 2015 | Wahl 5 Star Shaver WA8061
My laptop compaq nx 6120 don,t show screen and not work
try the fn key and the f10 and f9 key on keyboard if that doesn't work to reset laptop push the power botten once and see if laptop shutdown and restart computer if still nothing on screen plug laptop into a desktop montor the plug is on the left side of laptop looking from the front of computer hope this help
and if only plugging in laptop to desktop montor works than you will need a replace the power inverter this part powers the screen and you can find one on ebay at a good price good luck with your computer :)
Oct 24, 2013 | Computers & Internet
CAble seems faulty-Is it a magnetic pick up? how can I test it?
The best and safest way (if you don't have a multimeter) is to use a torch battery, 3 pieces of wire and a torch globe. Attach wires to the centre terminal of the globe, & one to the globe base. Now cut the wire attached to the globe base and insert the torch battery between the cut ends.This creates a test circuit with the torch globe, & battery in series.There are now two wire ends free. To test your circuit, touch the two free wire end together. If you have done this right. the torch globe will light. To use your tester, touch one wire end to a pin on your shaver wall plug, touch the other wire to a hole in the shave end of shaver cable.If the globe does not light, try the other hole. If it still doesn't light, touch your tester wires together to test it's still working ok. Test the cable again, if no light, you have a broken power cable.
NOTES:
1. For this operation the razor and cable are NOT CONNECTED to the power outlet
2. Use insulated wire and solder them to the torch globe if you can, otherwise use a cheap globe holder from Tandy
May 01, 2010 | Braun 4775 Electric Shaver
I HAVE TO TURN THE MONTOR OFF AND ON MULTIPLE
Unplug the screen, the power cable from it, and leave it 24hrs. Then plug it in and start your computer. Somehow it drains it fully of power and stops the standby situation.
Hope this helps, if anyone can help me then please do.
Thanks,
Dec 08, 2009 | Dell Dimension 2400 PC Desktop
Norelco Quadra Action 7866XL suddenly quit working any ideas
It sounds like the rechargeable batteries in your shaver have degraded to the point that they can no longer be recharged, and as such, you shaver won't run, even with the power cord connected and plugged in.
To get the shaver working like new again, you need to replace the batteries or have it done for you. If you have the tools to desolder and resolder the rechargeable batteries, and can disassemble the shaver, you could do this yourself. However, most people find that having the shaver serviced for them is preferrable, since there could be a chance of damaging the shaver when taking it apart, etc.
If you wish to get an estimate for having the batteries replaced for you, contact www.electricshaver.com or you can call them at 1-888-476-1785
They are an authorized service and repair center for most major brands of electric shavers and typically get the repairs done in about a week, once they receive the shaver. They also sell most common replacement cutter blocks and foil screens for shavers, in case you need new ones now or in the future.
I hope you find this Very Helpful and best regards!
Nov 12, 2009 | Norelco Quadra 7866 XL Electric Shaver
I purchased phillips series 7100 on 27th Nov. 2007 and it is now not holding the charge. I have adherd to the 8hr. charging & there is nothing wrong with the supply to the razor. As this is within the...
It sounds like your batteries are no longer able to hold a charge and are in need of replacement. With all rechargeable shavers, once the batteries are incapable of holding even a minimal charge, the shaver becomes unable to be used, sometimes even wih the power cord plugged into an outlet. My Braun shavers all worked for about a year after it would no longer operate on battery power alone, then the shavers all stopped working regardless of being plugged in directly to an outlet.
As you mentioned you are still under the warranty period, I would suggest you contact the company and request warranty service for your shaver.
if you weren't under warranty, I would advise getting the replacement batteries and doing a repair yourself.
Hope you find this Very Helpful and best regards!
Sep 11, 2009 | Philips Health & Beauty
Mains shaver , speed of a battery one which is running down and no power!
solved the problem with the shaver, PhilipsHQ7300, "mains washable" took it back and went back to old ones, which when you use them seem to have the power to shave you and not sound like they are running on low battery, which as they are mains I cant understand alright they are reduced to 24 volts(for safety purposes if you wash them plugged in) but a cordless 18 volt drill sounds more powerful than the shaver I know they are 2 different things but surely a shaver should shave smooth and quick, I know things are progressing fast and the great selling point is for products "look how much time you save" but this shaver is not up to par with the older models and it certainly does not save time, so as we no longer have this item we have solved the problem thankyou
Aug 11, 2008 | Health & Beauty
My Acer travelmate only works from battery not mains
Most likely the power plug has come loose off the motherboard. Unless you are extremely handy with a soldering and desoldering iron, I recommend taking it to a professional to do it because one wrong move can destroy the whole motherboard.
Jun 21, 2008 | Acer TravelMate® 4062WLCi...
Braun Shaver 360 Complete #8985
the 110 plugin goes into a circuit which changes AC to DC for charging the internal NiCad batteries. If there is NO charge whatsoever in the batteries, the shaver will not work. If you have any electronics background a simple test with a VOM will determine if the bridge rectifier is putting out any DC.[you must disassemble the shaver] If you have no experience on circuits take it to a repair location.
Sep 10, 2007 | Braun 360° Complete 8985 Electric Shaver
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
44 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
