Question about Garden
Mtd mower: drive belt keep jumping off, put new belts on and has made no difference
  • 86 Answers
SOURCE: belts slipping and breaking
If you are putting on the mtd belts and installing them right then you need to check bearings in variable speed pulley Also check idler and that no other pulley has been bent from installation.
Posted on May 16, 2009
  • 18 Answers
SOURCE: motion drive belt on craftsman riding mower
there is no adjustment..it is set by the spring that engages ur drive belt....
Posted on Sep 03, 2008
  • 636 Answers
SOURCE: mtd ranch king lawn mower drive belt
Try this site it is called manuals online, should be able download a manual for it for free, also for future reference would be nice.
Posted on Jul 11, 2009
MNfisherman
  • 11896 Answers
SOURCE: what size drive belt for a mtd lawnflite 11 hp
(1991) 131-531C611/505
(1990) 130-531C611/505
(1992) 132-531C611/505
(1993) 13-505 / 133C561C611
Posted on Jul 20, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
Mtd 42" riding mower rear drive belt keeps popping off pulley
Hi, check the idler pulley arm and return spring on that belt. Its most likely not pivoting freely allowing the belt to loosen when you operate the clutch, regards Phil.
Jun 10, 2012 | Mtd Garden
Belt for self popelled mower keeps breaking? Cannot keep a new belt on pulley
Check that the pulley isn't seizing up and causing the belt to snap, also be sure you loosen up the self propelled mechanismn by spraying down with WD 40, too much belt tension can cause this, but it rather seems like the belt pulley seizes and the engines drive pulley keeps turning causing the belt to overheat and break or stretch and come flying off.
Jun 21, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a mtd mower grinds going into gear and the blades run constantly .what could be wrong i put on new belts
Hi these machines have to hve the drive belts stop completely for them to go into gear smoothly, Also if non genuine belts are used it will cuase a lot of problems. There is so many variations between different models of mtd units. To check if you have the right belts you can check it up on a site called pats small engines.
Sep 11, 2009 | Garden
How do i change the drive belt on my mtd riding mower? Do i need to drop the deck?
You might not have to drop the deck. Take a look at where the drive belt is mounted and remove only what has be be removed. At the front of the engine pulley there are probably two long bolts that have to be removed so the belt will come off and come on. Then when you put the new belt on put inside of belt (V) in to the pulley and flat part of belt up against any idler's. When on properly it should be snug.
Good luck
roundo4
Aug 07, 2009 | Mtd Garden
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
MTD 12-38 Shifting problem
mtd 12/38 blads not stoping ? theres a ajustment rod on right side under the mower turn clockwise to losen belt .
Jul 09, 2009 | Mtd Garden
MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Jun 28, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
Belts slipping and breaking
May 15, 2009 | Garden
Garden Logo
137 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
