Question about Samsung LN-T4665F 46 in. LCD Television
A kid intentionally threw the remote control at the middle of the screen, eventhough it's still working, the part that has been hit is already damaged and only 3/4 of the screen is visible
    Brigadier General:
  • 3,006 Answers
If the LCD panel has been damaged then the tv is a write off, sorry.
Supplying and fitting a new panel will cost more than buying a replacement tv as it's overwhelmingly the single most expensive component. When you buy a new tv you are effectively buying a flat panel at a huge volume discount and all the other parts which make it a tv are thrown in for free.
The tv rental company I work for is the largest such business in the UK and only ever replaces broken panels by cannibalising other tv's which have been returned with other serious and unrepairable faults. In practice the panel is rarely swapped, what usually happens is that the broken screen tv donates its inner workings to a tv with a good panel and outer casing but with serious electronic faults (usually due to liquid damage). The panel only ever gets swapped over if the outer casing to the tv is cosmetically unacceptable.
Posted on Oct 08, 2010
Kids threw remote at screen and left slight mark that does not wipe off. anyone out there no how to repair kid damage?
It will be best to use a drop of Glycerin to wipe out that place. It won't make any harm, even if that scratch is there.
Gopakumar Gopalan Google
May 01, 2014 | Emerson 40" Lc401em2 1080p 60hz Flat Panel...
Help! My son threw a small plastic toy and it hit the screen causing it to have a shatter effect in the middle of the screen. Now all we have is lines and no picture. Is there any way it can be...
Hello, sorry to tell you this but the lcd is already damage, and replacing the lcd will resolve the problem. Or you can try to contact a technician to inspect the damage personally. Because it is much better to do some actual testing to the unit. Good day and best regards.
Aug 08, 2011 | RCA 46 46LA45RQ LCD TV
My kids threw a small piece of Lego and hit tv screen. Now Screen have a horizontal line across and you can actually see the point of impact where it was hit. Any suggestions on how to fix this? Thank you
It has caused a screen bleed of the pixels. There is no way on repairing this unless you replace the whole screen which will cost as much as the t.v. itself. As time persist, the lines will become larger as the crack will spread.
Apr 08, 2011 | JVC 42 in. LCD TV
Hi. My kids threw a small piece of Lego and hit tv screen. Now Screen have a horizontal line across and you can actually see the point of impact where it was hit. Any suggestions on how to fix this? Thank...
Lego broke the front glass of the LCD........... time for a trip to Best Buy or Circuit City for a new TV. Cost to replace the screen will exceed the cost of a new TV.
Apr 08, 2011 | Televison & Video
My kid threw the remote and went into the screen. need new screen.
sorry but you need a new tv . its a cheaper option for you parts are pretty expensive and labour too
Feb 16, 2011 | Sharp LC-42D43U 42 in. LCD HDTV
We just purchased 2 new wii remotes to add to our system .......(of course the kids threw the boxes away with the Christmas paper --NOT GOOD) we have tried numerous brand new batteries ......tried...
Frist make sure your batteries are right size and installed the right way. Then turn on your wii press the A button at this point you should see lights at bottom of controller. Now push the sinc buttons on the controller and the wii system and you should be set.
Dec 31, 2010 | Nintendo Wii Console
Kid threw remote at screen, lines going across it....
The LCD Screen is damaged beyond repair. Cost to replace TV is cheaper than repair.
May 21, 2010 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Monster remote by tv tech codes
Hit code search ... then the TV button .. then turn it off and on alot of times .. until the tv shuts off .. then hit enter ...
it takes me like 10 trys of doing this to get mind to program ... because i always hit the on/off button atleast once more after the tv shuts off because its such a shock when it does finally turn off...
I have to do this once a month because the kids always drop it and knock the batteries out
Sep 01, 2008 | Universal Remote Control Remote Control
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
Samsung LN-T4665F 46 in. LCD Television Logo
213 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
