Question about Simrad Rs82 Handset Vhf Radio
Hi.\r\nWhen my rs82 VHF has been powered on for about 6 hours it freezes. I can do nothing with the handset. I have to turn power of and then on again. Then only a short later the radio freeze again less than 1 hour. I have tryed to take the cables for the SIMnet of but the problem is stille the same. Best regards Per Appel pa@su-per.dk
So my TV will NOT come on. I turned it on and it went off and now will NOT power up. No lights, nothing. I tried manually and remote. Electrical outlet tested and works.
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
This tv will not turn on. I took it to a tv ... same here my lg tvkeeps turning of and won't turn on. Read more ... It will comethough.. Read more ...
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no power service repair review guide ... u re look l?ke my teacher bro :) ? learn much way amaut tecnic repair from you, thx for .... plug it in the orange logo stays on...will not power on....its a vizio 37 ... Now it willcome on after half and hour of pressing power.
Television will not turn on? ' Yahoo Answers
Dec 29, 2015 | Televison & Video
I can't transmit on my rs82 radio although the station can receive
Simrad RS82. Ok, can you switch to 1 watt and see if it transmits on low power? If it does, check all wiring and your power source (battery or power supply) for enough voltage. Marine radios often get corrosion on connections. Later, check your external antenna and connectors. Of course, you can never transmit on the pre programmed weather channels.
Oct 01, 2015 | Radio Communications
Proscan tablet support MY PROSCAN TABLET IS FREEZING UP WHAT CAN I DO
Hi Lesy, let the tablet run out of power or more to the point make it run out of battery then wait 6 hours then fully charge it before turning on. Cheers Greg.
Apr 27, 2014 | Tablets & eReaders
Keeps freezing up
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
Jan 29, 2014 | Kocaso sx9701 Android 4.0 ICS MID 9.7" IPS...
For no reason, my freezer went up to 56 degrees in a matter of 5-6 hours. I pulled the plug like the manual states because the temp was blinking. That solved the blinking. In 6 hours the temp dropped to 44...
You have either a sealed system problem or a control board problem. It's difficult to know which is which. You will need a qualified technician to determine what the problem is.
Good luck
Jun 17, 2011 | Samsung RS265LABP Side by Side...
Lg phone will not turn off. Screen is frozen
Take off the back cover and remove the battery, Wait 10 seconds and replace the battery and cover. Power on the handset and you should be back up and running again.
This may only be a small glitch causing the phone to freeze and nothing major.
Jan 16, 2011 | Cell Phones
Downlading manual in DANISH or ENGLISH for VHF
Hi!
Here's the link to download the manual for the Simrad RS82:
Unfortunately, there doesn't seem to be a Danish version listed:
http://www.simrad-yachting.com/Products/Professional/Communication-Systems/RS82-dVHF-Radio-System/Downloads/
Hope this helps!
Aug 31, 2010 | Simrad Rs82 Handset Vhf Radio
The printer screen freezes and i cant do nothing i have disconnected the power sometimes it work but freezes again
Please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
May 13, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Model 25942EJ3-C
Try this:
1.) Make sure the answering system is on.
2.) Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3.) Press key (8) to enter Time/Day set menu using the handset.
4.) To set the Hour, key in (00)-(12), like 08 for 8 o'clock.
5.) To set Minutes, key in (00)-(59), like 15 for 15 minutes after the hour.
6.) To set AM/PM, press the CALLER ID-VOLUME up or down buttons.
7.) To set the day of the week, press the CALLER ID-VOLUME up or down buttons.
8.) Press #PAUSE/ringer button to confirm the setting.
Hope this helps you out! Hal
Apr 16, 2009 | GE 26938GE1 Cordless Phone
Simrad Rs82 Handset Vhf Radio Logo
Top Simrad Boating Experts
Michael Vincent Cruz
Steve
Steve
ray gallant
Are you a Simrad Boating Expert? Answer questions, earn points and help others
