Question about Liebherr Refrigerators
My new Lieberr 7082 344 00- the fridge section works ok but I can't get the freezer to work. The light goes on but the rest of the controls are lifeless. Can't switch the freezer part on
  • 17 Answers
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Posted on Dec 10, 2007
  • 184 Answers
SOURCE: freezer compartment of fridge freezer
ON ALMOST ALL REFRIGERATORS, THE FRESH FOOD SECTION GETS ITS COOLING FROM THE FREEZER BY AIR CIRCULATION. IF THE AIR ISN'T CIRCULATING, FINDING THE CAUSE WILL REMEDY THE PROBLEM. THE MOST FREQUENT FAILURE IS THE DEFROST CYCLE AND IS EASILY DIAGNOSED BY LOOKING IN THE FREEZER SECTION. IF FROST IS PRESENT ON THE BACK WALL, (OR FLOOR OF OLD MAGIC CHEF TOP MOUNT), THEN A DEFROST FAILURE HAS OCCURED. THERE ARE THREE COMPONENTS IN THE DEFROST CIRCUIT. THE CONTROL, THE HEATER, AND THE BI-METAL. FIND THE DEFROST CONTROL AND SET TO DEFROST. IF THE HEATER COMES ON, THE CONTROL IS BAD. IF THE HEATER DOES NOT COME ON, EITHER THE HEATER OR THE BI-METAL IS BAD.
TO FIND THE BI-METAL, FOLLOW ONE SIDE OF THE HEATER WIRE FROM THE HEATER TO A SMALL ROUND DISC WITH TWO WIRES COMING OUT OF IT. THAT IS THE BI-METAL.DETERMINE WHICH IS BAD WITH VOLTAGE OR RESISTANCE MEASUREMENTS.
Posted on Mar 27, 2008
SOURCE: FREEZER WORKING - FRIDGE NOT WORKING
Ok, got it sussed! [well here's what I did anyway]...
Quite simply, I turned off the fridge-freezer at the mains overnight and in the morning, broke and chucked out the ice chunks that had lined up in the bottom of the freezer section and then turned it back on. I returned that night to see that it was working fine again! Hallelujah, I got my fridge back!!
So it seems that all it needed was a good long defrost, so far so good! I hope this solves your problem.
Posted on Jul 18, 2008
SOURCE: top of fridge warm but bottom freezer working ok
there is also a fan in the freezer compartment which if broken will cause this problem. you need to check that both fans are working. please refer to other fridge posts here re repairing/ replacing the freezer fan- there is a document here which shows you exactly what you need to do. important thing is to switch off the appliance first and leave the freezer door open for about 20 minutes before attempting to remove the back cover ie let it warm up first, so that you don't break any of the panels.
Posted on Jan 05, 2009
woodchuck789
  • 4070 Answers
SOURCE: Creda R335NW Fridge/Freezer. The fridge section
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Posted on Jul 03, 2009
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Jun 16, 2014 | Daewoo FRSU20IA Freezer
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
Freezer not freezing, or if it is lettuce etc in fridge freezes
With fridge freezers, there is usually a solenoid at the back that controls where the refrigerent goes. It consists of a sealed valve and a solenoid coil. It is possible that this has become open circuit so cannot direct refrigerant to the freezer section.
Another alternative problem may be the thermistor in the freezer section. This sensor will tell the control board the temperature in the freezer section. If it gets it wrong, then the freezer will overcool or not cool at all. Often a manufaturer will standardise on a part, so swapping the fridge and freezer thermistors around can identify that this is the fault - then just buy another 1.
If these tests don't work, you're looking at a new control board. Second hand ones may be available.
Best of luck.
Feb 08, 2010 | Liebherr Premium K 2954 Top Freezer...
Fridge section is too cold causing food to freeze
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 03, 2009 | Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Fridge and freezer sections no longer cold, although control panel lights up and ''appears'' to work. Interior light works and something can be heard running. Both sections failed together and quite...
you might have coils that are frozen up. Ironic that ice build up will prevent the fridge from working. In my case I could access the coils by removing the panel at the back of the freezer (on a maytag side by side). You then have to remove the ice (let it melt away, do mot try to cut it out...if you do you could damage the coils and there goes the fridge). In my case the problem was caused by a thermostat that was faulty. Easy to replace and all works good. Another issue could be a circuit board (located in the top part of the fridge section). I ended up replacing both parts. not too expensive if you do it yourself (less than $100 for both parts). It took me about 2 hours to do. It helps if you can get a diagram of the inside of your fridge.
good luck!
Aug 19, 2009 | Samsung Refrigerators
Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Jun 17, 2009 | Candy CPCA240FFK Bottom Freezer...
FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Jan 22, 2008 | Freezers
Refrigerators Logo
43 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
