Question about Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2IS Digital Camera
I was taking a ground shot at my daughter's tennis lesson and dropped my Canon PowerShot S2IS Digital Camera about a foot from the ground and now camera will no longer take pictures. When turning camera on the lens moves in and out a bit but seems to be jammed - lens won't go in all the way and sticking out when camera turned off. LCD monitor shows recorded images when toggle turned to green light but when toggle turned to orange light the lens goes back and forth within reduced range four or five times, all the while making shorter movements and ticking sound as it tries to establish operation then stops and LCD monitor flashes and turns black with E18 code showing up in bottom left corner momentarily before camera turns itself off. Any assistance you can offer would be greatly appreciated.
    Genius:
  • 3,422 Answers
HI,
You damaged the camera when you dropped it...and there's not much you can do if it's a permanent lens error (E18), other than buying a new camera.
Anyways here are few troubleshooting steps you can try:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras AV cable, and turn the camera on in picture review mode. Have no idea why this would work, except that quite a few people have reported some success with it.
Fix #4: Place the camera flat on its back on the kitchen table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum cleaner.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. Take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. A lot of people have reported success with this method. HOWEVER, there is some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables.
Fix #7: Try forcing the lens. Many people have also reported success with this method. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include pulling, pushing, rotating or twisting on the lens barrel while hitting the power button. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the lens barrel side that has the largest gap. While doing these, listen for a click that indicates that the lens barrel guide pins have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Goodluck,
Please don't forget to rate or accept the solution
Posted on May 29, 2008
  • Priya darshan May 29, 2008
  • 4,234 Answers
You have jammed the lens motor assembly, possibly broken a tooth or more. The camera attempts to move the lens assembly the full range during its power up check. If it fails, the camera will shutdown to prevent further damage (eg. the motor burning out trying to move the lens). This one will need service.
Dan
    Brigadier General:
  • Canon Master
  • 3,614 Answers
Try to remove the battery for an hour, & put it back again..
Let me know..
Maximum sd card for canon powershot s2is
SD cards max out at 2GB. The S2 will not work with higher-capacity SDHC cards.
Mar 27, 2013 | Canon PowerShot S2 IS Digital Camera
I have a Canon PowerShot S2IS that gives me a black screen and a "change batteries" message even with new batteries. Is there a way to re-set or re-boot the camera?
Try cleaning the battery compartment contacts with a cotton swab "dampened" in rubbing alcohol. Also clean the battery contacts and the charging station the same way. Thanks, Dana
Nov 22, 2009 | Canon PowerShot S2 IS Digital Camera
Lens error restart camera
same thing just happened to me today. the little girl that I babysit dropped it about 1 foot to the rug on the ground, not a hard drop at all. so i tried taking out the batteries and hit it on the table (read on other sites) then i gently turned the end of the lens (my lens was stuck out) counter clock wise and it clicked and then worked.
Apr 20, 2009 | Canon PowerShot SD1100 IS Digital Camera
My daughter dropped the canon power shot a650 and now the fold-out screen does not work, although she can still take pictures using the view finder. Can the fold-out screen be replaced? It appears to...
here u go u can buy and replace it is easy to do so but u can get it fixed as well see the link and pls rate me FIXYA for help
http://www.darntoothysam.com/servlet/the-1222/Canon-PowerShot-A650-IS/Detail
Mar 27, 2009 | Canon PowerShot A650 IS Digital Camera
No Image to Shoot
There is a temporary fix that works sometimes but eventually it will stop working alltogether. If canon can't help, might try this:
<http://cgi.ebay.com/Repair-blank-black-pictures-S2IS-canon-powershot-S2-IS_W0QQitemZ300293064869QQcmdZViewItemQQptZDigital_Cameras?hash=item300293064869&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50>
Dec 20, 2008 | Canon PowerShot S2 IS Digital Camera
E 18 problem
This error is caused by a faulty lens motor, contaminated transmission, or mechanical damage from dropping. Unfortunately, there is no easy fix for this and it requires service from Canon or other repair facility.
Dec 15, 2008 | Canon PowerShot S2 IS Digital Camera
Canon powershot s2is file transfer
you want to put the pictures from your computer back onto the camera? you can use a card reader and do a file transfer (drag and drop).
Mar 14, 2008 | Canon PowerShot S2 IS Digital Camera
Canon powershot S2IS
1>>u may have dropped the camera in some place.
2>>the camera POWER ON switch must have got pressed while the camera was inside pouch. if this has happened, the lens system gets jammed and so lens wont retract. for this problem it costs nearly 1800rupees in indian service center.
Dec 21, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
94 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
