How can i change my computer keyboard setting?
When I press shift and the question mark key I only have access to the É and the + key when I press the Fn key. How do i get the question mark working
You have likely changed the language setting on your keyboard. Typically you can change the language setting by pushing ctrl+shift. Most computers are set up for 3 languages, so you should try cycling through all three languages to get your keyboard working.
If this does not work, this site tells you how to change your language setting: http://support.microsoft.com/kb/258824
Sep 05, 2011 | Acer NSK8458AN Keyboard
My probook 4510s is set up with US keyboard, how can I change it to UK setting?
hi
  • Right-click on the taskbar and click on "Toolbars."
  • Step 2 Click on "Language bar." If this option doesn't appear on the menu, you only have one language on your computer. Refer to the steps in Section 2 to add languages to your computer. If you have to add "English (United Kingdom)," you may have to restart your computer before you can change the keyboard layout.
  • Step 3 Click on "Input language."
  • Step 4 Select "English (United Kingdom)" from the list of languages.
  • Step 5 Click on "Keyboard layout" and select the "English (United Kingdom)" keyboard layout and apply the changes.
    Add Languages to Your Computer
  • Step 1 Click on the "Start" icon.
  • Step 2 Click on "Control Panel."
  • Step 3 Click on "Clock, Language, and Region."
  • Step 4 Click on "Regional and Language Options."
  • Step 5 Click on the "Keyboards and Languages" tab and click on "Change keyboards..."
  • Step 6 Click on "Add..." in the "Installed Services" section.
  • Step 7 Select "English (United Kingdom)" on the list and check each of the entries under "Keyboard" and "Other," and then click on "OK" to close the menu.
  • Step 8 Click on "Apply" and "OK" to add "English (United Kingdom)" to your computer.
  • Jun 30, 2010 | HP ProBook 4510s FM849UT Notebook
    I cannot get a question mark, the upper case E with a grave (green) on keyboard appears
    When you get that it usually means the language setting for the keyboard has changed.
    The standard key markings are valid for most english language settings. US is the default. To change this go to start - settings - control panel. Then look for Regional and language settings. Click on that and then in the window that open there are three tabs along the top. The middle one should say language, click on that one. In the Text Languages and input options area click on the Detail button. A new window opens. At the top it shows your language. And in the box under it will show your lnaguage and installed keyboard layout. So if I were using Canadian English and the US keyboard then the keys will function as marked. To change the keyboard language click the add button, then select your language and then the keyboard layout. When you click ok it goes back to the previous window but now will show the original setup and the new one you just made. Just remove the original and apply and close everything and your keyboard will now produce the correct characters.
    Apr 23, 2010 | Acer NSK8458AN Keyboard
    Character keys problem
    I doubt the keyboard itself is at fault. Try it on another computer and see if it does the same thing. If it works okay on the other system, then the Keyboard settings on your machine were probably changed. Go to the Control Panel and look at the Keyboard or Regional Options entry, and make sure that it is set to English. If your computer has foreign language support turned on, there may also be a control in the system tray at the lower right of the screen that has been changed from EN to some other language.
    Mar 13, 2010 | Trust Keyboard KB-1120 Keyboards
    Hey my friends keyboard is typing letters incorrectly, can you help? It started when she tried remote assistance on the windows live program, and she has windows xp with a gateway keyboard
    It may be that the default settings for the keyboard have been set to a different language/regional area.
    You could try changing it and see if it works.
    If you wish to change the keyboard layout, you can do this by right clicking on your taskbar and select "language bar". When this is done, right click on the keyboard symbol and select "settings".
    Alternatively, go start>control panel>regional settings> and change it there.
    Aug 03, 2009 | Gateway 2520915 Keyboard
    My keyboard won't work at all
    Dear sir/madam,
    please do the following tips to solve:
    1. checkout the cable connection between your keyboard panel and port on your computer.
    2. checkout the keyboard port, whether its working or damaged (check the keyboard cable connection's pin also)
    3.checkout the post settings of computer with keyboard (commonly, keyboard light would blinking on and off at the time of computer boots)
    4. if the post will be come properly, then you have to view the keyboard settings in the control panel of operating system.
    5. commonly, keyboard issue comes with in the above instructions only. if its not working, you keyboard cable will be damaged or the keyboard have a problem related with in.
    here, you can only change the keyboard.
    thank you,
    Aug 23, 2008 | Compaq Computers & Internet
    Dell wireless mouse and keyboard installation problem
    click start
    right click my computer
    properties
    hardware
    device manager
    ?mouse and keyboard
    scan for hardware changes
    Aug 23, 2008 | Dell Wireless Keyboard Optical Mouse w0147
    Computer keyboard.
    The problem does not lie in your keyboard, but rather the keyboard layout settings. Go to control panel, keyboard options and select the standard US settings.
    Jul 06, 2008 | Gateway 2520915 Keyboard
    Boot problem
    you need to do the following :
    1- get yourself a PS2 keyboard
    2- go to windows and install the S5100K-G keyboard driver
    3- reboot the computer and go to the BIOS settings and make sure to enable the USB keyboard and mouse feature
    4- shutdown the pc .. remove the PS2 keyboard and plug the S5100K-G keyboard then reboot
    this should solve the problem
    Dec 29, 2007 | Unotron S5100KG Keyboard
    Problem with keyboard
    Hi
    this is a comen problem with key boards what you could try is dissconnecting your keyboard from your PC and restarting you PC when you hear a bleep and a messidge on the screen follow the instructions and replug your keyboard back in another thing you could try is setting your keyboard to the UK setting this might help to
    Nov 05, 2007 | Logitech Deluxe Access Keyboard
    Computers & Internet Logo
    19 people viewed this question
    David Payne
    David Payne
