Question about Epson ACULASER CX11NF All-In-One Printer
Service Req c2011 - Epson ACULASER CX11NF All-In-One Printer
2 Suggested Answers
epsinopin
  • 9 Answers
SOURCE: ADF Jam... Service req c2011
Can be a tough one.
1st - Open the ADF & make sure that the 2 little Sensor tabs move freely.
2nd - Lift the ADF & check that the White Plastic Paper Guide is "down in the slot" & not resting on edge of the white flat bed scan pad or overlapping the scan pad.
For some C Error Codes
Check for electrical interference from external devices.
Disconnect the Printer from all devices, and run a test print..
Here are the "c2011 error" fixes per the manufacturer:
Replace the Automatic Document Feeder.
Replace the Scanner.
Replace the Main Board.
You might try unplugging the ADF & see if you can operate without it.
If you unplug the scanner, the printer might not function.
Posted on Feb 06, 2009
Service req e 406 -
I'm going to assume you have an epson 406, and that you got a "service req" error. Means, "service required". There should be a code, too, that might tell us what service is required, but without that, we can do little for you.
Jul 15, 2016 | Office Equipment & Supplies
Service req 0001001C
SERVICE REQ - 0001001C - FS origin (Suction fan shutter home position) error
Jan 18, 2013 | Epson Stylus Pro 10600 InkJet Printer
Service req. light stays on in 08XB?
KEEP PRESS THE MILE RESET SWICH.. AND OPEN THE IGNITION SWITCH FOR 5 SECONDS..
Aug 07, 2009 | 2008 Scion Xb
EPSON AcuLaser C1900 with Error "Service Req E020"
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
May 18, 2009 | Epson AcuLaser C1900 Printer
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
Error in printer
" Service Req E 0003" means that your printer needs to be serviced. Pls contact your service provider.
Jan 27, 2009 | Epson EPL N1200 Laser Printer
Can be a tough one.
Jan 27, 2009 | Epson ACULASER CX11NF All-In-One Printer
Greetings,
Here try this, turn it OFF then locate the cable that is connecting the ADF and the main FLATBED scanner. Disconnect and re-connect it.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 17, 2008 | Epson ACULASER CX11NF All-In-One Printer
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
Epson ACULASER CX11NF All-In-One Printer Logo
162 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
