Question about Epson Aculaser C1100 Printer
It keeps displaying the following and therefore not working Service Req E537
    Guru:
  • Epson Master
  • 452 Answers
E537 is Fuser error check the thermistor
Posted on Oct 12, 2010
My nokia 2700 req for security passwordi forgot password.any solution?
you can try the following solutions:
1. on your phone's homescreen enter these: *#2640# to Display the phone security code in use
2. if step 1 does not work, try this (MAKE SURE that you know your PUK, if not contact your service provider first and ask for the PUK), enter an incorrect pin until the phone prompts you to input the PUK, input the PUK you obtained from the service provider and your phone should be working properly
Apr 20, 2011 | Nokia Classic 2700 Cell Phone
EPSON ACULASER C1100 When running a given Message Service Req Error E537 Please help me
E537 is the Fuser error check the latch lever of the fuser assy is set incorrectly
Oct 09, 2010 | Epson Aculaser C1100 Printer
Light flashing Service req E537
E537 specifies that the fuser unit has failed and will require replacing. Before that try removing the fuser, cleaning the electrical contacts and refitting it a couple of times - it could just be dirty contacts or incorrectly seated. To do this, turn off the printer, open the top back cover (if the printer has been turned on the fuser may be hot so be careful). There are two "latches" on top of the fuser which need to be rotated to the unlocked position (look for the arrows pointing to the padlock symbols). Next look at the L/H side at the front of the fuser, there is a little pale plastic "paddle" that needs to be rotated up to allow the removal of the fuser. (NB - on older printers this is a solid piece of plastic held in by a screw, you will need to remove this!) The fuser unit will now lift straight up and out of the printer using the two top latches to lift it. Refitting is a straight reversal of the above. If this fails then visit Epson.com for contact details of a parts stockist near you or just google "Epson C1100 fuser unit" to find an on-line supplier. Hope this helps.
Jul 07, 2009 | Epson Aculaser C1100 Printer
Service req E537
E537 is a Fuser Unit error, it most likely requires replacing but first try a few simple checks. Lift the scanner unit upwards out of the way and open the top rear cover to expose the fuser unit. Check that it is seated properly and that both "latches" are in the locked position. Try unlocking them and removing/reseating the fuser (there is a small plastic hinged piece on the L/H side of the printer that needs lifting to allow removal). If all of this fails you will need to replace the fuser unit. A google search should turn up a stockist in your area as they are listed as consumable items.
Please take a moment to rate this solution. Thanks.
Mar 20, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser C1100 E537
Hi there
This suggests a fuser error. This is the hot unit at the rear top of the machine.
Steps are as follows:-
1. Open COVER FUSER.
2. Draw out the COVER RH boss from the hole on COVER FUSER while pushing
COVER RH outward, and remove COVER FUSER.
After removal check coninuity across heater lamp amd thermistor terminals. If either shows anyhing more than 13 Ohms then you need to replace your fuser unit.
Anything more than that requires hands on technical expertise.
Good luck
ivorpits
Dec 20, 2008 | Epson Aculaser C1100 Printer
Fuser error E537
Get a service manual from HERE and follow the routine to remove/replace the fuser unit.
Jun 28, 2008 | Epson Aculaser C1100 Printer
Service req e537 has come up on the display panel of our epson aculaser c1100. Cant find a manuel ....can you advise on this problem please? Rhonda
buenas tardes tengo el error service req E537 y quisiera saber como hago para girar la varilla? espero tu respuesta gracias
Dec 20, 2007 | Epson Aculaser C1100 Printer
Epson C1100 Service Req Error E537
E537 is listed as FUSER FAIL: ? Control Thermistor detected a temperature exceeding the specified temperature. Safety Thermistor detected a temperature exceeding the specified temperature. ? The Control Thermistor did not detect a Ready even though the specified time elapsed from Main Lamp ON at Warm Up. ? The Main Lamp continues to stay lit even after time specified for the Main Lamp elapsed after the Control Thermistor detected a Ready. ? The Control Thermistor detected a temperature below the specified temperature even after the specified time elapsed from Main Lamp ON at Warm Up. ? The latch lever of FUSER ASSY is set incorrectly. You should replace the fuser unit. If the error remain after changing the fuser you need to take the machine for service as the error may relate to the power supply units.
Aug 25, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
421 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
